Home » Introduction to Combinational Logic Functions
Digital eBook
The term “combinational” comes to us from mathematics. In mathematics a combination is an unordered set, which is a formal way to say that nobody cares which order the items came in. Most games work this way, if you rolled dice one at a time and get a 2 followed by a 3 it is the same as if you had rolled a 3 followed by a 2. With combinational logic, the circuit produces the same output regardless of the order the inputs are changed.
There are circuits which depend on the when the inputs change, these circuits are called sequential logic. Even though you will not find the term “sequential logic” in the chapter titles, the next several chapters will discuss sequential logic.
Practical circuits will have a mix of combinational and sequential logic, with sequential logic making sure everything happens in order and combinational logic performing functions like arithmetic, logic, or conversion.
You have already used combinational circuits. Each logic gate discussed previously is a combinational logic function. Let’s follow how two NAND gate works if we provide them inputs in different orders.
We begin with both inputs being 0.
Combinational Logic Functions - 1
We then set one input high.
Combinational Logic Functions - 2
We then set the other input high.
Combinational Logic Functions - 3
So NAND gates do not care about the order of the inputs, and you will find the same true of all the other gates covered up to this point (AND, XOR, OR, NOR, XNOR, and NOT).
Similar Articles:
Related Articles
Logic Simplification With Karnaugh Maps
S Bharadwaj Reddy
Digital Logic With Feedback
S Bharadwaj Reddy
Contact Normal State and Make/Break Sequence
S Bharadwaj Reddy
Bit Grouping
S Bharadwaj Reddy
Numbers and Symbols
S Bharadwaj Reddy
Synchronous Counters
S Bharadwaj Reddy
WordPress Image Lightbox
