Reading: Instrumentation Role during Steam Blowing
Inst Tools > Blog > Instrumentation Design > Instrumentation Role during Steam Blowing
A brief introduction to steam blowing and role of Instrumentation engineer during the steam blow out operation in the plant.
Last updated: May 12, 2022 12:06 am
2 Min Read
As a part of pre-commissioning procedures steam blowing is carried out.
The prime purpose of steam blowing is to de-scale dust, scales, and other foreign materials from steam pipelines to avoid damage to turbine blades in the course of normal operation.
Steam Blowing
High momentum of expanding steam in the pipe dislodges and purges out the loose materials.
The instrument team shall remove instruments (control valves, orifice plates, flow elements, thermowells, thermocouples, pressure gauges, etc.) that may be damaged during steam blowing.
Inform construction workmen of contractors regarding steam blowing activity and arrange for necessary barrication/evacuation as per site conditions.
Prior to steam blowing an Instrument engineer must list out the instruments coming in steam blowing loop with mark-up P&ID along with Operations team.
Once instruments are identified the nozzles of the thermowell must be verified from ISO metric drawings for nozzle length so as to ensure proper insertion of thermowell upon installation.
Moreover, in some cases, the thermowell design is with collar support. Hence, a mock-up installation of the thermowell should be done so as to check if the thermowell inserts properly and smoothly in the nozzle.
Due to improper welding or welding burrs, the thermowell collar gets stuck in between and doesn’t insert properly.
Sometimes, the nozzle flange is not properly welded onto the standpipe and there is linear or angular displacement as shown in the picture below:
This may lead to issue during installation of thermowell.
Hence, mock-up needs to be done prior to steam blowing only so that if any minor grinding or surface finish is required in the nozzle same may be done.
  • Heat Tracing
  • Steam Tracing
  • Burner Safety
  • Role of Flow Meter
  • Impulse Line Test
Pull Up and Pull Down Switch Circuits
Level Instruments General Specifications
How to Select a Flow Meter
Purpose of Loop Diagrams
Gas Detectors Installation Techniques
Redundant Power Supply for Critical Field Panels
What to Choose RTD or Thermocouple ?
How to Select a Fuse ?
Solenoid Operated Valves and Latching Valves
Basic Terms used in SIL Verification
How to Select a pH and ORP Meter
How to Select a pH or ORP Meter
Tagging Philosophy for Junction Box
Tagging Philosophy for Junction Box, Cable, and Cable Drum
History of 3-15 psi, 10-50 mA, and 4-20 mA signals
Level Transmitter Design
Level Transmitter and Level Gauge Design Tips
Instrumentation Project Documents
List of Instrumentation Project Engineering Documents
DCS Vs PLC
Difference between DCS & PLC Systems
Pressure Switch Terminology
Hazardous Area Questions & Answers
Hazardous Area Classification Questions
Types of Allen Bradley PLC
Process variable to 4-20mA Conversion
Formula to Calculate 4-20 mA from Process Variable
Worldwide Voltage & Frequency Values
How Valve Positioners act as Cascade Control Systems in a Loop?
Speed of Power Actuators
Speed of Actuators
Valve stem travel
Control Valves Mechanical Friction Problems
Membrane Bioreactor in Water Treatment - MBR Process
Membrane Bioreactor in Water Treatment – MBR Process
