Reading: How to do Force in GE PLC Proficy Machine Edition?
Inst Tools > Blog > PLC Tutorials > How to do Force in GE PLC Proficy Machine Edition?
Last updated: March 4, 2021 12:40 pm
Learn how to do Force ON and Force OFF in GE PLC software proficy machine edition using ladder logics and reference view tables.
FORCE in GE PLC
Step 1:
Open “Proficy Machine Edition” Software
Open "Proficy Machine Edition" Software
Step 2:
Open the saved project.
Step 3:
Software loaded.
GE Proficy Software
Step 4:
First Click on Online mode then click on Toggle online. Refer the below picture.
Proficy Online mode then click on Toggle online
Step 5:
Now you are online. Browse the logic and select the required variable to be forced.
Right-click on the variable to be forced and click “Force ON” option as shown in the below figure.
Here we are forcing a on/off valve or also called as shutdown valve. Force ON means we are making the logic status to 1.
Force ON in Proficy Machine Edition
Step 6:
Now if we want to test the logic status with “0” then right-click on the required variable and click “Force OFF” as shown in the below figure.
Force OFF means we are making the logic status to 0.
Force OFF in Proficy Machine Edition
Step 7:
After testing the logic with Force ON and Force OFF options, we must remove the force so the logic will work in real-time otherwise these variables will stay in force state.
Right-click on the required variable and select “Remove Force” option as shown in the below figure.
Remove Force in Proficy Machine Edition
Step 8:
Till now we discussed how to do force ON and OFF from logics.
Now if we want to do the force ON and OFF from reference tables then the below steps will apply.
Select the “Reference View Tables” menu in the left side-bar and expand it.
Step 9:
Select the “Default Tables” folder in the left side-bar and expand it as shown in the below figure.
Reference View Tables in GE PLC
Step 10:
Select “Analog Output” option in the left side-bar and double-click on it.
In this window, we must know the address used for the outputs in the logic.
Select the required address (%AQ0113 in our example), click on it and apply the required value.
Analog Output Force in PLC
Step 11:
After testing, again enter the default value.
Force in PLC
Step 12:
Now we see the FORCE ON and FORCE OFF of digital inputs.
Select the “Input” option in the left side-bar as shown in the below figure.
Step 13:
In our example, we want to force %I00005 address. Select the respective bit and right-click on it.
The value in the selected address if logic “0”.
A drop-down window will appear as shown in the below figure and select “Force ON” option.
Force ON Digital Inputs in PLC
Step 14:
Then a pop-up window will open for confirmation. Click on “OK”.
Step 15:
As we used FORCE ON option, so the logical value in the address %I00005 will change to logic “1” as shown in the below figure.
Force PLC
Step 16:
Similarly, right-click on the address and click on “Force OFF” option to make the logic status to “0”.
Force OFF Digital Inputs in PLC
Step 17:
After testing, we have to remove the force otherwise the logic status will stay in the forced state.
So, right-click on the required address and select “Remove Force” option.
Remove Force Digital Inputs in PLC
Step 18:
Again, a pop-window will open for confirmation. Click on “OK” to remove the force.
Force Inputs in PLC
Step 19:
Now if we want to show all the variables which are in “Forced state” then follow the below step.
Select “HBR504” option and right-click on it.
A drop-down window will appear, now select “online Commands”, again a new dropdown appears.
Select “Show Forces in Controller” option as shown in the below figure.
Show Forces in PLC Controller
Step 20:
Now software displays all the forced variables in the controller as shown in the below figure.
How to do Force ON and OFF in GE Proficy Machine Edition?
  • Download Free PLC software
  • SCADA Software Demo
  • Up Down Counter in PLC
  • Grounding Scheme in PLC
  • Backup from Siemens PLC
  • Wiring Diagrams of PLC
What is Alarm Prioritization? – Types of Alarms
Difference Between Microcontroller and PLC
How to Configure PID Controller in Various Schneider PLCs?
PLC Example on Switch Program with Timers
  • R Gupta says:
    September 26, 2020 at 6:02 pm
    Why are we using “toggle online” after taking PLC online in step 4?
PLC Program for Fish Feeding System
Pulse Generation using Timer in Siemens PLC
What is Interposing Relay in a PLC System ?
Sheets, Tags, Elements in Functional Block Diagram of Studio 5000
Problem on PLC, HMI, VFD, and Motor Circuit
Electrical Circuit Breaker Quiz
100 Electrical Circuit Breaker Quiz
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Function Module in Siemens PLC
What is Function Module in Siemens PLC?
Siemens PLC Write Protection
How to Protect Siemens PLC using Password?
PLC Ladder Logic Chemical Mixing Process
Chemical Mixing Process using PLC
Motor Feedback Fail Logic in PLC
Does Really a Safety Barrier is Important
Does Really a Safety Barrier is Important? – PLC DCS Systems
Online time of the PLC
System and Local Time in PLC
Calculate Power in Parallel RC Circuit
Transformers Questions and Answers
Latest Transformers Questions and Answers
Level Gauge Interface Measurement
Level Gauge Interface & Temperature Problems
Feedback control loop - 2
Feedback Control Principle
Top US Universities that Offer Online Education
Limit Switch Schematic
Basics of Limit switches
Full Wave Rectifiers Objective Questions and Answers
