Reading: Pilot-operated Safety and Relief Valves
Inst Tools > Blog > Control Valves > Pilot-operated Safety and Relief Valves
Last updated: March 28, 2019 4:12 pm
Control Valves Safety Instrumented System (SIS)
While many safety and relief valves actuate by the direct action of the process fluid forcing against the valve plug mechanism, others are more sophisticated in design, relying on a secondary pressure sensing mechanism to trigger and direct fluid pressure to the main valve assembly to actuate it.
Pilot-operated Safety and Relief ValvesComparison to non piloted pressure relief valvesAdvantagesDisadvantages
This pressure-sensing mechanism is called a pilot, and usually features a widely-adjustable range to give the overall valve assembly a larger variety of applications.
In a pilot-operated over-pressure-protection valve, the “lift” pressure value is established by a spring adjustment in the pilot mechanism rather than by an adjustment made to the main valve mechanism.
A photograph of a pilot-operated pressure relief valve used on a liquid petroleum pipeline appears here:
This photograph courtesy of the National Transportation Safety Board’s report of the 1999 petroleum pipeline rupture in Bellingham, Washington. Improper setting of this relief valve pilot played a role in the pipeline rupture, the result of which was nearly a quarter-million gallons of gasoline spilling into a creek and subsequently igniting.
One of the lessons to take from this event is the importance of proper instrument maintenance and configuration, and how such technical details concerning industrial components may have consequences reaching far beyond the industrial facility where those components are located.
The relief valve mechanism itself is the white-painted flanged valve found in the center-right region of the photograph (RV-1919). This particular relief valve happens to be a Fisher model 760 with 8-inch, ANSI 300# flanges.
The actuating pilot mechanism is the small unit connected to the relief valve body via stainless-steel tubing. When this pilot senses fluid pressure in the pipeline exceeding the lift pressure, it switches fluid pressure to the piston actuating mechanism of the main relief valve, opening it to relieve fluid pressure from the pipeline.
Thus, the lift pressure value for the relief valve is set within the pilot rather than within the main valve mechanism. Altering this lift pressure setting is a matter of adjusting spring tension within the pilot mechanism, and/or replacing components within the pilot mechanism.
Advantages
  • Smaller package on the larger pipe sizes.
  • More options for control.
  • Seals more tightly as the system pressure approaches but does not reach set pressure.
  • Control pilot can be mounted remotely.
  • Some designs allow for changes in orifice size within the main valve.
  • Can be used in engines.
Disadvantages
  • More complex, resulting in various fail-open failure modes.
  • More expensive at smaller sizes (starts to even out as pipe size increases).
  • Small parts in pilot valve are sensitive to contaminant particles.
Articles You May Like :
Pneumatic Instrumentation
Pressure Transmitter Manifolds
Insertion flow meters
What is Magnetic Tape Recorder ?
P&ID for Pumps Heat Exchangers
SIS Sensors
Control Valve Relation between Cv and Kv
Basics of Ball Valves
SIS Application Program – Safety Instrumented System
Difference between Pneumatic, Electrical & Hydraulic Actuators
Trip Valve Principle
Control Valve Characteristics
What is Complementary Split Range Control (CSRC)?
What is Double-ported Globe Valve ?
Why Restriction Orifice is some distance from Blowdown valve ?
Top 80+ Valve Questions and Answers
Control Valve Erosion Problems
What is Blowdown Valve (BDV)?
de-energized-to-safe-mode
Incident Investigation: Motor Operated Valve Lesson
Locked Open (LO) and Locked Close (LC) Valves
Locked Open (LO) and Locked Closed (LC) Valves
How to do Control Valve Sizing
How do you do control valve sizing in Layman’s terms?
Piping Schematic for Two Solenoid Valves Double Acting
Different Types of Control Valve Actuators
On-Off Valve Problems
How to Solve On-Off Valve Problems?
Control Valve Direction of Control Action
PID Controller Action : Directing Acting & Reverse Acting
On Off Valve Root Cause Analysis
Root Cause Analysis for FRP Line Damaged due to On-Off Valve
Deluge System for Transformer Protection
Deluge System for Transformer Protection Animation
Omron PLC increment and decrement
Increment & Decrement Instructions in CX-Programmer (OMRON)
Suppose the lamp refuses to light up
Indentify Faults in Simple Lamp Circuit including Failed Wires
Measurements & Instrumentation Quiz – Set 5
Omron PLC Instructions - Move, Move Bit, Move Digit
Move, Move Bit, Move Digit – Examples of Omron PLC Programs
Flammable Gases and Vapors Class 1 & Class 2
Gas Detectors Standards
Analytical Control System of Heat Exchanger Questions
