Reading: PLC Program for Sequential Motor Control
Inst Tools > Blog > Guest Articles > PLC Program for Sequential Motor Control
PLC Ladder Logic for Sequential Motor Control. Study about PLC Motor Programming tutorials and implement PLC Ladder Logic for the Motor application.
Last updated: November 3, 2023 10:37 am
Guest Articles PLC Tutorials
This is the PLC Program for Sequential Motor Operating System.
Sequential Motor ControlProblem DiagramProblem SolutionList of Inputs & OutputPLC Ladder Diagram for Sequential Motor ControlLadder Logic ExplainedRuntime Test Cases
Problem Description
In many industries, there are lots of motors are used. Sometimes we need to start more than one motor in an application.
When we have a low incoming power supply rating, then there is a chance the incoming MCB will trip when one or more motors will START in parallel because they will consume more power.
Here we will consider one similar example where we START each motor one by one.
Problem Diagram
Problem Solution
The problem can be solved by using PLC programming or relay logic.
In this case, we have to operate motors sequentially. There are total 3 motors to be controlled in a sequence. so that each motor will start sequentially, say Motor 1 will START then after some delay then motor 2 will start and after some delay motor 3 will start.
So that whole operation will take 10 seconds to start all motors in a sequence. By providing this delay we can avoid the problem of taking large
current by motors during initial stat up.
All motors will be operate in the sequence and 5 seconds time delay is to be provided between operations of each motor.
Here will write logic for sequential operation for motors using PLC.
Inputs List
  • Start PB : I0.0
  • Stop PB: I0.1
Outputs List
  • Cycle on : Q0.0
  • Motor 1: Q0.1
  • Motor 2 : Q0.2
  • Motor 3 : Q0.3
PLC Sequential Motor Control
In this application, we used Siemens S7-1200 PLC and TIA Portal Software for programming. We can also design this logic with relay circuit.
Network 1:
In Network 1, we wrote logic for cycle ON condition. Here cycle ON (Q0.0) lamp will indicate cycle status. Cycle can be started by pressing START PB (I0.0) push button and can be Stopped by pressing STOP PB (I0.1) push button.
When cycle will be ON, at same time Motor 1(Q0.1) will be Started. And at the same time, timer instruction will be executed.
Network 2:
In Network 2, the NO contact of Motor 1  starts Timer T1  and when Timer for Motor 2 (Q0.1) will reach the set value 5 seconds. Then NO contact of the T1 will START the Motor 2 (Q0.1).
Network 3:
In Network 3. we have taken logic for motor 3. Here we have given NO contact of motor 2 for starting the timer of motor 3. When T2 will reach the set value 5s , the NO contact of the T2 will START the Motor 3(Q0.0).
When STOP PB (I0.1) will be pressed then NC contact will be activated which makes Cycle (Q0.0) OFF. And also motor 2 and 3 will stop working.
Runtime Test Cases
Note: The above PLC Logic provided for basic idea about application of PLC in Sequential Motor Control. The Logic is limited and not complete application.
Author: Bhavesh
  • PLC Controls a Valve
  • Scaling for PLC Input
  • PLC Quesstions
  • DCS versus PLC
  • PLC Paint Spraying
Various Types of Delta PLC used in Industrial Automation
Circular Chart Recorder Calibration Procedure
Advanced Skills Required for a PLC Programmer to Get a Job
PLC Programming for Traffic Barrier Control
Difference Between FC and FB in Tia Portal
  • mouyed alassadi says:
    March 25, 2019 at 12:49 am
    thank for INST TOOL program
What is an RTU? – Remote Terminal Unit
How to Create Faceplate in FactoryTalk View Studio?
What is Interposing Relay in a PLC System ?
Single-Acting Cylinder Control using Proximity Sensor
How to Use ModScan Software for Testing Modbus Communication?
How to Program a Star-Delta System using 1 Button in PLC?
Tia Portal – OB10 Time of Day Interrupt Organization Block
Free SCADA Training Course
SCADA Standards
SCADA for Substation Automation
PLC Sequential Lights Control Example
PLC Timer Example: Sequential Control of Three Lights with Reset
PLC Programming Example with Pushbutton and Motor
Siemens PLC-to-PLC Communication Project
Automatic Lamp Control in Storage Facility
Ladder Logic Counters Instruction
Up Counter PLC Program
Parameters of SRT_DINT instruction
Tia Portal – OB20 Time Delay Interrupt Organization Block
Automated Test Bench - Complex PLC Programming Examples
Automated Test Bench – Complex PLC Programming Examples
Transit Time flow meter Theory
Transit Time Flow Meter Principle
Automatic Motor Forward and Reverse Control using Timer
Difference-between-pneumatic-electric-hydraulic-actuators
Difference between Pneumatic, Electrical & Hydraulic Actuators
Differential Pressure Flow Meters
Short Notes on Differential Pressure Flow Meters
Gate Valve Parts
What is Gate Valve ?
Scintillation Counter Theory
Scintillation Counter Principle
Bernoulli's Principle
Bernoulli’s Principle and Equation – Flow Measurement
