Reading: Hard-Wired Control Logic for the Pressure Alarm
Inst Tools > Blog > Common > Hard-Wired Control Logic for the Pressure Alarm
To understand the hard-wired control logic concept, let us examine a relay control circuit where a pressure switch activates an alarm light.
Last updated: September 4, 2023 11:28 am
Common
2 Min Read
Hard-Wired Control Logic for the Pressure AlarmSolution:
Pressure Alarm Relay Logic
Solution:
Here we used simple applications to understand the hardwired control logic. In industry, we are using PLC for logic but sometimes for simple applications, we can use hardwired control logic.
However, this logic is complex for large applications, but we can use it for small applications.
As shown in above figure 1, we used a pressure switch and alarm lamp. Pressure is set in the pressure switch around 10 Psi. Here we used NC contact of the pressure switch so when pressure is ok, the relay is in actuated condition so the alarm lamp will be ON.
As shown in above figure 2, if pressure is below 10Psi then the relay will be OFF so the NC contact of the relay will remain healthy. So that alarm lamp will be ON.
Disclaimer: The example application presented here is intended solely for illustrative purposes and may differ from real-world applications. The logic implemented in this example is not the only way to achieve the same function; various methods can be used. The parameters and graphical depictions used herein are also for explanatory reasons and may vary in actual setups. Please note that this example does not account for all possible safety interlocks or additional features that might be present in a real-world scenario.
What is Cable Drum Handling? – Transportation & Storage
Difference between DSP and DAC – Digital Electronics
Difference between Electron and Proton
What is a Fotonic Sensor? – Working Principle, Advantages, Disadvantages
Heat Recovery in HVAC System
Mill Interlocks in the Sugar Industry
4-wire Transmitters Current Loops
Common Materials used in Instrumentation Cables
Intrinsic Safety of Instruments
Seismic Displacement Sensing Accelerometer
Introduction to Digital Systems
What is a Process Alarm? Types of Alarms
Instrumentation Thread
Thread Sealant Types and Selection for Instrumentation Applications
Password Protect Apps and Files
Sugar Plant - Automatic Control of Massecuite Feed
Sugar Plant – Automatic Control of Massecuite Feed
Meters used in Troubleshooting Electrical Equipment
Series Air Fuel Combustion Control
Combustion Control – Series and Parallel Air-Fuel Ratio Control
smart-transmitters-advanced-diagnostics
Smart Transmitters Advanced Diagnostics
Power Tool Maintenance
Power Tool Maintenance – When And How To Replace Carbon Brushes
Battery in Vehicle
Why is a Battery used in a Vehicle?
power factor correction equipment
Power Factor Controller (PFC) – Commissioning
Difference Between Skin Effect and Proximity Effect
Differential Pressure Switch Working Principle
Limit Switch Schematic
Basics of Limit switches
Orifice Beta
Level Measurement using DP Transmitters - Open Tank
Open Tank Level Measurement using DP Transmitters Animation
Thermocouple Types
Types of Thermocouples
Homebrew CNC Machine
Embarking on a Homebrew CNC Project: A Journey of Creativity
