Reading: Field Instrumentation Tips
Inst Tools > Blog > Common > Field Instrumentation Tips
Last updated: April 29, 2019 7:57 am
Common
2 Comments
6 Min Read
1. For RTD Pt 100 measurement,measure the resistance across the white and common terminal, then the temperature can be calculated simply by
Temp = (resistance measured across terminal minus 100)/0.385
or
Temp = (resistance measured across terminal minus 100)multiplied by 2.6
For example :
if the RTD resistance across white and red terminal is 126 ohm, then
the temperature measured is 26/0.385=67.53 degree centigrade or
26 multiplied by 2.6
26*2.6=67.53
This follow the same eqn, R=Rₒ(1+αT) remember that this is only applicable for PT 100 not other types
2.For calibration of -100 mmH2O to -10 mmH20 range capillary type using pressure pump not vacuum pump
The values for 25%, 50%, 75%, 100% are as follows:
0% is -100 mm h2o
25% is  -77.5 mm h2o
50% is -55 mm h2o
75% is -32.5 mm h2o
100% is -10 mm h2o
First find the Span=URV-LRV=-10+100=90
Then divide this by 4 as we are calibrating for 4 values namely 25%, 50%, 75%, 100%
i.e. 90/4=22.5
then the 4 points can be calculated as follows
0%(4ma)————-> 0 mm h2o i. e LP and HP open to atmosphere
25%(8ma)———–> -0+22.5=22.5 mm h2o (apply 22.5mmh2o to HP side not LP here LP is open to atmosphere.)
50%(12ma)——–> 22.5+22.5=44 mm h2o (apply 44mmh2o to HP side not LP)
75%(16ma)———> 44+22.5=67.5 mm h2o (apply 67.5 mmh2o to HP side not LP)
100%(20 ma)——> 67.5+22.5=90 mm h2o (apply 90 mmh2o to HP side not LP)
3.Calculation of flow m3/hr from differential pressure values mm h20 if both ranges are known:
We know that the flow equation is related as follows
Q=k√∆p
Here Q is the rate of flow: k is the Bernoulli’s constant; and ∆p is the differential pressure
Consider for instance the D.P. transmitter is of range 0 to 120 mm H2O and the DCS range of
0 to 1500 m3/hr
Then the next step is to find the Bernoulli’s constant
i.e. Q=k√∆p
1500=k√120 (here we consider span URV values to find Bernoulli’s constant)
k=1500/√120
k=136.936
Once we get Bernoulli’s constant we can calculate any flow rate if we know the D.P.
For e.g.
If differential pressure is 90 mmH2O
Q=k√∆p becomes
Q=136.936√90
= 136.936*9.486 = 1298.9 m3/hr
Thus we can calculate any flow rate if we know the transmitter and DCS range.
Or simply
Flow in DCS(present value) =(DCS range)√(Present DP value/DP range)
For example DCS range is 1000m3/hr,
DP range is 100 mmh20,
And present DP value in transmitter is showing 25 mmh2o,then
DCS flow will be
=1000√(25/100)
=1000√(1/4)
=1000*1/2
=500 m3/hr
4.For K type thermocouple (Chromel alumel) if the mV measured across yellow(positive) and red (negative) is x,then the temperature can be calculated as follows
Temperature = x/0.0397(millivolt measured divided by 0.0397) or x *25.2 (millivolt multiplied by 25.2)
for example if we measure the mV value across yellow and red terminal using a multimeter and found to be 0.397 then temperature can be calulated by
temperature=(0.397/0.0397)=10 degree centigrade or (0.397*25.2)=10 degree centigrade
5.calibration checking of capillary type LT if you dont have any instruments for checking
Suppose that a capillary type LT is mounted on a tank having range of -1200mmh2o as LRV and URV -60 mmh2o and you need to check whether the transmitter is Ok
We know that the transmitter is mounted with HP side to high pressure side and LP tapping to low pressure side,Firstly isolate the process line,vent and drain the process inorder to release any trapped pressure inside the flange.the transmitter will show 0% reading ie(-1200mmh2o),
Now measure the tap to tap length and mark the corresponding 25%,50%,75% and 100% level .Remove the LP flange of the transmitter(with HP flange of capillary intact) and keep it near(parallel) to HP tapping, the transmitter will show 100%.Now lift the LP capillary flange to 25% above from the HP tapping (where we marked before as 25%),now the transmitter will show 75% (not 25%)
Next keep the transmitter LP capillary flange at 50% marking the transmitter will show 50% reading.Similarly when we place at 75% the transmitter will be showing 25%
Finally if we place at 100% marking the transmitter should show 0% that is -60mmh2o
6.For most of the thermocouples the red terminal is considered as negative terminal(ANSI standard) and if red is not available then white terminal is considered as negative terminal(japan and IEC standards)
7.For pH analysers calibration can be done by supplying mV
58mV corresponds to 1 pH
so if we are calibrating for water whose pH is 7, the supplied voltage should be 58*7 mV=406mV.
Thus if 406mV is applied to pH transmitter it will show a reading of 7pH
Credits : kishore karuppa swamy
Understanding the Difference between HOP Test and OTDR
Difference Between NPT, BSPP and BSPT Seals
Measurement Unit Conversions
What is a Process Alarm? Types of Alarms
List of Cybersecurity Labs
Types of Air Conditioning Systems
2 Comments
  • Hardik Mungra says:
    August 22, 2018 at 1:46 pm
    Nice and very useful information
  • Mack Kelly says:
    July 25, 2019 at 10:25 am
    was owesome to me
Pressure Regulator with Flapper-Nozzle Principle
What is a Database Server? – Types, Comparison
Working of Air Compressor – Types – Control Techniques
Automation in Farming & Agriculture
Electrical Switches Principle & Types
Use of Isolator in Microwaves
Seismic Displacement Sensing Accelerometer
Thin Film Deposition Systems
What is a Thin Film Deposition System? How do they work?
Isometric Projection
Piping and Instrumentation Drawing (P&ID) Tutorials – Part 2
Reproducibility in Measurement
What is Reproducibility?
Optical Line Terminal
What is an Optical Line Terminal? – OLT Working Principle
How does the IIoT work - Industrial Internet of Things
How does the IIoT work? – Industrial Internet of Things
7 Marketing Strategies for Engineering Companies
Pneumatic Counter for Counting the Strokes of a Cylinder
Difference between Anode and Cathode
P&ID Guidelines for Pumps Heat Exchangers
Why is White Powder Used in Electrical Cables
Why is White Powder Used in Electrical Cables?
Basics of Electricity Rates
Valve Actuator Passing
Lessons Learned from Actuator Passing Incidents
Instrumentation Air System Design
Analog Electronics Objective Questions – Set 2
Power Systems MCQ Series 18
PLC Program Example - Signal Lamp Task
PLC Program Examples
