Reading: PID Simulator Download
Inst Tools > Blog > PLC Tutorials > PID Simulator Download
The PID controller simulator represents a very useful tool to understand the basic PID algorithm. Download and run the simulations.
Last updated: March 4, 2021 10:48 am
PLC Tutorials Control Systems Excel Tools
3 Comments
2 Min Read
PID controller simulator represents a very useful tool to understand as algorithm PID works.
PID AlgorithmClosed-Loop ControlDownload PID Simulator
In addition, the concept as direct or indirect controller action, 4-20 mA analog input/output signal, fail close or fail open control valve are fundamental to determine the correct implementation of the closed-loop control.
PID Algorithm
This worksheet simulates a simple level of control in a tank. The algorithm PID, for discrete values, is used to simulate the process:
PID algorithm
For those interested, I would like to share the excel document in which it is possible to see the calculations.
It was considered that the controller has in the input (Cin) and in output (CO) the variables according to the standard 4-20 mA.
Closed-Loop Control
Closed Loop
Sampling time ∆t is equal to 1 s. The system is initially in a steady-state with a settable input flow rate equal to the output flowrate.
At t = 0 it takes a step disturbance on the discharge line by means of the pump.
Through mass balance, the actual level (Present Value) is calculated. Obviously, in real-case, there is a Level Transmitter that “read” and communicate at the controller the PV.
It is possible to put in the system a dead time just to see the effect on the PID controller.
The algorithm PID determines the control action on the control valve that modify the inlet flowrate.
The control valve has a linear characteristic: Fin= % opening valve / 100 * Fmax, in.
To disable the derivative action is sufficient to set Td = 0 (refer to sheet “Calculation”, cell J8) while to disable the integral action set value 0 in the cell J9, excel sheet “Calculation”.
Note: this excel file simulates an “academic” version of the PID controller.
Author: Domenico Luca Romilio
Building Management System
Difference between Timer and Counter – PLC Basics
CRA Module in Schneider PLC – Remote IO Adapter Module
Identify Faults in PID Control Loop
Interactions With Process Control Systems Philosophy
3 Comments
  • Jumel Navidad says:
    January 25, 2023 at 3:16 am
    Thx for article it is very helpful to me
  • Raed says:
    August 23, 2023 at 3:01 pm
    great
  • Zhao Haiyang says:
    November 23, 2023 at 3:12 pm
    thank you
What is DCS? (Distributed Control System)
What is Seal-in Circuit ?
Basic PLC Ladder Programming Example
Override Control Functions
Integral (Reset) Control Theory
PLC Program for Controlling a Water Pump with 3 Power Sources
Advanced Ladder Logic PLC Example
Automatic Sanitizer – Complex Ladder Logic PLC Examples
Hot Well Level Control System in Condensing Turbine
ESG in Industrial PLC Automation Systems
PLC Conveyor Forward and Reverse Logic
Advanced PLC Conveyor Control: Forward and Reverse Rotation
Structured Text PLC Program for Sequential Process Data Storage
Structured Text PLC Code for Sequential Process Data Storage
How to Filter Digital and Analog Inputs in a PLC
PID Controller Functions
The STAR-DELTA Auto And Manual Program
Feed forward example
What is Feedforward Control ?
PLC Logic for Water Pumping and Chemical Addition
Developing PLC Logic for Water Pumping and Chemical Addition
Split Range Control for Temperature Control Application
Memory Devices Objective Questions – Part 1
Two Tanks Filling using PLC
PLC Ladder Logic for Tanks Filling as per Priority
PLC Program for Forward and Reverse Motor control
3 Phase Motor Control using PLC Ladder Logic
Measurement Unit Conversions
Thermovcouple Circuit
Thermocouple and its Principle
