Reading: How to Solve Cable Tray Sagging ?
Inst Tools > Blog > Erection & Commissioning > How to Solve Cable Tray Sagging ?
Last updated: August 23, 2019 10:44 am
Erection & Commissioning Instrumentation Design
2 Min Read
Sagging occurs when the Load increases on Cable Tray.
1. Increase Support Frequency2. Increasing Collar Height3. Changing Type of Tray4. Changing Width of Tray Will “Not” Help
So here’s few possible solutions
When we reduce the distance between two consecutive support, this would strengthen the load carrying capacity of the tray.
Usually we provided support to cable tray every 3 m, If still the load is high the support could be given every 2.5 m or so .
But yes increasing support is not always feasible to do so !!
Example your support is running via pipe rack or other reasons. So below options can be evaluated
Like we have a collar attached to the shirt
A Collar is attached to the plate of cable tray also called depth of cable tray.
The higher the we increase the collar length the more strength it gives to the cable tray.
Also at some places an extra collar is added inside cable tray to separate the DO and AI,AO,DI signals ,This also adds to strengthen the cable tray
Ladder type has higher load bearing capacity than perforated tray.
The ladder tray has rods called rungs which provided higher load bearing capacity
Obviously there are other trade offs if those are acceptable then changing type could solve the problem
Just as a side note
Changing width of cable tray will not be helpful
i.e Changing from 300 mm Cable tray to 900 mm Cable tray will not help to increase the load bearing capacity .
Thanks for reading !
PS: This is as per best of my current understanding
NOTE :- There are TONS of more solutions available also !! so run your creativity wild !!
Author : Asad Shaikh
Profile : Linkedin
Articles You May Like :
Pressure Transmitter Fittings
Field Instruments Mounting
Instrument Tube Installation
P&ID Guide for Pig Receiver
Factors during Piping Design
Immersion Heaters in Lube Oil Consoles
Orifice Sizing Guidelines and Thumb Rules with Flowchart
Monsoon Protection for Field Instruments and Junction Boxes
Pipeline Project Management
Ferrules and Cross Ferruling
What is an O-Ring?
Selection Guidelines for Cable Glands
Interactions With Process Control Systems Philosophy
How O-Ring Failure caused NASA’s shuttle to Blast ?
Pneumatic Signal Piping and Fittings
Process Variable Damping of Transmitter
Instrument System Architecture and Process Control Design
System Architecture and Process Control Systems Philosophy
Triangle A-B-C- with Arc “A-C”
Instrument Tube Fitting Installation – Part 2
Panel Ground Noise
Floating Vs. Grounded Voltage
Solenoid Valve Design
Barrier & Sensor Connection with NAMUR
Why we use NAMUR Output Sensor?
Diaphragm seal for pressure measurement device
When to use a Diaphragm Seal?
Kv-value of a valve is determined by a standardised test
Calculate Flow Coefficient Kv of Solenoid Valve
Good and Bad Wiring Practices
Electrical Machines MCQ Series 6
why-reactive-power-is-generated-at-load
Why Reactive Power is Generated at Load
Fundamentals of Digital Systems Quiz
200 Quiz Questions on Fundamentals of Digital Systems
How to export in Vijeo Designer
Vijeo Designer software – Import and Export
Dependent Voltage Source
diode-basic-structure-symbol
Forward Bias & Reverse Bias of a Diode
LogixPro Simulator Software
