Reading: 15 Loop Diagram Questions
Inst Tools > Blog > Instrumentation Design > 15 Loop Diagram Questions
Loop Diagram helps us to read the wiring connections from field instruments to the system cabinet. Find the top 15 Loop Diagram Questions here.
Last updated: September 22, 2020 10:05 am
Instrumentation Design Instrumentation Interview Questions
13 Comments
3 Min Read
Loop Diagram helps us to read the wiring connections from field instruments to system cabinet. Find the top 15 Loop Diagram Questions here.
Read: What are Loop DIagrams?
Examine this loop diagram, and answer the following questions:
Loop Diagram
Loop Diagram
Click on the image to zoom
Question 1:
What type of control loop is represented in this diagram? In other words, what is the process variable, and how is this process variable manipulated?
Question 2:
What is the calibrated range of the sensing instrument?
Question 3:
How are physical locations for wire connection points declared in this diagram?
Question 4:
Assuming the resistor inside the DCS input card is 250 ohms, calculate the amount of voltage between terminals 23 and 24 at a transmitter signal value of 50%.
Answer:  At a 50% signal (12 mA in a 4-20 mA range), the voltage dropped between terminals 23 and 24 will be 21 volts.
Question 5:
Identify where wires are part of a larger, multi-conductor cable, and identify how those wires are distinguished from all the others in that cable.
Question 6:
Identify the convention used to label wire pairs for each field instrument. In other words, how can a person tell whether a certain wire pair is going out to the transmitter, the indicator, or the control valve?
Question 7:
Identify at least two different ways you could measure the transmitter’s signal without interrupting the 4-20 mA current signal to the flow controller.
Question 8:
Explain why interrupting the loop’s continuity is a bad thing if the control system is operating, controlling a live process.
Question 9:
What do the letters “FI” and “FO” stand for? Are these labels ISA-standard?
Question 10:
Is FT-733 self-powered or loop-powered? How can you tell?
Question 11:
Sketch arrows showing the direction of electric current in each wire (using conventional flow notation), identifying each component as being either a source or a load.
Question 12:
Identify all the effects of pair 4 within cable ISOM-18 failing open and failing shorted.
Question 13:
Identify all the effects of cable FI-733 failing open.
Question 14:
Identify all the effects of pair 5 within cable ISOM-18 failing open and failing shorted.
Question 15:
When we use loop diagrams for troubleshooting? Explain with some examples.
Share your answers with us through comments.
  • HART Communicator Analysis
  • Instrumentation documents
  • What are Instrument Errors?
  • Configure a Smart Transmitter
  • What is NAMUR NE 43?
Credits: Tony R. Kuphaldt
Basics of Thermistors, Thermocouples and RTD’s
Flow Transmitters Questions and Answers – Instruments Test
Basics of Cable Shields
What is Hammer Effect in Gauges ?
Determine the Status of Lamps and Relays in the Circuit ?
13 Comments
  • afzal says:
    January 23, 2020 at 9:07 pm
    answer for question 1
    this diagram is repersenting a closeloop, and flow is the process variable . and the process variable can be manupulated by (fv-733)
    answer for question 2
    the calibration range of the sensing element is 0-125 wc
  • James Robles says:
    January 25, 2020 at 10:24 am
    I have a question. What software is used to draw loop diagrams?? I have never found how to draw them. Is it auto CAD? Is it Visio? Is it MS excel?
    • Vinoth Baskaran says:
      March 19, 2020 at 10:41 am
      It depends on client requirement during EPC stage, In General Loop Diagrams are generated in Smart Plant Instrumentation, Aveva Instrumentation and then submitted in Autocad or Microstation files & PDF copies.
  • Undefined says:
    January 25, 2020 at 3:38 pm
    SPI Intools can be used to create ILDs
    • Avinash says:
      January 27, 2020 at 10:44 am
      apart from spi intools, which software we can used??
  • Khalaf says:
    April 20, 2020 at 3:06 am
    Need answer for q6 please
    • AMIR says:
      June 24, 2020 at 8:12 pm
      There are several ways to name the wires, in the general case we shall follow the numbering procedure or engineering document such as wiring diagram, the common method is to identify the wire as follow:
      Tag the Instrument wire following the instrument tag by adding + and – on the instrument side.
      And instrument tag ending with terminal numbers
  • ad says:
    August 5, 2021 at 8:41 pm
    what does FO stand for?
    • Alikhan says:
      September 7, 2021 at 4:14 pm
      Flow output module as I understood
      FI is Flow input module
      Maybe it means PLC’s or DCS’s modules
  • Alikhan says:
    September 7, 2021 at 4:16 pm
    Can someone explain question 12-14?
  • Naran Parmar says:
    September 11, 2023 at 5:00 pm
    Sir,
    Why control signal range is 4-20 mA ? why not 2-18mA, 5-21mA,10-26mA ?
    • Tyler CV says:
      November 3, 2023 at 3:22 am
      4-20mA is a standard in industry.
  • Mohammad Aslam Moien says:
    November 14, 2023 at 6:48 pm
    Please answer someone the Q12 and Q13 please.
How to Calculate Transmitter Performance and Calibration Frequency?
Motor Protection Circuits
Types of Cables, Purpose, Advantages, Disadvantages, Applications
Instrumentation Technical Interview Questions and Answers
Immersion Heaters in Lube Oil Consoles
Temperature Sensor Failure
Failsafe Wiring Practices
Instrumentation and Process Control Project Inputs
Instrumentation and Process Teams Interactions in Design Engineering Companies
Profibus Communication Interview Questions & Answers
What is WHCP?
Control System Vendor Internal Test Procedures
Vendor View of Supplying Industrial Process Control & Safety Systems
Instrument Numbering Philosophy
Automation Engineers Interview Questions
Instrumentation Lab Viva Questions
Water Treatment Industry
Water Softening Systems in Water Treatment Industry
Motor contactors
What is Contactor ?
Cable Shield
High-frequency Signal Cables
foundation-fieldbus-vs-profibus
Comparison between Foundation Fieldbus and Profibus
Safety PLC Coding Practices
Safety PLC Coding Practices – Programming Recommendations
Paddle Type Level Switch
What is a Level Switch? Types of Level Switches
Pros and Cons of Online Educational Services
Pros and Cons of Online Courses
PLC Program for Selective Execution of the Application
PLC Selective Execution of the Application – Example Program
