Reading: Piping and Instrumentation Drawing (P&ID) Tutorials – Part 4
Inst Tools > Blog > Common > Piping and Instrumentation Drawing (P&ID) Tutorials – Part 4
Last updated: January 21, 2020 12:13 pm
Common
Reading Engineering P&IDs
Standards and conventions have been developed to provide consistency from drawing to drawing. To accurately interpret a drawing, these standards and conventions must be understood.
Standards and Conventions for Valve Status
Before a diagram or print can be properly read and understood, the basic conventions used by P&IDs to denote valve positions and failure modes must be understood. The reader must be able to determine the valve position, know if this position is normal, know how the valve will fail, and in some cases know if the valve is normally locked in that position.
Figure 17 illustrates the symbols used to indicate valve status. Unless otherwise stated, P&IDs indicate valves in their “normal” position. This is usually interpreted as the normal or primary flowpath for the system. An exception is safety systems, which are normally shown in their standby or non-accident condition.
P & ID Valve Status Symbols
Figure 17 : Valve Status Symbols
3-way valves are sometimes drawn in the position that they will fail to instead of always being drawn in their “normal” position. This will either be defined as the standard by the system of drawings or noted in some manner on the individual drawings.
P&ID Document Reading Example
Example : At this point, all the symbols for valves and major components have been presented, as have the conventions for identifying the condition of a system.
Refer to Figure 18 as necessary to answer the following questions. The answers are provided in the back of this section so that you may judge your own knowledge level.
Example P&ID
Figure 18 : Exercise P&ID
1. Identify the following components by letter or number.
  • a. Centrifugal pump
  • b. Heat exchanger
  • c. Tank
  • d. Venturi
  • e. Rupture disc
  • f. Relief valve
  • g. Motor-operated valve
  • h. Air-operated valve
  • i. Throttle valve
  • j. Conductivity cell
  • k. Air line
  • l. Current-to-pneumatic converter
  • m. Check valve
  • n. A locked-closed valve
  • o. A closed valve
  • p. A locked-open valve
  • q. A solenoid valve
2. What is the controlling parameter for Valves 10 and 21?
3. Which valves would need to change position in order for Pump B to supply flow to only points G and H?
4. Which valves will fail open? Fail closed? Fail as is?
Answers :
1.
  • a. A or B
  • b. C or D
  • c. E
  • d. 31
  • e. 1
  • f. 8 or 17
  • g. 2,3,7 or 16
  • h. 10, 21
  • i. 12 or 24
  • j. 26
  • k. 32
  • l. 28
  • m. 5 or 14
  • n. 18 or 19
  • o. 18 or 19
  • p. 4
  • q. 11 or 23
2. Temperature as sensed by the temperature elements (TE)
3.
  • Open 18 and/or 19,
  • Shut 13 and 25
4.
  • Fail Open: 2 and 3
  • Fail Closed: 10 and 21
  • Fail as is: 7 and 16
Dew Point in Instrument Air
Instrumentation Loop Diagrams
What is Linear Electric Motor?
Instrumentation documents
Difference between Electron and Proton
What are Micro Electro-Mechanical Systems (MEMS)?
What is a Vent Filter? – Water Treatment Plant
How to Use a Paint Thickness Gauge?
Working of Air Compressor – Types – Control Techniques
Moving Magnet Type Velocity Transducer
What are the Advantages & Disadvantages of CNC Milling?
Advancements in Lime Slaking Technology: What’s New And What’s Next
Batch Type Centrifugal Automation in Sugar Industries
How to Achieve Sustainability in UX Design and Make a Difference?
Pilot Operated Back Pressure Regulator Valve
Types of Sensors Used in Automobiles
2 wire transmitter current loops
6 Pieces of Essential Equipment For PCB Assembly
What is Shielded Twisted Pair Cable
What is Shielded Twisted Pair Cable? – Advantages, Disadvantages
CNC Programming - Definition, Types, and Tips
CNC Programming – Definition, Types, and Tips
HART
List of Tools used by Instrument Technician or Engineer
Career Opportunities and Scope in Industrial Automation
Active Barrier
What is a Active Barrier ?
Motor Protection Relay
Motor Protection Circuits
Four Wire Current Loop
4-wire Transmitters Current Loops
Wrong Orifice Installation
How Not to Install an Instrument and Wrong Practices
PLC Program for Two ways switch logic for staircase light
PLC Program for Two Way Switch Logic
As-Interface Protocol Overview
AS-interface and DeviceNet Communication
Comparison of Level Meters - Level Measurement Instruments
Comparison of Level Meters – Level Measurement Instruments
Fieldbus Terminator
What is a Fieldbus Terminator and How Does it Work?
