Reading: Hazards of Compressed Air
Inst Tools > Blog > Process > Hazards of Compressed Air
Last updated: May 17, 2018 7:16 pm
Process
2 Min Read
People often lack respect for the power in compressed air because air is so common and is often viewed as harmless. At sufficient pressures, compressed air can cause serious damage if handled incorrectly. To minimize the hazards of working with compressed air, all safety precautions should be followed closely.
Small leaks or breaks in the compressed air system can cause minute particles to be blown at extremely high speeds. Always wear safety glasses when working in the vicinity of any compressed air system. Safety goggles are recommended if contact lenses are worn.
Compressors can make an exceptional amount of noise while running. The noise of the compressor, in addition to the drain valves lifting, creates enough noise to require hearing protection. The area around compressors should normally be posted as a hearing protection zone.
Pressurized air can do the same type of damage as pressurized water. Treat all operations on compressed air systems with the same care taken on liquid systems. Closed valves should be slowly cracked open and both sides should be allowed to equalize prior to opening the valve further. Systems being opened for maintenance should always be depressurized before work begins.
Great care should be taken to keep contaminants from entering air systems. This is especially true for oil. Oil introduced in an air compressor can be compressed to the point where detonation takes place in a similar manner as that which occurs in a diesel engine. This detonation can cause equipment damage and personnel injury.
Rotary Compressors
CO2 Absorber Corroded Wall Thickness & Weld Building
What is EDI in a Water Treatment Plant? – Electro deionization
Bucket Steam Trap
Cooling Tower
Pressurizer
Components of Water Treatment Plant
What is a Deaerator? – Working Principle
Compressor Anti-Surge Control near-miss incident
Precoat Filters
Process Control Fundamentals
Process Air Compressor too Frequent & too Lengthy Overhauls Eliminated
Strainers
What is a Compressor? Types of Compressors
Single-Bed Demineralizer
Demineralizers
swing check valve Theory
Hydraulic System
Positive Displacement Pumps
What are Positive Displacement Pumps and their Types?
CO2 Stripper Collapsed Internals Revamp
Y Strainer
What is a Y Strainer ?
Water Treatment Industry
Water Softening Systems in Water Treatment Industry
What is Heat Pump Water Heater?
Blowout preventer (BOP) Principle
Analog Electronics Objective Questions – Set 10
Communication between Intouch Scada and Allen Bradley PLC
Communication between InTouch Scada and Allen Bradley PLC
Feedback Control Questions & Answers
Feedback Control Loop Questions & Answers
Importance of Instrumentation Engineering
Importance of Instrumentation Engineering – Objectives
How to Setup a Smart Transmitter Using a HART Communicator
How to Configure a Smart Transmitter Using a HART Communicator?
What we need to Know before Tune a PID Controller
Worldwide Voltage & Frequency Values
Innovative Segment Orifice
Pitot-tube Replaced with Innovative Segment Orifice Plate
