Reading: Low Voltage Protection (LVP) and Low Voltage Release (LVR)
Inst Tools > Blog > Electrical Theory > Low Voltage Protection (LVP) and Low Voltage Release (LVR)
Last updated: August 17, 2018 1:34 pm
Electrical Theory
3 Min Read
Within the two basic categories of motor controllers, there are three major types of AC acrossthe-line controllers in use today. There are low-voltage protection (LVP), low-voltage release (LVR), and low-voltage release effect (LVRE) controllers.
The main purpose of an LVP controller is to de-energize the motor in a low voltage condition and keep it from re-starting automatically upon return of normal voltage (Below Figure).
LVP Controller Operation:
LVP Motor Controller Principle
Figure : LVP Controller
  1. Push the START button, which energizes contactor coil M, closing the M and Ma contacts. When the START button is released, the circuit will remain complete, because the Ma contact remains closed, shunting the open start switch.
  2. When a low voltage condition occurs, the M coil will drop out at some pre-determined value of voltage, and the M and Ma contacts will open. The START button must then be pushed to restart the motor.
  3.  Depressing the STOP button deenergizes the M coil, which then opens the M and Ma contacts.
The purpose of the LVR controller is to de-energize the motor in a low voltage condition and restart the motor when normal voltage is restored. This type of controller (Below Figure) is used primarily on small and/or critical loads (e.g., cooling water pumps required for safety-related equipment).
LVR Controller Operation:
LVR Motor Controller Operation
Figure : LVR Controller
  1. Place the START switch in Run which energizes coil M, closing the M contacts and starting the motor.
  2. When a low voltage condition occurs, the M coil drops out, opening the M contacts and de-energizing the motor. When normal voltage is restored, the M coil is again energized, closing the M contacts and restarting the motor.
The LVRE controller maintains the motor across the line at all times. This type of controller is of the manual variety and is found mostly on small loads that must start automatically upon restoration of voltage (Below Figure). An LVRE controller may or may not contain overloads. If overloads are used, they will be placed in the lines to the load.
LVRE Motor controller
Figure : LVRE Controller
The motor controllers that have been discussed are very basic. There are many automatic control functions that can be incorporated into these types of controllers.
Apparent Power, True Power, Reactive Power & Total Power
What is Electricity ?
Series and Parallel Capacitors
Compound Generators
Resonance, Resonant Frequency, Series and Parallel Resonance
Reading Electrical Schematics
Types of AC Generators
What is Synchroscope ?
Transformer Voltage Ratio
Conductor, Insulator, Resistor and Current Flow
Half-Wave Rectifier Circuit
Resistivity
Generator Action in a Motor
Units of Electrical Measurement
Measuring Circuit Voltage
Voltmeters
Voltage Divider
Voltage Divider
Center Tap Full-Wave Rectifier
Full-Wave Rectifier Circuit
Core-Type Transformer
Transformer Turns Ratio
Current Law
Applying Kirchhoff’s Current Law
3-Wire, Three-Phase Delta Wiring System
Circuit Breaker Control Circuit Wiring
How to Measure Specific Gravity of Battery
Air Release Valve
What is an Air Valve? Purpose, Types, Advantages, Disadvantages
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Tilting Pad Bearing
Standard Test Signals Objective Questions
Difference between Signal Cables and Control Cables
Dynamic Characteristics of Power Diode
Power Diode – Characteristics, Construction, Working, Advantages
Automatic Motor Forward and Reverse Control using Timer
