Reading: How Gate Valves Work ?
Inst Tools > Blog > Control Valves > How Gate Valves Work ?
Last updated: January 23, 2019 2:39 pm
Control Valves
2 Min Read
Gate valves work by inserting a dam (“gate”) into the path of the flow to restrict it, in a manner similar to the action of a sliding door. Gate valves are more often used for on/off control than for throttling.
ApplicationsAdvantagesDisadvantages
The following set of photographs shows a hand-operated gate valve (cut away and painted for use as an instructional tool) in three different positions, from full closed to full open (left to right):
Gate Valve Body Design
Applications
  • Suitable for oil, gas, air, heavy liquids, steam, non-condensing gases, abrasive and corrosive liquids
  • Sizes available range from standard cast configurations as small as 2″ to special fabricated valves exceeding 100″.
  • Standard cast configurations have ASME 125/150 bolting patterns and are rated atb150 psi.
Also See : Gate Valve Animation
Advantages
  • High capacity
  • Tight shutoff
  • Low cost
  • Little resistance to flow
  • Ability to cut through slurries, scale and surface build-ups
  • Provide unobstructed flow paths that not only provide high flow capacity (Cv), but even allows slurry, large objects, rocks and items routinely found in mining processes to safely pass through the valve.
Disadvantages
  • Poor control
  • Cavitate at low pressure drops
  • Cannot be used for throttling
  • Relatively low pressure limitation – general pressure limitations are 150 psi at maximum.
Articles You May Like :
Valve Types Characteristics
Objective Questions on Valves
Direct Acting Control Valves
What is Piston Check Valve ?
Instrumentation Inspection Report
Control Valve Sequence Methods
Control Valve Cv calculation
Classification of Control Valves
What is Shutdown Valve?
Pneumatic Valves Questions & Answers
3 Port 2 Position Direct Acting Solenoid Valve Working Principle
Current to Pressure (I/P) Converter Principle
Self-actuated Temperature Regulator – Principle, Types, Advantages
Control Valve Preventive Maintenance
Globe Valve Seat and Disk
Purpose of 100% and 30% Feed Control Valves in a Power Plant
Control Valve Performance with Constant Pressure
Gas Valve Sizing
Working Principle of Hydraulic Actuators
Solenoid Valve Problems and Solutions
Cage-guided globe valves
What is Cage-guided Globe Valve ?
Control Valves Flow Direction
Control Valve Flow Direction
Difference between Rotary Shaft and Sliding Stem Control Valves
Difference between Rotary Shaft Valves and Sliding Stem Control Valves
Control Valve in Last Position
Control Valve Fail Safe Action
Electric Motor Actuator Parts
Special Control Valves
Malfunctioning Inlet Check Valves
Industrial Plasma Systems
Why PDMS is Used For Fabrication?
PLC Programming Basics for a Packing Machine Control System
PLC Packing Machine Control System Program in XG5000
Earthing Calculations
Electrical Earthing Calculations
PLC based Drink Dispenser System
mA-Conversion-Tool
Transmitter Current Conversion Tool
What is an RTU - Remote Terminal Unit
What is an RTU? – Remote Terminal Unit
Renewable Energy Projects
200 Renewable Energy Projects for Students and Engineers
Masked Move Instructions
How to use Masked Move Instruction in PLC
