An accessory specifically designed for a variety of field-mounted instruments including DP transmitters is the 2 inch pipe mounting bracket. Such a bracket is manufactured from heavy gauge sheet metal and equipped with a U-bolt designed to clamp around any 2 inch black iron pipe.
Holes stamped in the bracket match mounting bolts on the capsule flanges of most common DP transmitters, providing a mechanically stable means of attaching a DP transmitter to a framework in a process area.
The following photographs show several different instruments mounted to pipe sections using these brackets:
