Reading: PLC Latching Function
Inst Tools > Blog > PLC Tutorials > PLC Latching Function
PLC Latching function is a self-maintaining circuit in that, after being energized, it maintains that state until another input is received.
Last updated: November 2, 2023 2:33 pm
3 Min Read
There are often situations where it is necessary to hold an output energized, even when the input ceases.
A simple example of such a situation is a motor, which is started by pressing a push button switch. Though the switch contacts do not remain closed, the motor is required to continue running until a stop push button switch is pressed.
The term latch circuit is used for the circuit used to carry out such an operation. It is a self-maintaining circuit in that, after being energized, it maintains that state until another input is received.
An example of a latch circuit is shown in Figure 1.18. When the input A contacts close, there is an output. However, when there is an output, another set of contacts associated with the output closes.
These contacts form an OR logic gate system with the input contacts. Thus, even if the input A opens, the circuit will still maintain the output energized. The only way to release the output is by operating the normally closed contact B.
Also Read: PLC Logic Functions
As an illustration of the application of a latching circuit, consider a motor controlled by stop and start push button switches and for which one signal light must be illuminated when the power is applied to the motor and another when it is not applied.
Figure 1.19 shows the ladder diagram with Mitsubishi notation for the addresses.
PLC Motor Logic Application
Note that  the stop contacts  X401 are shown as being programmed as open.  If the stop  switch used is normally closed then X401 receives a start-up signal to close. This gives a safer operation than  programming  X401 as normally closed.
X401 is closed when the program is started. When X400 is momentarily closed, Y430 is energized and its contacts close. This results in latching and also the switching off of Y431 and the switching on of Y432.
To switch the motor off, X401 is pressed and opens. Y430 contacts open in the top rung and third rung, but close in the second rung. Thus Y431 comes on and Y432 off.
Latching is widely used with start-ups so that the initial switch on of an application becomes latched on.
Also Read: Introduction to PLC Ladder Diagrams
  • Latches Objective Questions
  • Solenoid Operated Valves and Latching Valves
  • D Latch
  • PLC Motor Logic with START, STOP, TEST Push buttons
  • Concept of Latching in PLC
DCS Commissioning Steps
Best 100 PLC Projects for Final Year Engineering Students
ON and OFF a Group of Outputs by One Push button PLC Logic
PLC Example on Manufacturing Line Assembly
What is Sequential Function Chart (SFC?)
What is Process Control?
Studio 5000 Tutorial: PLC Programming for Digital Alarms
PLC Programming Projects for Beginners
PLC Programming for Weight-Based Packaging
Vijeo Designer software – Import and Export
PLC Digital Input and Digital Output Modules
Raw Counts to Engineering Units : Conversion Formula
Masking in PLC
What is Masking in PLC?
Introduction to GOC controllers
Mitsubishi Electric GOC Controllers
Power Supply Sizing for Industrial Automation Systems
Edge Detection in PLC
Edge Detection in PLC Programming
how-a-plc-do-the-scaling-for-a-sensor
How a PLC do the Scaling for a Sensor ?
How to Choose a PLC
How to Choose a PLC for New Project? – Criteria for Selection of PLC
Structured Text Automatic Gate Logic
Structured Text PLC Programming for Automatic Gate Control
Top 100 Electrical Machines Projects for Electrical Engineers
Motor Stop Interlock for Changing the Direction PLC Program
What is an Electrical Drive
What is an Electrical Drive? Types, Advantages, Disadvantages
Integral (Reset) Control Theory
Difference Between AIS and GIS Panels
DC Generator
DC Generator
