Reading: Flow and Level Measurement Quiz
Inst Tools > Blog > Instrumentation MCQ > Flow and Level Measurement Quiz
In this article, we shared the flow and level measurement quiz questions and answers for instrumentation and electrical engineers.
Last updated: February 11, 2022 10:43 am
Instrumentation MCQ
13 Min Read
In this article, we shared the flow and level measurement quiz questions and answers for instrumentation, electrical, and electronics engineers.
Flow Measurement QuizLevel Measurement Quiz
The below list provides all the multiple-choice questions (MCQ) related to the flow measurement.
1. The rate at which fluid flows through a closed pipe can be determined by
A)Determining the mass flow rate
B)Determining the volume flow rate
C)Either Determining the mass flow rate or Determining the volume flow rate
D)None of these answers
2. Conveyor-based methods are used for the measurement of the flow of
A)All of these answers
B)Solids
C)Liquid
D)Gas
3. For the measurement of the flow rate of liquid, the method used is
A)Thermal mass flow measurement
B)Bourdon tube
C)Conveyor-based methods
D)Coriolis method
4. The devices used for flow obstruction is/are
B)Orifice plate
C)Venturi tube
D)Flow nozzle and dall flow tube
5. The device which is used for making temporary measurements of flow is
A)Pitot static tube
B)Orifice plate
C)Venturi
D)Dull flow tube
6. The instrument which is not suitable for the application in the automatic control scheme
A)Orifice plate
B)Pitot static tube
C)Rotameters
D)Rotary piston meter
7. Example of a positive displacement meter is
A)Turbine meters
B)Venturi
C)Rotary piston meter
D)Variable area flowmeter
8. Turbine meters are generally preferred for
A)High viscosity and low flow measurements
B)High viscosity and high flow measurements
C)Low-viscosity and high flow measurements
D)Low viscosity and low flow measurements
9. The flow meter which is replacing the differential pressure meters in its applications is
A)Electromagnetic flow meters
B)Vortex-shedding flow meter
C)Ultrasonic flow meters
D)All of these answers
10. Dipsticks are used for the
A)Flow measurement
B)Level measurement
C)Pressure measurement
D)Displacement measurement
11. The most common application of float system is
A)To monitor the flow of liquid
B)All of these answers
C)To monitor the flow of solid
D)To monitor the fuel tank level in motor vehicle
12. Capacitive devices are used for the level measurement of
A)Both Only liquid and Solid in powdered form
B)Solid in powdered form
C)Only liquid
13. In ultrasonic level gauge, the ultrasonic source is placed at the
A)Middle of the vessel containing the liquid
B)Bottom of the vessel containing the liquid
C)Far from the vessel containing the liquid
D)Top of the vessel containing the liquid
14. If the ambient temperature is doubled and pressure fluctuates, then the transmission time of radar through the air is
A)Almost unaffected and remains same
B)Decreases
C)None of these answers
D)Increases
15. In radiation methods, the detector system is located at
A)Outside a liquid filled tank
B)The top of the liquid filled tank
C)Middle of the liquid filled tank
D)The bottom of liquid filled tank
16. A vibrating level sensor consists of
A)One piezoelectric oscillators
B)Four piezoelectric oscillators
C)Three piezoelectric oscillators
D)Two piezoelectric oscillators
17. Contact devices used for the measurement of level are
A)More reliable then devices which does not make contact with the material
B)Less reliable then devices which does not make contact with the material
C)Less reliable then devices which makes contact with the material
D)More reliable then devices which makes contact with the material
18. Instrument which is capable of discriminating temperature differences of even 0.1 degrees Celsius is
A)Fiber-optic level sensors
B)Thermography
C)Vibrating level sensors
D)Laser method
19. In fiber-optic level sensors, the amount of light loss depends on
A)Amount of light which is reflected back
B)Amount of light which is not reflected back
C)The proportion of cable that is not in the liquid
D)The proportion of cable that is submerged in the liquid
The below list provides all the multiple-choice questions (MCQ) related to the level measurement.
1. In closed container type level measuring system, pressure at top of container is due to _____________
A)Liquid pressure
B)Atmospheric pressure
C)Vacuum pressure
D)Vapor pressure
2. Which of the following is correct for a level to force conversions?
A)Level difference should be gradual
B)Liquid at constant density distribution
C)Liquid should be highly viscous
D)Liquid with different density distribution
3. Which of the following conversions take place in float element?
A)Level to force
B)Level to displacement
D)Level to voltage
4. Contact devices used for the measurement of level are
5. A d/p cell used to measure liquid level has a “suppressed zero.”
This means:
A)The transmitter is located below the 0% liquid level mark
B)The elevation of the vessel is below sea level
C)The transmitter uses filter circuits to suppress noise to a zero level
D)The liquid is less dense than water
E)The transmitter is located above the 0% liquid level mark
6. In closed container type level measuring system, pressure at top of container is due to ______________
A)Liquid pressure
C)Vapor pressure
D)Vacuum pressure
7. Which of the following conversions take place in float element?
A)None of these answers
B)Level to force
C)Level to voltage
D)Level to displacement
8. In ______________ system, float whose weight greater than liquid to be displaced is used.
A)Inverse float system
B)Magnifying float system
C)Displacer system
9. Which of the following devices are used for a level to force conversion?
A)Membrane
B)Load cell
C)Voltmeter
D)Diaphragm
10. What will happen if the float becomes lighter?
A)System becomes less efficient
B)None of these answers
C)Density variations becomes more important
D)Density variations becomes less important
11. Suppose a storage vessel holds a liquid of unpredictable density.​
Identify which level measurement technology will not maintain accurate measurement of liquid height in the vessel as the liquid density changes:
A)Differential pressure transmitter
B)Guided-wave radar
C)Float and tape
D)Sightglass
E)Ultrasonic
12. Which of the following represents pressure of a liquid column with constant density?
B)ϱg
C)ϱh
D)ϱgh
13. Calculate the LRV and URV for this ΔP-based liquid level measurement system.​
Calculate LRV and UR
Calculate the LRV and URV of liquid level
A)LRV = 0” H2O ; URV = 360” H2O
B)LRV = 84” H2O ; URV = 444” H2O
C)LRV = 444” H2O ; URV = 0” H2O
D)LRV = 0” H2O ; URV = 444” H2O
E)LRV = 7” H2O ; URV = 37” H2O
14. A displacer-type level transmitter has a cylindrical displacer 30 inches long and 2.5 inches in diameter.​
When fully submerged in a petroleum fuel (Gf = 0.82), how much buoyant force will the displacer generate?
A)5.320 pounds
B)6.488 pounds
C)4.363 pounds
D)17.45 pounds
E)2.792 pounds
15. For float element, uniformity of density is important.
A)True
B)False
16. Diaphragm element is used for a level to pressure conversion.
A)True
B)False
17. The following liquid level switch will only function with liquids that are liquid level switch
question on liquid level switch
A)Optically transparent
B)Absolutely pure (i.e. not a solution)
C)In a state of laminar flow
D)Denser than water
E)Electrically conductive
18. Which of the following level-measurement technologies cannot be adapted to measure solid (powder) level in a vessel?
A)Displacer
B)Float and tape
C)Ultrasonic
D)Radar
E)Load cell
19. For float element, uniformity of density is important.
A)True
B)False
20. Which of the following represents pressure of a liquid column with constant density?
A)ϱh
B)ϱgh
D)ϱg
21. The main advantage of a “dip tube” or “bubbler” system for level measurement is that:
A)It compensates for changes in liquid density
B)It isolates the pressure transmitter from the process fluid
C)It can measure both solid and liquid levels
D)It always elevates and never suppresses the calibration range
E)It is less expensive to operate than a direct-connected transmitter
22. Which of the following represents correct relation for pressure in manometer type level measuring system?
A)​ϱmhm​– ϱy
B)(ϱm​​– ϱy)g
C)(​​ϱmhm– ϱy)g
D)(ϱmhm​​– ϱ)g
23. A guided-wave radar transmitter is able to measure liquid interface levels based on differences of between the two liquids.
A)Density
B)Speed of light
C)Dielectric constant
D)Ionization potential
E)Temperature
24. What will happen if the float becomes lighter?
A)Density variations becomes more important
B)System becomes less efficient
25. If the specific gravity of the liquid inside the vessel increases, what aspects of the transmitter’s calibration will we need to change in order to maintain accurate liquid level measurement?
liquid inside the vessel measure
A)We will need to change the transmitter’s LRV and URV
B)We will need to change the transmitter’s linearity and zero
C)We will need to change the transmitter’s linearity and span
D)We will need to change the transmitter’s LRV and linearity
E)We will need to change the transmitter from linear to square-root characterization, and adjust the zero
26. In ______________ system, float whose weight greater than liquid to be displaced is used.
A)Magnifying float system
B)Inverse float system
D)Displacer system
27. Diaphragm element is used for a level to pressure conversion.
A)True
B)False
Click Here for Answers
Next Quiz:
  • Transducers MCQ
  • RTD Questions & Answers
  • Measuring Instruments MCQ
  • Industrial Instrumentation MCQ
  • Distributed Control System MCQ
Flip Flop Circuits Objective Questions
Measurement of Resistance Objective Questions
Level Gauges Objective Questions and Answers – Instrumentation
Measurements & Instrumentation Quiz – Set 9
Industrial Instrumentation Quiz
Capacitive Transducers Objective Questions
Mechanical Systems Objective Questions
Electro Mechanical Systems Objective Questions
Thermography and Thermometry Objective Questions
High Frequency Amplifiers Objective Questions
Measurement of Errors Objective Questions
Components of Bourdon Tube – Questions and Answers
Sensors Objective Questions
250+ Electronic Measurements and Instrumentation MCQ Questions
Self Balancing Potentiometer Objective Questions
Comparators Objective Questions
Ionization Transducers Objective Questions
Sensors and Transducers Objective Questions
Pneumatic Control Mechanisms Objective Questions
Thermocouple Temperature Ranges
Thermocouple Temperature Range Questions and Answers
Level Measurement Objective Questions
Seismic Transducers Objective Questions
PWM Inverter Quiz
List of 100 Industrial Instrumentation Questions
List of 300 Industrial Instrumentation Questions
How Weigh Feeder Works
How Weigh Feeder Works ?
Intrinsic Safety of Instruments
Bernoulli's Principle
Bernoulli’s Principle and Equation – Flow Measurement
Process flow diagram examples
What is Process Flow Diagram (PFD) ?
Polyphase Induction Motor Multiple Choice Questions and Answers
200+ Polyphase Induction Motor Multiple Choice Questions and Answers
Why Restriction Orifice is some distance from Blowdown valve
Why Restriction Orifice is some distance from Blowdown valve ?
