Reading: #14 PLC Best Practices – Restrict Third-party Data Interfaces
Inst Tools > Blog > PLC Tutorials > #14 PLC Best Practices – Restrict Third-party Data Interfaces
Restrict the type of PLC connections and available data for third-party data interfaces in a programmable logic controller,
Last updated: September 22, 2021 5:50 pm
Restrict the type of connections and available data for 3rd party interfaces. The connections and/or data interfaces should be well defined and restricted to only allow read/write capabilities for the required data transfer.
Restrict Third-party Data Interfaces in PLCExample
Security ObjectiveTarget Group
HardeningIntegration / Maintenance Service Provider
In some cases, due to long cable runs or a large exchange of data, interfaced data connections present a better business case than hard-wired data exchange between two separate parties.
The following guidelines should be considered and followed where practical when designing and implementing a third-party data exchange interface:
Use a dedicated communications module, either directly connected to the 3rd party PLC or data exchange equipment or use dedicated network equipment physically segregated from each party’s core network.
The MAC address of connected devices is typically available in system variables for any ICS Ethernet-enabled device, making it possible to verify device identity with a multi-factor approach (IP address + MAC maker code = trusted device).
This practice is certainly not fool-proof, as MAC & IP addresses can be spoofed, but it serves to raise the bar in terms of communications between trusted ICS systems and devices.
When selecting a protocol for 3rd party interfaces, choose a protocol which minimizes the ability of the third party to write data to the owner’s system.
Choose a connection method and connection port which prevents the 3rd party from being able to configure the owner’s PLC or data exchange equipment.
The third-party should not be able to read or write to any data that has not been explicitly defined and made available.
 Use a watchdog timer for monitoring communication so that commands are not sent to a PLC in fault mode.
Serial Connection: Use a dedicated communication module for each 3rd party interface with a restricted array of data. Ensure the owner’s side of the connection is the Initiator and that the third party is the Responder.
Ethernet/IP: Some PLCs allow for communication modules to function as a firewall and can perform Deep Packet Inspection (DPI), or restrict communication module interfaces to limit the data exchange to a predefined subset. If these features are available, and an Ethernet/IP protocol is in use, ensure the features are enabled and configured.
When operational or contractual requirements prevent the owner from accomplishing the previous items, consider using a separate “data concentrator” (aka proxy/DMZ) PLC in order to buffer the data and protect the owner from unwanted writes/programming from the 3rd party. Ensure the backplane of this PLC cannot be traversed from the 3rd party network.
Types of PLC
Example
Pipeline or Lease Automatic Custody Transfer (LACT) units which transfer and meter hydrocarbons or water exchanged between an upstream producing or pipeline company and a midstream pipeline company with network or serial interfaced connections sharing metering, state, and permissive information between companies.
Regional potable water purveyor (importer) sharing turnout water flow rate being delivered to a local municipality’s water plant.
Why?
Beneficial for…?Why?
  Security1. Limit the exposure to 3rd party networks and equipment.
2. Authenticate external devices to prevent spoofing.
  ReliabilityLimits the ability for intentional or unintentional modifications or access from 3rd party locations or equipment.
Maintenance
References
Standard/frameworkMapping
  MITRE ATT&CK ICSTactic:  TA010 – Impair Process Control
Technique:  T0836 – Modify Parameter
  ISA 62443-3-3SR 7.6: Network and security configuration settings
SR 7.7: Least functionality
  ISA 62443-4-2CR 7.6: Network and security configuration settings
CR 7.7: Least functionality
  ISA 62443-4-1SD-4: Secure design best practices
SI-1: Security implementation review
SVV-1: Security requirements testing
Source: PLC Security
What is 21 CFR in SCADA and HMI Systems?
PLC Automatic Irrigation System
Control Speed of Induction Motor using Analog Output of PLC
PLC based Drink Dispenser System
Sequential PLC Programming for the Pneumatic Valves
Normally-open and Normally-closed Switch Contacts
PLC System Documentation
FB Block in Siemens PLC Programming
PLC Logic for Automatic Bending Machine for Exhaust Pipe
What is an Instruction List? – PLC Programming
PLC program for Sorting System by Size Example
PLC Based Product Sorting Machine System – Lift Control
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
Connecting Faceplates to PLC Project
Connecting Faceplate to PLC Project – HMI Tutorial
Timer-based vacuum cleaner in Schneider PLC
Schneider Electric PLC Timer Problem: Vacuum Cleaner
Two Hand Control Logic
Two Hand Control Logic using PLC
Allen Bradley SLC 500 PLC Programming
Relay Internal Parts
Relay Operation, Types, Symbols & Characteristics
Difference Between Circuit Breaker and Disconnector
FMCW Radar level transmitter Working Principle
FMCW Radar Level Transmitter Working Principle
PID Control Theory
Overview of PID Control terms
Two Differential Pressure Transmitters
Pressure Level Transmitter Problems
Pole Placement by State Feedback
What is Profibus
All About Fieldbus Protocols
Which instrument is faulty
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Instruments Tapping Points
