Reading: Level Measuring Instruments Velocities of Propagation
Inst Tools > Blog > Practical Questions > Level Measuring Instruments Velocities of Propagation
Ultrasonic, radar, and magnetostrictive level measuring instruments use the principle of time-of-flight to determine the level of a process substance in a vessel.
Last updated: January 27, 2021 11:08 am
Practical Questions
2 Min Read
A critical factor for the accuracy of any time-of-flight measurement technology is the velocity of propagation for the wave in question, through the substance(s) that wave must travel.
level-sensing technologies
1. Examine each of these illustrations and then determine which of the velocities of propagation (v) matter and which do not. Be prepared to explain why, in each case!
2. Next, identify physical variables effecting the velocity of propagation for each of the waves in question.
3. Which of these level-sensing technologies do you suspect enjoys the greatest immunity from calibration error resulting from changing process conditions?
4. In each case, identify factors influencing the strength of the received signal
Partial Answer:
  • Ultrasonic level, bottom-mounted: vwater matters, vair does not
  • GWR level: vair matters, vwater does not
The velocity of propagation for sound waves varies with the density of the medium and also its bulk modulus. The velocity of propagation for radio waves varies with permittivity.
In both cases, changes in density (typically caused by changes in pressure and/or temperature) affect these factors, thereby affecting the velocity of propagation.
Share your answers & explanation with us through the below comments section.
  • Tank Stilling Well
  • Level Transmitter Errors
  • Sump Tank Level Transmitter
  • Magnetostrictive Level Sensor
  • Guided Wave Radar Level Sensor
Credits: Tony R. Kuphaldt
Differential Pressure Transmitter with 5 Way Manifold Valve
Displacer Type Density Transmitter Question
Questions on Pneumatic Control Loop
How to Connect Proximity Switch (Source Type) to Make LED ON ?
pH Transmitter Problem
Re-calibrate the Foxboro DP Pneumatic Transmitter
Calculate the Thermocouple’s Measurement Junction Temperature
Solenoid-controlled Valve Problem
Calculate LRV and URV for 4-20 mA Loop-powered DP Transmitter
DP Transmitter Calibration Errors
PLC Pump Permissive Interlocks
Upgrading the Electrical System in an Automobile
level control system
Practical Process Control System Questions & Answers – 10
Question on Analytical Controller
process conditions, Find out the Circuit Components Status
As per Process Conditions, Find out the Circuit Components Status ?
Calculate Hydraulic Pressure of a Drum
Calculate Hydraulic Pressure of a Process Vessel
Simple Pressure Repeater
Simple Pressure Transmitter Circuit
Pressure Transmitter using Potentiometer and Diaphragm
Problem on Weigh feeder
Steam Eductor Question
Choppers Objective Questions
Pros and Cons of Soft Starter
Pressure Unit Conversion Practical Example
Differential Pressure Level Transmitter Errors
High Pressure Liquid Chromatography Questions & Answers
Piping Schematic for Two Solenoid Valves Double Acting
Different Types of Control Valve Actuators
Basic AC Generator
AC Generator Parts
Flow Measurement
Continuous Flow Measurement
