Reading: Pitot Tube Working Principle
Inst Tools > Blog > Animation > Pitot Tube Working Principle
Pitot Tube measures the difference between total pressure and static pressure and it is converted into a proportional flow rate.
Last updated: October 31, 2023 3:07 pm
Animation Flow Measurement
2 Comments
6 Min Read
The Pitot tube is named after Henri Pitot who used a bent glass tube to measure velocities in a river in France in the 1700s. Pitot tubes can be very simple devices with no moving parts used to measure flow velocities.
Pitot TubeAveraging Pitot tubeAdvantages of the Pitot tubeDisadvantages of the Pitot tubeApplications for the Pitot tube
Pitot tubes are a common type of insertion flowmeter. The below animation shows the basics for a Pitot tube, where pressure is generated in a tube facing the flow, by the velocity of the fluid.
This ‘velocity’ pressure is compared against the reference pressure (or static pressure) in the pipe, and the velocity can be determined by applying a simple equation.
Pitot Tube
Pitot Tube Working Principle Animation
Note: In Animation from right to left: The tube inserted in the center of the pipe is used to measure Total Pressure and the next second tube is used to measure the static pressure.
When the flow rate through the pipe changes, the pressures at the total pressure tube and static pressure tube vary with respect to the flow velocities. The difference between the total pressure and static pressure is used to measure the proportional flow rate passing through the pipe.
A DP-type transmitter is used to measure the difference between total pressure and static pressure and it is converted into a proportional flow rate.
Pitot Tube Flow Meter
In practice, two tubes inserted into a pipe would be cumbersome, and a simple Pitot tube will consist of one unit as shown in the Below Figure. Here, the hole measuring the velocity pressure and the holes measuring the reference or static pressure are incorporated into the same device.
Pitot Tube Installation
Because the simple Pitot tube (Above Figure ) only samples a single point, and, because the flow profile of the fluid (and hence velocity profile) varies across the pipe, accurate placement of the nozzle is critical. To avoid this type of problem we are using averaging pitot tubes.
Note that a square root relationship exists between velocity and pressure drop (see Below Equation). This limits the accuracy to a small turndown range.
Pitot Tube Calculation Formula
Where:
u1 =The fluid velocity in the pipe
Δp =Dynamic pressure – Static pressure
ρ =Density
There are some practical limitations to the use of a pitot-static tube:
  1. If the velocity is low, the difference in pressures is very small and hard to accurately measure with the transducer. Errors in the instrument could be greater than the measurement! So pitot-static tubes don’t work very well for very low velocities.
  2. If the velocity is very high (supersonic), we’ve violated the assumptions of Bernoulli’s equation and the measurement is wrong again. At the front of the tube, a shock wave appears that will change the total pressure. There are corrections for the shock wave that can be applied to allow us to use pitot-static tubes for high-speed aircraft.
  3. If the tubes become clogged or pinched, the resulting pressures at the transducer are not the total and static pressures of the external flow. The transducer output is then used to calculate a velocity that is not the actual velocity of the flow.
The averaging Pitot tube (Below Figure) was developed with a number of upstream sensing tubes to overcome the problems associated with correctly siting the simple type of Pitot tube.
These sensing tubes sense various velocity pressures across the pipe, which are then averaged within the tube assembly to give a representative flow rate of the whole cross-section.
Averaging Pitot Tube Working Principle
  • Presents little resistance to flow.
  • Inexpensive to buy.
  • Simple types can be used on different-diameter pipes.
  • Turndown is limited to approximately 4:1 by the square root relationship between pressure and velocity.
  • If steam is wet, the bottom holes can become effectively blocked. To counter this, some models can be installed horizontally.
  • Sensitive to changes in turbulence and needs careful installation and maintenance.
  • The low pressure drop measured by the unit, increases uncertainty, especially on steam.
  • Placement inside the pipework is critical.
  • Occasional use to provide an indication of flow rate
  • Determining the range over which a more appropriate steam flow meter may be used.
Reference: spiraxsarco
  • Coriolis Meter Construction
  • Optical flow meter Principle
  • Doppler Ultrasonic Meter
  • Turbine Flow Meter Theory
  • What is a Thermal Mass Meter
Laminar Flow Meter Working Principle
V Cone Flow Meter – Principle, Advantages, Disadvantages
Solenoid Valves Types, Principle & Animation
Flow Transmitters Questions and Answers – Instruments Test
PID Controller Gains Effect on Manipulated Variable
Capacitance Level Transmitter Animation
2 Comments
  • AYON BHOWMIK says:
    June 3, 2016 at 5:01 pm
    Thank you sir for the article , it really helped a lot to clear the concept.
  • GOURI SHANKAR PATTNAIK says:
    November 10, 2016 at 6:59 pm
    Thanks sir
MOS Type Gas Sensor Principle
What is Water Cut Meter?
Logic Gates Animation
DP type Flow Transmitter Preventive Maintenance and Calibration
How to Read Circular Chart Recorder for Flow Measurement?
Area Velocity Flow Meter Principle
Factors Affecting the Performance of Ultrasonic Flow Meters
Why Viscosity is Not Included in the Orifice Equation?
Advantages and Disadvantages of Flow Measurement Techniques
Advantages & Disadvantages of Different Flow Meters
What is Averaging Pitot Tube
What is an Averaging Pitot Tube? – Principle, Advantages
Vortex Flow GIF
Working Principle of Vortex Flow Meter
Relay Wiring
vortex flow transmitter
What is a Vortex Flow Meter?
Valve Basics
Basics of Control Valves
Online Simulation
Orifice Flow Measurement Formula
Basics of Flow Measurement
Resistance Temperature Detectors Troubleshooting Tips
Choke Input Filter Operation
Digital Electronics Objective Questions – Set 5
Retentive ON delay timer using PLC Logic
Retentive ON Delay Timer using PLC
DP-Transmitter-with-two-seals
DP Transmitter with Two Seals applications
Drum Level Compensation of DP Transmitter
Drum Level Compensation and Range Calculation of DP Transmitter
Frequency Response MCQ
Bode Plots MCQ
Classification of Fuses
Step-by-Step Guide to Choose Right Fuse for a Panel
