Reading: PLC Automatic Door Control System – Programming Example
Inst Tools > Blog > PLC Tutorials > PLC Automatic Door Control System – Programming Example
This is a PLC Program for an automatic door control system. Learn PLC programming with example problems for students.
Last updated: November 3, 2023 1:50 pm
3 Min Read
Automatic Door ControlProblem DiagramProblem SolutionList of inputs/outputsPLC Programming for Automatic Door Control SystemProgram DescriptionResult
Problem Description
Implement logic for the automatic door open & close system in PLC using ladder diagram programming language.
Problem Diagram
PLC Program for Automatic Door Control System
Problem Solution
We will use PLC S7-300 for this application. Also we will use TIA portal software for programming.
In this system when someone enters the infrared sensing field, opening motor starts working to open the door automatically till the door touches the door opening limit switch.
If the door touches the opening limit switch for 8sec and no body enters the sensing field/area, then closing motor starts to close the door automatically till the door touches the closing limit switch.
Stop the closing action immediately if someone enters the sensing field during the door closing process.
List of inputs
  • Infrared sensor :- I0.0
  • Closing limit switch :- I0.1
  • Opening limit switch :- I0.2
List of outputs
  • Opening motor :- Q0.0
  • Closing motor :- Q0.1
PLC Ladder Logic for Automatic Door Control
Program Description
For this application we used S7-300 PLC and TIA portal software for programming.
Network 1:
When infrared sensor is detected (I0.0), door opening motor (Q0.0) will start. The door will be open. When it touches the close limit switch (I0.1), opening motor will be stop.
Network 2:
When the door touches the opening limit switch (I0.2), timer will be executed.
Network 3:
After 8sec time closing motor (Q0.1) will start. When it touches the closing limit switch, closing motor (Q0.1) will turn OFF.
Note :- Above application may be different from actual application. This example is only for explanation purpose only. We can implement this logic in other PLC also. This is the simple concept of automatic door open and close application, we can use this concept in other examples also.
All parameters considered in example are for explanation purpose only, parameters may be different in actual applications. Also all interlocks are not considered in the application.
Result
PLC Door Opening
Author: Bhavesh
  • Motor Starter PLC Logic
  • PLC Fan Control Unit System
  • PLC Oil and Water Separation Process
  • RSLogix5000 PLC Program Backup
  • What is a Limit Switch?
Check Block Consistency Tools in Simatic Manager
Pulse Timer Instruction in PLC Programming
Delta PLC Counter with Comparison
PLC Logic for Automatic Bending Machine for Exhaust Pipe
  • Vaibhavi says:
    November 28, 2022 at 5:44 pm
    Plc based ac motor control system
    Please give this project
PLC Programming Course Online Free
What is Marshalling Cabinet?
Configuring and Usage of Cyclic Interrupts TIA Portal (OB 30+)
PLC Trainer Demo Download
What is Interposing Relay in a PLC System ?
Jump Instruction in Siemens Tia Portal
PLC Emergency Stop Example Program
Automatic exhaust fan control
XG5000 PLC Programming for Automatic Exhaust Fan
Track PLC Operating Modes
#2 PLC Best Practices – Track Operating Modes
Siemens PLC
Will PLCs become obsolete?
CPU Communication Ports in Siemens PLC
Types of CPU Communication Ports in Siemens PLC
SCADA
Top 100+ SCADA Questions
Two wire loop powered transmitters
Example of PID Control Instruction
How to Configure PID in Siemens PLC?
Lamp Counter Logic
Function Block (FB) for Motor Control Logic
PLC PID tuning parameters
COCO Simulator
COCO Simulator: Free Process Simulation Software
Fire and Gas System Interview Questions & Answers
Types of Transfomer Cooling Methods
Multi Way Switches using PLC
Making Multi Way Switches using PLC
solenoid-valves-types-principle-animation
Solenoid Valves Types, Principle & Animation
Micro-impulse Level Transmitter Principle
conductivity transmitter
Conductivity Transmitter Calibration Procedure
