Reading: Ion Transducers Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Ion Transducers Questions & Answers
6 Min Read
1. Which of the following is not an ion transducer or detector?
a) Faraday cup collector
b) Channeltron
c) Micro-channel plate
d) Flame ionization detector
Answer: d
Explanation: Flame ionization detector is not an ion transducer. It is a detector used in chromatography.
2. Which of the following is similar to photo multiplier transducer?
b) Channeltron
d) Electron multiplier transducer
Answer: d
Explanation: Electron multiplier transducer is similar to photo multiplier transducer. The difference is that its primary cathode detects ions rather than photons.
3. Which of the following is used in places where ion currents are very low?
b) Channeltron
Answer: d
Explanation: Electron multiplier transducer is used in places where ion currents are very low. Its primary cathode detects ions.
4. Discrete type electron multiplier transducers can provide current gain upto which of the following?
a) 102
b) 105
c) 107
d) 1011
Answer: c
Explanation: Discrete type electron multiplier transducers can provide current gain upto 102. Upto 20 dynodes need to be used for this purpose.
5. Continuous dynode electron multiplier transducer is a trumpet shaped device made with which of the following?
a) Glass doped with lead
b) Steel doped with bronze
c) Phosphor bronze doped with iron
d) Iron doped with calcium
Answer: a
Explanation: Continuous dynode electron multiplier transducer is a trumpet shaped device made of glass. It is heavily doped with lead.
6. The potential maintained across the continuous dynode multiplier transducer is which of the following?
a) 1 to 5kV
b) 5 to 10kV
c) 2.5 to 6.2kV
d) 1.8 to 2kV
Answer: d
Explanation: The potential maintained across the continuous dynode multiplier transducer is 1.8 to 2kV. Electrons cascade down the tube.
7. Which of the following are not the characteristics of electron multiplier transducer?
a) Rugged
b) Reliable
c) Microsecond of response time required
d) High current gain
Answer: c
Explanation: Electron multiplier transducer requires only nanosecond of response time. It provides high current gain.
8. Which of the following are true about dynodes used in discrete dynode electron multiplier?
a) The dynodes are all kept at same voltage
b) Successive dynodes are held at lower potential
c) Successive dynodes are held at higher potential
d) All dynodes are held at very low potential
Answer: c
Explanation: In discrete dynode electron multiplier, successive dynodes are held at higher potential. Dynodes are metal plates with copper or beryllium surfaces.
9. In which of the following detectors, the collector is placed in an inclined manner?
b) Channeltron
Answer: a
Explanation: The collector is placed in an inclined manner in faraday cup collector. This is to reflect the ions away from the entrance of the cup.
10. Which of the following is the least sensitive ion detector?
b) Channeltron
Answer: a
Explanation: Faraday cup collector is the least sensitive ion detector. It is used in places where great sensitivity is not required.
11. Photographic plates are coated with which of the following?
a) Lead
b) Quartz
c) Silver bromide
d) Mercuric sulphate
Answer: c
Explanation: Photographic plates are coated with silver bromide. These are sensitive to energetic ions.
12. Which of the following detectors are well suited for spark source instruments?
b) Photographic plates
Answer: b
Explanation: Photographic plates are well suited for spark source instruments. It has great sensitivity.
13. Photographic plates have greater sensitivity and resolution than electron multipliers.
a) True
b) False
Answer: a
Explanation: Photographic plates have greater sensitivity and resolution than electron multipliers. This is because they integrate the ion signals over a period of time.
14. Which of the following detectors consist of an array of glass capillaries?
Answer: c
Explanation: Micro-channel plate consists of an array of glass capillaries. They are coated with electron emissive materials.
15. Which of the following detectors can be used for ions with short life time?
Answer: b
Explanation: Photographic plates can be used for ions with short life time. This is because they integrate the ion signal over a period of time.
Auger Electron Spectroscopy
Measurement and Instrumentation Objective Questions – Part 2
Necessary Conditions for Stability & Non-Linear Systems
MCQ on Measurement and Instrumentation
DC Circuits Multiple Choice Questions
Transfer Functions Objective Questions
UV Visible Spectrometers Questions and Answers
Infrared Gas Analyzers Questions & Answers
Electrical Measurements and Instrumentation Objective Questions & Answers
Components of Mass Spectrometer Questions & Answers
Combination Electrode Questions & Answers
The Infinite Time Regulator Problem
Time Response Analysis
Performance Indices
Hydrogen and Glass Electrodes Questions & Answers
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
Fundamentals of Radiochemical Methods Questions
Single Beam and Double Beam Instruments
Digital Control Systems
The Z-Transform
Top 100 Control Systems Objective Questions & Answers
Capacitive Level Measurement Principle
Three Wire RTD Circuit
What is a Three-wire RTD ?
Gas Detection Definitions
Standard Gas Detection Definitions
Relay Parts
Difference Between NO and NC Contacts
pH and ORP eBook Download
pH and ORP Learning Handbook
Common Materials used in Instrumentation Cables
Electronic Amplifiers Objective Questions
