Reading: Optocouplers Working Principle
Inst Tools > Blog > Electronic Devices & Circuits > Optocouplers Working Principle
Last updated: September 3, 2019 7:17 am
Electronic Devices & Circuits Electronics Animation
3 Min Read
What is optocoupler?
 An optocoupler is an optical link and it connects two circuits via this link.
The optical link is contained within a chip. A Light Emitting Diode inside the chip shines on a photo-diode, photo-transistor or other photo device.
When the photo device sees illumination, the resistance between its terminals reduces. This reduced resistance can activate another circuit.
Optocoupler Working Animation
An optocoupler uses an LED optically coupled to a photodiode or a phototransistor in a single package.
Two basic types are LED-to-photodiode and LED-to-phototransistor, as shown in Figure.
Optocoupler Principle
Optocouplers are used to isolate sections of a circuit that are incompatible in terms of the voltage levels or currents required.
For example, they are used to protect hospital patients from shock when they are connected to monitoring instruments or other devices.
They are also used to isolate low-current control or signal circuits from noisy power supply circuits or higher-current motor and machine circuits.
Examples of typical packages are shown in Figure.
Different Optocoupler Packages
OptoCoupler Operation Animation
OptoCoupler Animation
The LED requires 1mA to 15mA.
What does this mean?
If the current-limiting resistor connected to the LED has a high value, only a small current will flow through the LED and it will not glow very brightly. (The LED is inside the chip – you cannot see it).
The transistor will not turn on very much and the resistance between the collector-emitter terminals will be fairly HIGH. The output voltage will remain fairly HIGH.
As the current through the LED increases, (the current-limiting resistor is reduced in value) the LED will glow brighter and the transistor will turn on harder. The output voltage in the diagram above will reduce.
If the current through the LED is allowed to rise and fall, the output voltage of the circuit above will fall and rise.
If the current through the LED changes instantly from zero to say 15mA, the output will change from HIGH to LOW. This is the principle of SWITCHING or passing a DIGITAL SIGNAL.
Phototransistor Circuit Example
Transistor Amplifier Working Principle
Shockley Diode Working Principle
pi filter Operation
Dependent Voltage Source
Ideal Diode Characteristics
Short Notes on Rectifiers & Filters
LC Tuned circuit Working Animation
Full Wave Voltage Doubler using Diodes
Electron Gun of Cathode Ray Tube
How a PN Junction Formed in a Diode
Varactor Diode Operation
Testing a Transistor with a Digital Multimeter
Limitations of Resistors
Short Circuit and Open Circuit
pn-junction-energy-diagrams
Energy Diagrams of PN Junction & Depletion Region
Transistor Biasing
Transistor Biasing
p-type-semiconductor
N Type and P Type Semiconductors
Transistor Collector Feedback Bias
Zener Diode Limiter Working
Zener Diode Limiter
Diodes Voltage Tripler
Electronic Symbols List
Electronic Symbols
Safety Valve
Compare Relief Valve and Safety Valve
What is Swing Check Valve ?
SMART Transmitter
What is a SMART Transmitter?
Fire Hydrant System
Basics of Fire Fighting Hydrant Systems
Pull Cord Switch Principle
Pull Cord Switch Working Principle
Breather Valve Working Principle
Boiler Three Element Controller Philosophy
Stability in Frequency Domain
Realization of Basic Compensators
