Reading: PLC Program to Control a Water Pump
Inst Tools > Blog > PLC Tutorials > PLC Program to Control a Water Pump
PLC program to control a water pump driven by an electric motor. It will be manually started and stopped by pushbutton switches, and shut down automatically by any one of several “permissive” switches.
Last updated: March 4, 2021 11:04 am
PLC Tutorials Practical Questions
3 Min Read
A engineer needs to write a PLC program to control a water pump driven by an electric motor. This water pump will be manually started and stopped by pushbutton switches, and shut down automatically by any one of several “permissive” switches.
The operating statuses of these switches are listed here:
  • Start pushbutton (normally-open): open when unpressed, closed when pressed
  • Stop pushbutton (normally-closed): closed when unpressed, open when pressed
  • Low water level (normally-closed): closed when level is low, open when level is adequate
  • Low oil pressure (normally-open): open when pressure is low, closed when pressure is adequate
  • High vibration (normally-closed): closed when still, open when vibrating
  • Water leak detector (normally-open): open when dry, closed when wet (leak detected)
The engineers’s first attempt is shown here, but it contains a serious error. Identify and correct this error:
Answer :
The Oil_press_low contact instruction should be drawn as normally-open rather than normally-closed as shown in the engineer’s first draft of the PLC program.
The program is designed to shut down the motor if ever the Shutdown bit goes to a 0 state. This means the motor will shut down if any of the permissive contact instructions become uncolored (i.e. fails to “conduct” virtual power).
We have been told that the real-world oil pressure switch is NO, which means its contact opens when oil pressure becomes too low. This means a low oil pressure condition causes that bit to be 0, which necessitates an NO contact instruction so that it will un-color under that condition.
More PLC Questions :
PLC Programming Questions & Answers – 1
PLC Programming Questions & Answers – 2
PLC Programming Questions & Answers – 3
PLC Programming Questions & Answers – 4
PLC Programming Questions & Answers – 5
PLC Programming Questions & Answers – 6
PLC Programming Questions & Answers – 7
How PLC Reads the Data from Field Transmitters
How to Choose the Right Industrial Automation Solution?
Problem on PLC, HMI, VFD, and Motor Circuit
How to Retrieve PLC Project From Memory Card?
Sequential Operation of Output Bits using Two Push buttons
Can SCADA Work Without a PLC? Explained
Problem with Pirani Gauge
Electronic Pressure Sensor with Bourdon Tube and LVDT
PLC Sequencer Instruction with Example
1 to 8 Demultiplexer PLC ladder diagram
What is Recipe Management in SCADA?
Various Types of Delta PLC used in Industrial Automation
PLC Timer Example: Sequential Control of Three Lights with Reset
Steam Eductor Question
PLC Program for Automatic Mixing Controlling in a Tank
Marking Machine
PLC SCL Program for Marking Machine
Programmable Logic Controller (PLC) Questions and Answers – 5
HMI
SCADA
Top 100+ SCADA Questions
PLC analog output card
PLC Analog I/O and Network I/O
Complementary Split Range Control
What is Complementary Split Range Control (CSRC)?
Types of Sensors Used in Automobiles
Analog Input Card Resolution Effects on Accuracy
PLC Analog Input Card Resolution Effects on Accuracy
Power Electronics Filter Quiz
Vortex Flow Meter Animation
PLC Program with 2 Toggle Switches and 4 Motors
Bubbler Level Measurement Animation
Frequency Response MCQ
Bode Plots MCQ
DCS Troubleshooting Control Valve Loop
