Reading: PLC Programming Examples on Industrial Automation
Inst Tools > Blog > PLC Tutorials > PLC Programming Examples on Industrial Automation
Last updated: August 11, 2023 10:22 am
5 Comments
3 Min Read
Develop PLC Programming Examples on Industrial Automation according to the logic given below,
PLC Programming ExamplesProgram Description:Program Output:When Start PB is pressedWhen Stop switch pressed before the 20sWhen Stop switch pressed after the 20sWhen Fan reset switch is pressedConclusion:
  1. A Saw, Fan and oil pump all go ON when a start button is pressed.
  2. If the saw has operated less than 20s, the oil pump should go off when the saw is turned off and the fan is to run for an additional 5s after the shutdown of the saw.
  3. If the saw has operated for more than 20s, the fan should remain on until reset by a separate fan reset button and the oil pump should remain on for an additional 10 s after the saw is turned off.
  4. Write a PLC program that will implement this process.
Rung 0000:
Start/Emergency Stop PB latched with memory B3:0/0.
Rung 0001:
B3:0/0 enabled to turn on Saw (O: 0/0), Fan (O: 0/1 ) and Oil pump (O:0/2).
Normally closed contact of Stop switch is in series Saw output to turn off.
Fan reset switch and Timer T4:0 is connected to turn off Fan when condition meets.
Timer T4:2 done a bit and memory bit is to turn off the oil pump.
Rung 0002:
When the stop is pressed, according to the logic mentioned in point 2, Fan output (O: 0/2) needs to turn off after 5s.
Comparator block restricts the timer T4:0 to run after the 20s of Saw operation.
Rung 0003:
Timer T4:1 runs when the start is pressed. When the stop is pressed at any point after the 20s, Saw output will go off.
After 10s, the oil pump will go off. This operation is done by Timer T4:2. Timer T4:0 done bit is used to restrict the Timer T4:1 operation when T4:0 is ON.
Rung 0004:
Less than a comparator block is used to perform the logic mentioned in point 2, to turn off Fan when saw output operation was less than 20s.
Program Output:
Now we see the simulation of above ladder logic for different conditions as mentioned below.
Motor Start after seconds delay in ladder logic
Motor Stop after timer using ladder logic
Fan Logic using PLC Programming
Conclusion:
We can use this example to understand the programming logic in Allen Bradley PLC.
PLC Programming Tutorial for Beginners - Siemens PLC Training Course
Author: Hema Sundaresan
  • PLC Sequencer Programming
  • What is PLC Redundancy?
  • Encode & Decode Instruction
  • PLC Program for Motor Starter
  • JUMP Instruction in PLC Program
Up Counter PLC Program
Program Flow Control Instructions in PLC Programming
XG5000 Example of Simple Conveyor Control PLC Program
Create User-Defined Data Types and Function Blocks in Studio 5000
#10 PLC Best Practices – Assign Register Blocks by Function
Basics of Fail-safe Circuits
5 Comments
  • Adrian Takkar says:
    January 21, 2020 at 9:39 am
    I would like to experiment on PLC programming examples.
  • Dean says:
    August 13, 2020 at 9:10 pm
    great example
  • salman says:
    March 9, 2021 at 4:22 pm
    good logic
    but if I am correct Once some one off the saw before 20s and everything stops…..
    when someone again press the off button the oil pump will run for 10s.
  • Amit says:
    April 1, 2022 at 7:00 pm
    what is the condition for oil pump if the saw runs for more than 20 sec??
  • juuko quraish says:
    September 30, 2022 at 11:23 am
    Thank you
Open User Communication in Siemens Tia Portal – PLC to PLC
FC Function in Siemens PLC
Basic Conveyor System for Product Handling in Omron PLC
What are AI, AO, DI, and DO? – Definition, Examples, Purpose
PID in Siemens TIA Portal
#18 PLC Best Practices – Store PLC Hard Stop Events from Faults
PLC Fault Diagnosis – PLC Training Documents
PLC Wiring
Online and Diagnostics of Siemens PLC
How to Use Diagnostic Buffer for SIEMENS PLC?
Ladder Diagram PLC program
PLC Counter Instructions
Types of Limit Switches
Types of Limit Switches – Principle, Advantages, Disadvantages
Mitsubishi PLC Counter Tutorial Using GX-Works2
sinking-and-sourcing-digital-output-modules
PLC Digital Signals Wiring Techniques
InTouch SCADA Training Course
Free InTouch SCADA Tutorial Course for Beginners
Automatic Box Filling System using PLC Programming
Pneumatic Valves and Cylinders Sizing
Pneumatic Valves and Cylinders Sizing – Part 2
SCADA System
What is SCADA System?
Performance of Systems Objective Questions
Performance of Control Systems Objective Questions
Control Valve in PlantPAx Project
Configuration of Control Valve in Studio 5000
Volumetric Flow Calculations
Functional block diagram for analog alarms
PLC Logic for Analog Alarms using Functional Block Diagram
Electrical Equipment Selection in Hazardous Area
