Reading: PLC Programming Example for Motor Forward and Reverse Control
Inst Tools > Blog > PLC Tutorials > PLC Programming Example for Motor Forward and Reverse Control
Last updated: March 4, 2021 2:51 pm
3 Comments
2 Min Read
Make the example ladder logic to control the motor in forward and reverse direction using PLC Programming with limit switches as sensors.
PLC Example for MotorMotor Forward and Reverse ControlList of Inputs and OutputsPLC ProgramProgram DescriptionConclusion:
The Workpiece starts moving on the left side and moves to the right when the start button is pressed.
When it reaches the rightmost limit, the drive motor reverses and brings the workpiece back to the leftmost position again and the process repeats.
The forward and reverse pushbuttons provides a means of starting the motor in either forward or reverse so that the limit switches can take over automatic control.
Input and Output List of PLC Program for Motor Control
PLC Program
PLC Programming of Motor Forward and Reverse
Program Description
RUNG 0000
Latching rung to operate the system through Master Start and Stop PB.
RUNG 0001
When the workpiece is near Limit switch1, It will enable forward motor, for latching forward Motor is connected in parallel with limit switch 1.
Forward Pushbutton (PB) is also connected in parallel to manually operate forward motor.
RUNG 0002
When the workpiece is near Limit switch2, It will enable reverse motor, for latching reverse Motor is connected in parallel with limit switch 2.
Reverse Pushbutton (PB) is also connected in parallel to manually operate Reverse motor.
Conclusion:
The above-explained process is for example only. It may vary from real-time.
Author: Hema Sundaresan
PLC Sequencer Programming
What is PLC Redundancy?
Encode & Decode Instruction
PLC Program for Motor Starter
JUMP Instruction in PLC Program
Download Free HMI software – CODESYS
Memory Structure of Siemens PLC
Batch Mixing with PLC Ladder Logic Program
Chemical Mixing Process using PLC
3 Comments
  • Rahul says:
    September 9, 2019 at 9:01 am
    write a ladder logic when start switch on a lamp glow continuously. but the same switch is turn on the same lamp blinks on and off.
    How to program this
  • Raja says:
    September 10, 2019 at 2:58 pm
    why fwd & rev motor latched
  • Nahla says:
    November 1, 2022 at 4:41 pm
    I tried to apply this on TIA PORTAL
    CPU : 314C .
    HMI: TP 700 Comfort.
    The CPU SIM works normally with no problem.
    The HMI SIM : It seems to me like there no link between the HMI and the CPU, I made a START button that activates the START input but it’s not working. Knowing that I did the connection between both cpu and hmi.
    What could be the problem, plz ?
How to Create DFB in Schneider PLC? – Derived Function Block
Test and Process Modes in Siemens PLC
Introduction to Functional Block Diagram in Studio 5000
PLC Automatic Irrigation System
Siemens PLC programming: BCD, Integer, Double Integer, Real
Siemens PLC Tia Portal – OB100 Start-up Organization Block
Factory Acceptance Test (FAT) of a PLC Panel
Modbus Poll and Modbus Slave
How to Use Modbus Poll and Modbus Slave Software?
Burning Oven PLC Program
PLC Program for Ceramic Burning Oven Conveyor System
HMI Simulation for PID Controller
PID Controller Output Types – PID_PWM and PID_Output
PLC Motor Logic
Studio 5000 Logix Emulate Controller
How to Create New Project in Studio 5000?
Mitsubishi FX series programming basics
How to Write and Read a Program for Mitsubishi FX3U PLC?
4-20mA Current Loop Components
Why Use a Current Loop?
What is Siemens TDC - Siemens Control System
What is Siemens TDC? – Siemens Control System
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
full-wave-bridge-rectifier-with-voltage-regulator
Basics of Voltage Regulators
Computer Science and Technology Certifications
Computer Science and Technology Majors Certifications
MCQ on Rotating Electrical Machines
PID Controller Types
PID Controllers : Parallel, Ideal & Series
Percentage-to-Process-Variable-Conversion
Formula for Percentage to Process Variable Conversion
Memory Devices Objective Questions – Part 5
Plunger Pump Drive
Too Low Efficiency Torque Converter Elimination Attempt
