Reading: What is a Paddle Wheel Flow Meter?
Inst Tools > Blog > Flow Measurement > What is a Paddle Wheel Flow Meter?
A variation of turbine flow measurement is the paddle wheel flow meter, a very inexpensive technology usually in the form of an insertion-type flow sensor.
Last updated: November 2, 2023 6:17 am
Flow Measurement
A variation on the theme of turbine flow measurement is the paddle wheel flow meter, a very inexpensive technology usually implemented in the form of an insertion-type sensor.
Paddle Wheel Flow MeterPrinciple of OperationProblems of Flow Meters
In this instrument, a small wheel equipped with “paddles” parallel to the shaft is inserted in the flow stream, with half the wheel shrouded from the flow.
A photograph of a plastic paddle wheel flow meter appears here:
Paddle wheel flow meter principle
A surprisingly sophisticated method of “pickup” for the plastic paddle wheel shown in the photograph uses fiber-optic cables (optional) to send and receive light.
One cable sends a beam of light to the edge of the paddle wheel, and the other cable receives light on the other side of the paddle wheel.
As the paddle wheel turns, the paddles alternately block and pass the light beam, resulting in a pulsed light beam at the receiving cable.
The frequency of this pulsing is, of course, directly proportional to volumetric flow rate.
The external ends of the two fiber optic cables appear in this next photograph, ready to connect to a light source and light pulse sensor to convert the paddle wheel’s motion into an electronic signal:
Paddle wheel flow meter sensors
A problem common to all turbine flow meters is that of the turbine “coasting” when the fluid flow suddenly stops.
This is more often a problem in batch processes than continuous processes, where the fluid flow is regularly turned on and shut off.
This problem may be minimized by configuring the measurement system to ignore turbine flow meter signals any time the automatic shutoff valve reaches the “shut” position.
This way, when the shutoff valve closes and fluid flow immediately halts, any coasting of the turbine wheel will be irrelevant.
In processes where the fluid flow happens to pulse for reasons other than the control system opening and shutting automatic valves, this problem is more severe.
Another problem common to all turbine flow meters is lubrication of the turbine bearings. Frictionless motion of the turbine wheel is essential for accurate flow measurement, which is a daunting design goal for the flow meter manufacturing engineers.
The problem is not as severe in applications where the process fluid is naturally lubricating (e.g. diesel fuel), but in applications such as natural gas flow where the fluid provides no lubrication to the turbine bearings, external lubrication must be supplied.
This is often a regular maintenance task for instrument technicians: using a hand pump to inject light-weight “turbine oil” into the bearing assemblies of turbine flow meters used in gas service.
Process fluid viscosity is another source of friction for the turbine wheel. Fluids with high viscosity (e.g. heavy oils) will tend to slow down the turbine’s rotation even if the turbine rotates on frictionless bearings.
This effect is especially pronounced at low flow rates, which leads to a minimum linear flow rating for the flow meter: a flow rate below which it refuses to register proportionately to fluid flow rate.
  • Variable Area Flow Meter
  • Piston Flow Meter Principle
  • Turbine Flow Meter Animation
  • Dall Tube Flow Meter Principle
  • Rotameter Selection Tips
Pitot Tube Working Principle
Square-Root in DCS or Flow Transmitter?
What is a Vortex Flow Meter?
Coriolis Flow Meter Construction
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
All About Variable Area Flow Meters
Coriolis Flow Meter Uncertainty and Inaccuracy
Gas and Liquid Measurement: Processes and Solutions for the Industrial Sector
What is an Orifice Meter?
Difference between Transit time and Doppler Ultrasonic Flow Meter
Bernoulli’s Principle and Equation – Flow Measurement
Working Principle of Flow Switch with Animation
What is a K Factor
Flow Meter K-factor and Calculations
multi-hole-restriction-orifice-plate
Basics of Restriction Orifice (RO) – Types, Applications, Standards
Flow Meters Troubleshooting
Turbine Flow Meters Troubleshooting
Bernoulli's Principle and Flow Meters
Coriolis Mass Flow meter as a Multi Variable Transmitter - 1
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
Advantages and Disadvantages of Flow Measurement Techniques
Advantages & Disadvantages of Different Flow Meters
multi-variable transmitter
Mass Flow Meters
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
Pneumatic Load Cell Principle
As-Interface Protocol Overview
AS-interface and DeviceNet Communication
Loop Diagram
Difference Between Wattmeter and Energy Meter
Basic Transistor Amplifier Circuit Principle
Battery in Vehicle
Why is a Battery used in a Vehicle?
Number Systems Multiple Choice Questions
Pressure Transmitter Calibration at the bench
