Reading: NDIR Gas Analyser Working Principle
Inst Tools > Blog > Analyzers > NDIR Gas Analyser Working Principle
Last updated: August 25, 2018 2:47 pm
Analyzers Animation How It Works
3 Comments
1 Min Read
NDIR GAS ANALYSER WORKING PRINCIPLE ANIMATION
For NDIR Gas analyzer, the main components are an infrared source (lamp), a sample chamber or light tube, a wavelength filter, and the infrared detector. The gas is pumped (or diffuses) into the sample chamber, and gas concentration is measured electro-optically by its absorption of a specific wavelength in the infrared (IR). The IR light is directed through the sample chamber towards the detector.
The detector has an optical filter in front of it that eliminates all light except the wavelength that the selected gas molecules can absorb. Ideally other gas molecules do not absorb light at this wavelength, and do not affect the amount of light reaching the detector. The detector measures the attenuated signal depending amount of gas absorption and it is proportional to the measured gas concentration.
Also Read: Infrared Non Dispersive CO2 Analyzer Working Principle
Hydrazine Analyzer Working Principle
Mass Spectrometer Working Principle
Scintillation Counter Principle
Cat and Mouse type Level Indicator
Tilt Level Switch Working Animation
pH Analyzer Calibration and Troubleshooting
3 Comments
  • amin shakiba says:
    May 2, 2016 at 11:36 am
    thank you
  • Neeraj Sharma says:
    May 31, 2016 at 2:51 pm
    Thank You so much sir
  • Hezy Ram says:
    September 22, 2021 at 2:28 pm
    how much it cost initially? and what is the cost to operate it (yearly)?
    thanks
Ultrasonic Sludge Blanket Level Meter Animation
Limit Switch Animation
H2S Measurement Using Lead Acetate Principle
Argonite/CO2 Flooding System Master & Slave Cylinder Operation
Relay Principle & its Types
Probe Type GWR Level Transmitter Working Animation
Level Transmitter Animation
Anti Surge Controller Working Principle
Humidity Calculator
Humidity calculator
sulfur dioxide analyzer
Fluorescence
Sealed Bellows Temperature Sensors
Bellows Pressure Sensors Working Principle Animation
hall-effect-sensor
Hall Effect Sensor Working Principle Animation
ORP-sensor-calibration
Oxidation-Reduction Potential (ORP) Sensor Calibration Procedure
Electromagnetic Flow Meters Working Principle
Piston Flow Meters Working Animation
Piston Flow Meters Working Principle with Animation
Vibrating Fork Level Switch Working Animation
Advantages and Disadvantages of Per Unit System
Password Protect Apps and Files
PLC Ladder Logic for Demultiplexer
1 to 8 Demultiplexer PLC ladder diagram
Capping Machines
Capping Machine – 5 Aspects of Control Systems and Automation
Compatibility Objective Questions
ControlLogix
Difference Between CompactLogix and ControlLogix
List of Documents Required for Testing and Calibration Laboratory
List of Documents Required for Testing and Calibration Laboratories
Analyzers Based on Gas Density Questions & Answers
