Reading: PLC Program for Temperature Control using Thermostat
Inst Tools > Blog > PLC Tutorials > PLC Program for Temperature Control using Thermostat
PLC Temperature Control Programming : In a vessel there are 3 Heaters which are used to control the temperature of the vessel.
Last updated: November 2, 2023 5:00 pm
7 Comments
PLC Temperature Control: In a vessel there are Three Heaters which are used to control the temperature of the vessel.
PLC Temperature Control ProgrammingPLC SolutionPLC Ladder LogicLadder Logic Operation
We are using Three Thermostats to measure the temperature at each heater. also another thermostat for safety shutoff in case of malfunction or emergency or to avoid over temperatures.
All these heaters have different setpoints or different temperature ranges where heaters can be turned ON accordingly (below table shows the temperature ranges).
  1. A temperature control system consists of four thermostats. The system operates three heating units. The thermostats (TS1/TS2/TS3/TS4 are set at 55°C, 60°C, 65°C and 70°C.
  2. Below 55°C temperature, three heaters (H1,H2,H3) are to be in ON state
  3. Between 55°C – 60°C two heaters (H2,H3) are to be in ON state.
  4. Between 60°C – 65°C one heater (H3) is to be in ON state.
  5. Above 70°C all heaters are to be in OFF state, there is a safety shutoff (Relay CR1) in case any heater is operating by mistake.
  6. A master switch turns the system ON and OFF.
PLC Solution
  • There are four thermostats; assume them be in NC state when the set point is not reached.
  • Let there be a control relay (CR1) to work as a safety shutoff.
  • Master Switch : The Start switch is NO and Stop switch NC type.
The below table shows the temperature ranges where Thermostats (TS1,TS2,TS3,TS4) status will be indicated as per the temperature value.
Also the Heaters (H1,H2,H3) status in which either those Heaters will be ON or OFF as per the temperature value.
Temperature Control using PLC ladder logic
PLC Ladder Logic
First Rung:
It has START button (default NO contact) and STOP button (default NC contact). A Relay CR1 is used to control the heaters depending on the thermostats status.
A Thermostat TS4 is connected in between STOP & Relay, if TS4 activated (means TS4 contact changes from NC to NO) then all heaters will be OFF.
An NO contact of Relay CR1 is used across the START button in order to latch or hold the START command.
Second Rung:
An NO contact of Relay CR1 is used to control the Heaters (H1,H2,H3) with the thermostats (TS1,TS2,TS3) status.
After giving START command, This NO contact becomes NC contact. if temperature below 55 Deg C, TS1, TS2 & TS3 will be in Close Status so all heaters will be ON.
if Temperature is in between 55 to 60 Deg C, Then TS1 will be Open, so Heater H1 will be OFF.
then, if temperature in between 60 to 65 Deg C then TS2 also be Open, so Heater H2 will be OFF
if temperature in between 65 to 70 Deg C then TS3 also be Open, so Heater H3 will be OFF
There is a safety Shutoff which is used to avoid any malfunctions of Thermostats or to avoid over temperatures.
if temperature reaches above 70 Deg C then TS4 will activates and de-energizes the Relay, thus all Heaters will be turned OFF.
Note : Here Heaters H1, H2, H3 are either Relays or Contactors we energizing. so an NO contact of these relays are connected to Electrical Heater feeder circuits (MCC).These Electrical Feeder circuits will be controlled as per these signals and accordingly the heaters will be either ON or OFF.
  • PLC Programming languages
  • PLC Training Software Download
  • Mitsubishi PLC Programming
  • PLC Sequence Programming
  • RSLogix 5000 PLC Programming
PLC SCL Program for Marking Machine
Raw Counts to Engineering Units : Conversion Formula
Latched and Momentary Operation of Motor PLC Program
STL Programming – SET, RESET, ASSIGN
Schneider PLC Programming Example for Beginners
Basic Pumping System Application Used in Industrial Automation
7 Comments
  • azetou says:
    July 13, 2017 at 11:57 am
    Your program is incomplete : when the temperature goes above 70°C, all heaters will go off, consequently the temperature goes down. if the operator doesn’t press the start button again, all heaters will remain off!!! the process is not fully automated. The program can be improved. Am I right ?
    • S Bharadwaj Reddy says:
      July 13, 2017 at 1:42 pm
      Hi, if we need auto start then we can add (Optional). Ladder logic will be as per our objective which is mentioned in the post. Note : These programs are only for reference purpose or to understand the basic concept. The practical ladder logic will be different, it may include safety related inputs, some interlocks, some machine protection related inputs, also based on our application, requirements etc. Personally, I feel any logic can be improved. There is No End to the upgrades. Its all depends on us. Thanks
  • Benjamin Kaul says:
    January 8, 2019 at 4:07 am
    Great notes Bharadwaj Reddy
  • sinan says:
    April 14, 2020 at 11:34 pm
    Example logic is wrong
  • Ankit kumar says:
    January 13, 2021 at 12:15 pm
    Send me analog program of this circuit
    • nita says:
      July 4, 2024 at 10:39 am
      yeah,i need it
  • hossein ahmadi says:
    January 14, 2021 at 6:33 am
    hi
    i have a question
    suppose we have redundant cpu in a plc
    one is run and another has stopped
    we change damaged cpu with a new one that program is downloaded to it but i/o of this cpu is reseted
    if we put this cpu instead of damaged cpu
    i/o signal should be read from run cpu
    is it ok?
    can reseted i/o on new cpu be a problem and set i/o to zero?
PLC Programming Example for Motor Forward and Reverse Control
PLC Program for Entry and Exit Control of Car Parking
What are High-Speed Inputs in PLC?
Modbus Communication between PLC and Energy Meter
How to use Masked Move Instruction in PLC
How to Operate a Group of Induction Motors using PLC Logic?
Difference Between CompactLogix and ControlLogix
PLC based Automatic Bell System
PLC based Automatic Bell System for a School
Programmable Logic Controller (PLC)
What is Interposing Relay in a PLC System ?
PLC Control for Baking Machines Logic
PLC Programming for Baking with Auto and Manual Modes
LIFO Instruction in Allen Bradley PLC Programming
LIFO Instruction in PLC
How to Train Your Maintenance Team for Industrial Automation Systems
Difference Between Wifi and Industrial Wireless
PLC Program for Valves
PLC Pump Permissive Interlocks
LCS Configuration equipped with LOTO Facility
Tank Level Detection Switches
Fail Safe Switch Circuit
Basics of Fail-safe Circuits
Annubar Flow Meter Principle
Annubar Flow Meter – Principle, Advantages, Disadvantages
Flash Vessel All Level Instruments Stopped Working
Ammonia Flash Vessel All Level Instruments Stopped Working
Interference Immunity (EMC)
PLC Program
PLC Program to Heat and Bend Glass Tubes
An Indian Plants all turbines’ low Vacuum
An Indian Plants all turbines’ low Vacuum & Saudi Plant turbo-compressor only
Stability in Frequency Domain
Mathematical Preliminaries
