Reading: Four Way Solenoid Valve Working Principle
Inst Tools > Blog > Animation > Four Way Solenoid Valve Working Principle
Last updated: August 31, 2022 10:35 pm
Animation Control Valves Solenoid Valve
2 Min Read
Most indirect-acting solenoid valves operate slower than their direct-acting counterparts. This is because air pressure is routed in and out of the pilot to push the spool.
Four Way Solenoid ValveThree-Way Solenoid Valve
While the solenoid rests idle, the core spring pushes it forward against the pilot base. The purpose of the core is to seal against a very small pressure port facing it, which becomes open when the solenoid is energized.
Four Way Solenoid Valve Animation
Gif Courtesy: ZDSPB
When energized, the coil around the core pulls it away from the pilot base, which allows airflow into the pilot itself. This pushes the pilot against the spool, shifting the valve’s airflow as long as the coil is energized.
When resetting, the core spring pushes it against the pilot to seal off airflow and also open the pilot’s exhaust ports, which let the pilot reset to its idle position.
Some solenoid pilots have a feature known as the manual override as well. This is a small button on the outside of the pilot (between it and the core) which manually pushes the core away from the pilot to fire the marker.
The override is fitted with a spring to reset it and prevent it from interfering with the core during normal operation.
The only difference between a four-way and three-way pilot-actuated valve is the porting for the spool. One of the outputs is simply removed, and the air travels nowhere.
While the spool lies closed (idle), air pressure will enter the solenoid spool but not exit. The air that is trapped in the outlet port is always vented to the outside air through the firing assembly.
Some Pictures of 4 Way Solenoid Valve:
4 Way Solenoid Valve Parts
three way solenoid valve principle
solenoid valve diagram
Control Valve Testing for Noise Measurement
Microwave Flow Sensor – Working Principle and Applications
How to Select Control Valve Failure Mode
Face to Face Dimension of Control Valve
Valve Seat Leakage Test
  • sumit mohite says:
    May 23, 2017 at 6:19 am
    very nice sir. you’re doing a fantastic job
Cat and Mouse type Level Indicator
What is an Altitude Valve?
What is Travel Stop in Control Valve?
What is ON/OFF Valve ?
Hydrostatic Level Measurement
Resistor Color Code Animation
How to Do Maintenance of Control Valve Which is Stuck in Field?
Magnetic Float Level Switch Working Animation
Valves Legend P&ID
Comparison of Gate Valves and Globe Valves
Control Valve Parts
Basic Parts of Control Valves
Gate Valve Parts
What is Gate Valve ?
Level-Transmitters-Animation
Level Transmitter Animation
Diaphragm Valves
How Diaphragm Valves Work ?
Plant Shutdown Analysis: Valve Closed and SOV Coil Failure
DIN Valve Connectors
DIN Valve Connectors – Definition, Types
double-pumps unit unloading valves
What is an Unloading Valve? – Types, Principle
Interview Questions and Answers
Mass Spectrometer Questions & Answers
Principle of Operation of PLC
Convert Linear mA to Square root mA
Convert Linear Percentage to Square root Percentage
Glass Bottle Level Gauge
Antifriction Bearings Caused Machine Changeovers Posed Outages
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 7
Tubing ACCURATE BENDING
Instrument Tube Fitting Installation – Part 1
Pros and Cons of Online Educational Services
Pros and Cons of Online Courses
