  • Ask
  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: Methods of Transistor Biasing
  • PLC Tutorials
  • Control Systems
  • Ask
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Electronic Devices & Circuits > Methods of Transistor Biasing
Last updated: September 27, 2016 5:37 am
1 Min Read
In the interest of simplicity and economy, it is desirable that transistor circuit should have a single source of supply—the one in the output circuit (i.e. VCC). The following are the most commonly used methods of obtaining transistor biasing from one source of supply (i.e. VCC ) :
(i) Base resistor method
(ii) Emitter bias method
(iii) Biasing with collector-feedback resistor
(iv) Voltage-divider bias
In all these methods, the same basic principle is employed i.e. required value of base current (and hence IC) is obtained from VCC in the zero signal conditions. The value of collector load RC is selected keeping in view that VCE should not fall below 0.5 V for germanium transistors and 1 V for silicon transistors.
For example, if     = 100 and the zero signal collector current IC is to be set at 1mA, then IB is made equal to IC / = 1/100 = 10 µA. Thus, the biasing network should be so designed that a base current of 10 µA flows in the zero signal conditions.
Ripple Voltage in Rectifiers
Insulators, Conductors and Semiconductors
Freewheeling Diode Working Principle
Semiconductors Diodes Questions & Answers
Transistor Collector Feedback Bias
  • Dr Chandrashekar says:
    December 16, 2022 at 8:15 am
    good
208kSubscribersSubscribe
Recent Comments
Related Articles
Types of Resistors
Types of Resistors
Transistor Biasing
Transistor Biasing
how-to-find-resistor-value
Limitations of Resistors
Basics of Amplifiers Interview Questions
Amplifiers Questions & Answers
seven-segment-display-circuit
Seven Segment Display Working Principle
Independent-Voltage-Source-circuit-ideal-battery
Circuit Elements and Types of Circuits
half-wave-rectifier-working-animation
Half Wave Rectifier Principle
diode-clamper-circuit
Full Wave Voltage Doubler using Diodes
More Articles
Classification of Bridge Circuits
Process Variable Damping Graph
Process Variable Damping of Transmitter
Ripple Counter Objective Questions
PLC Sequential Lights Control Example
PLC Timer Example: Sequential Control of Three Lights with Reset
microwave flow detector applications
Microwave Flow Sensor – Working Principle and Applications
Time Division Multiplexing Objective Questions
Purpose of Flow Ratio Controller
Identify the Purpose of Flow Ratio Controller
Siemens PCS 7
What is PCS 7?
