Reading: PLC Program for Continuous Filling Operation
Inst Tools > Blog > PLC Tutorials > PLC Program for Continuous Filling Operation
PLC Program: A Continuous Filling Operation requires boxes moving on a conveyor to be automatically positioned and filled.
Last updated: November 2, 2023 5:00 pm
3 Comments
6 Min Read
PLC Program : A Continuous Filling Operation requires boxes moving on a conveyor to be automatically positioned and filled.
PLC Program for Continuous Filling OperationPurposePLC LogicExplanation
PLC Program for Filling Operation
Purpose
Solenoid : To control the product filling from the hooper. Solenoid will be activated after the box positioned (proximity switch activation) and again de-activates after the level switch activated (level full).
Level Switch : To detect the product level in the filling box.
Proximity Switch : To position the box exactly below the hooper.
Motor : To run the conveyor such that the box will move accordingly.
Local Control Panel : it has START & STOP buttons used to control the sequence.
Indication Panel : It displays the plant/batch status. Status signals are Run/Stand By/Full.
PLC Logic
PLC Bottle Filling Ladder Logic
The below are the default positions :
  • STOP Switch : Normally Close (NC)
  • START Switch : Normally Open (NO)
  • Proximity Switch : Normally Open (NO)
  • Level Switch : Normally Open (NO)
Note : In ladder logic we can use either NO or NC contacts as default of proximity & level switch as required. if we use NO then it becomes NC after switch activated. if we use NC then it becomes NO after switch activated.
Explanation
Here we have 5 rungs / complete lines in the above ladder logic.
First Rung:
It has STOP, START & RUN Indication. STOP default NC, START is NO, when we press START command then both STOP & START are NC so the output RUN will be activated.
RUN Indication will be displayed in indication panel. As START is a push button which generates a momentary command only.
So we use a logical NO contact from RUN output. when RUN is activated, the NO becomes NC and Holds/latches the START command and RUN will be continuously activated even though START signal is lost as it is momentary type.
Second Rung:
it is used to indicate STAND BY signal status in the indicator panel. RUN indication NC contact is connected to STANDBY.
so when RUN signal activated or process started then NC becomes NO and STAND BY indication will be disabled. if it is not running then stand by will be activated.
Third Rung:
it is used to indicate FULL signal status in the indicator panel. when level switch & proximity switch are activated then NO contacts will become NC and FULL signal status will be enabled.
Fourth Rung:
It is used to control the Motor either START/STOP. Proximity switch NC contact is used & RUN signal NO contact is used here to control the Motor.
so when we press START button, the RUN will be activated ( as discussed in First Rung ) so RUN signal NO contact will becomes NC.
Both proximity & RUN signals are enabled/healthy then Motor will be started and conveyor will start running and box/package will start move.
once the box reached before Hooper then proximity switch will be activated. So proximity switch NC contact becomes NO, so Motor will be stopped immediately.
After filling, the box has to move again and to reach other side. so here we use level switch NO contact across proximity switch.
When Filling completed, Level switch contact changes from NO to NC, so again the motor starts and moves the box to other end.
Fifth Rung:
It is used to control the solenoid valve operation. If solenoid activated then it starts filling the box and if solenoid valve de-activates then the filling will be stopped.
Here we mainly use RUN signal NO contact, Level Switch NC contact, Proximity NO contact to control the solenoid valve.
Solenoid valve will be activated when START command is given ( RUN signal NO contact becomes NC), when level is Zero (Level switch NC contact used as default here ), when Box is placed under the hooper ( proximity switch NO contact used.
so when box arrives under hooper, NO contact becomes NC ) , after all the logics are healthy then solenoid valve will be activated and starts filling.
if level reaches 100% then level switch will become NO and thus stopping the filling by de-activating the solenoid valve.  We used proximity switch here because the filling has to be started when the box placed in correct position.
After filling the box move out and filling again will start when next box comes under Hooper.
  • PLC Program for Conveyor Motor
  • 3 Phase Motor Control using PLC
  • PLC Tank Heating Control
  • Basics of Limit switches
  • Switch Types
Types of Limit Switches – Principle, Advantages, Disadvantages
Batch Simulator PLC Example Program using LogixPro Simulator
Ladder Logic Programming Examples
3 Comments
  • Khalid Hussein says:
    July 17, 2021 at 11:50 pm
    Wrong ladder logic.
    —-I/I—-I/I—–( )-
    Prox.s
  • helal basho says:
    November 23, 2021 at 6:36 pm
    – How can ” when Box is placed under the hooper ” ???
    – Is this system is fully automatic after turning it on from local control panel ???
  • Simiey says:
    October 4, 2022 at 1:14 am
    I believe that there is more than one way to solve this.
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
Schneider Electric: Car Parking System with Calculations in PLC
PLC Automatic Door Control System – Programming Example
How to Use Analog Input in Mitsubishi FX3U LOLLETTE PLC?
How to do Force in GE PLC Proficy Machine Edition?
PLC Programming Videos
PLC Compressor Control Ladder Logic
Studio 5000 Programming Three Motors with Fixed Priorities
Studio 5000: Programming Three Motors with Fixed Priorities
Why 4-20 mA Current Signal is used instead of Voltage Signal
Emergency Stop Push button
A Typical Sequential Function Chart
What is Sequential Function Chart (SFC?)
Water Treatment Plant SCADA
Typical HMI Screen Design for Water Treatment Plant
PLC Program for Counting Objects on Conveyor
PLC Program for Counting Moving Objects on Conveyor
Features of Scada Which are Must in an IoT System
Basic Pneumatic System
Pneumatic Handbook
compressor emergency shutdown system
Solenoid Valves Questions & Answers – 2
Pressure Gauge pulsation damping
Pressure Gauge Pulsation Damping
Elevator PLC Ladder Logic
Hydrostatic interface level measurement Formula
Hydrostatic Interface Level Measurement
Digital Electronics Objective Questions – Set 3
Infrared Temperature Calibrators
Different Types of Temperature Calibrators
Thermowell Design Guidelines
