Reading: Ion Analyzer Questions & Answers
Inst Tools > Blog > Multiple Choice Questions > Ion Analyzer Questions & Answers
1. If a solid or liquid membrane is placed in pure water, the membrane dissolves slightly, producing an equilibrium concentration of the measured ion. This is represented as __________
a) A constant, Eo
b) Activity
c) Blank correction, Cb
d) Concentration of standard solution, Cs
Answer: c
Explanation: If a solid or liquid membrane is placed in pure water, the membrane dissolves slightly, producing an equilibrium concentration of the measured ion. This is represented as blank correction, Cb. This is the constant background for all measurements.
2. During which of the following conditions is the blank correction not necessary?
a) If sample concentration rises in linear response region
b) If sample concentration falls in linear response region
c) If sample concentration rises in non-linear response region
d) If sample concentration falls in non-linear response region
Answer: b
Explanation: The blank correction is not necessary if sample concentration falls in linear response region. This is the constant background for all measurements.
3. During which of the following conditions is the blank correction necessary?
Answer: d
Explanation: The blank correction is necessary if sample concentration falls in non-linear response region. This is the constant background for all measurements.
4. Ion analysers need calibration once in which of the following durations?
a) Every two or three hours
b) Every nine or ten hours
c) Every 24 hours
d) Every 48 hours
Answer: a
Explanation: Ion analysers need calibration every two or three hours. Temperature affects the output.
5. In ion analysers, which of the following serve the dual purpose of controlling the operating current of FET and providing current gain?
a) FET itself does it
b) SCR
c) Op-amp
d) Diode
Answer: c
Explanation: In ion analysers, op-amp serves the dual purpose of controlling the operating current of FET and providing current gain. Two FETs are operated as source followers.
6. The presence of dirt or moisture degrades which of the following?
a) Circuit components
b) High input impedance of buffer amplifier
c) Low input impedance of buffer amplifier
d) Low output impedance of buffer amplifier
Answer: b
Explanation: The presence of dirt or moisture degrades the high input impedance of buffer amplifier. Solder flux may also degrade it.
7. Which of the following is not a type of ground in ion analyser?
a) Chassis and electrostatic ground
b) Digital ground
c) Analog ground
d) Reference ground
Answer: d
Explanation: There is no such point as reference ground. Three types of grounding is provided which are chassis and electrostatic ground, digital ground and analog ground.
8. The timing for microprocessor and for all signals is generated by the CPU clock.
a) True
b) False
Answer: a
Explanation: The timing for microprocessor and for all signals is generated by the CPU clock. A crystal may be present to provide clock signals.
9. Which of the following is the only operator entry required in PC-based ion analysers?
a) Hardware set-up
b) Signal measurement
c) Calibration
d) Sample calculation
Answer: c
Explanation: Calibration is the only operator entry required in PC-based ion analysers. The operator has to enter the concentration of calibration standards.
10. The analog and digital grounds are connected together in ion analysers.
a) True
b) False
Answer: b
Explanation: The analog and digital grounds are not connected together in ion analysers. This is to ensure that the digital signals never flow through the same conductor as analog signals.
Performance Indices
State Variables & Linear Discrete Time Systems
Approximation of Higher-Order Systems by Lower Order
Instrumentation for Electron Spectroscopy
Mass Spectrometer Questions & Answers
Pole Placement by State Feedback
Paramagnetic Oxygen Analyzers Questions & Answers
Instrumentation Diagrams Multiple Choice Questions
PID Controller Multiple Choice Questions
Tuning of PID Controllers
Fluorescent Spectrometer Questions & Answers
Components of Mass Spectrometer Questions & Answers
Digital Control Systems Multiple Choice Questions
Inductively Coupled Plasma Mass Spectrometer
Signal Reconstruction
UV Visible Spectrometers Questions and Answers
Nonlinear Control Systems
Constructing Phase-Trajectories
Time Response Analysis
Robotic Control System – Part I
Control Loops Multiple Choice Questions
Control Loop Multiple Choice Questions
Stepper Motor Parts
Stepper Motor MCQ
Piping and Instrument Drawing
Difference between PFD and P&ID with Example
Top 100 Robotic Projects for Engineering Students
Area Velocity Flow Meter Principle
Electrical Machines Short Answers
Characteristics of Transducers Objective Questions
Signal Flow Graphs Objective Questions
Negative Readings in Gas Detectors
Why Negative Readings in Gas Detectors ?
Control Valve Plug Stem and Gland Leaks
Repeat Control Valve Plug Stem and Gland Leaks
