Reading: What is an Explosive Limit? – Lower Explosive Limit (LEL)
Inst Tools > Blog > Fire & Gas System > What is an Explosive Limit? – Lower Explosive Limit (LEL)
The Lower Explosive Limit (LEL) denotes the minimum gas concentration in the air necessary to ignite when exposed to a fire source.
Last updated: May 4, 2024 10:28 am
Fire & Gas System
6 Min Read
In an industrial environment, workers deal with gases around. These can be hazardous or non-hazardous. Most of them do not know the safety limits of working with these gaseous elements. One of them is inflammability.
What is an Explosive Limit?Lower Explosive Limit (LEL)How to determine the LEL for a given gas in the air?How to control flammable vapors and gases?
A gas tends to catch fire at certain properties or proportions. Not everyone can interpret, study, and take care of it, as it is complex. But usually, it is recommended for engineers and other higher-level operators to take care of that so that they can train the workers accordingly.
If not, then any untoward incident can happen in the industry. Two of the parameters related to inflammability are the lower explosive limit (LEL) and upper explosive limit (UEL). In this post, we will see the concept of a lower explosive limit.
First of all, let us understand what an explosive limit is. When a gas is present in the air, it can either become combustible or remain normal. To become combustible, it must have some proportion in the air. This proportion is called the explosive limit.
For example, a gas can have an explosive range of 5-60%. This means that if the gas is present in such proportion in the air, then it will catch fire. If it goes below or above the range, then it will not catch fire. This explosive limit determines the safety parameters of the plant which needs to be followed within.
Explosive Limit in Fire and Gas System
In the discussion earlier, it will be clear now what the lower explosive limit is. LEL is the minimum limit of concentration for a gas to be required in the air, to start igniting when it is given a fire source.
Below this limit, the gas will be too weak to start combustion. This limit varies for various gases and it depends on their properties. If it is required in a plant that the gas does not catch fire at minimum concentration, then this level must be maintained. Otherwise, if it goes above this, then it will catch fire if ignited. For this, mostly gas detectors and analyzers are used to measure the current concentration of the gas.
It is to be noted that these levels are mentioned in the safety data sheet of the gas. There, you can check it in its physical and chemical properties.
Calculating LEL is rather simple. You just need to know the volume of the gas. For example, it is found that 5% of the volume in the air of a particular gas will be LEL. So, to determine the LEL percentage, just divide 5% by 100% volume.
Suppose the 100% volume is 10%. So, divide 5 by 10, and the result is 50%. This means the LEL of that gas is 50%. So, if the gas is 50% occupied in the air, then it will catch fire if ignited.
Now that we know how important LEL is, we should know how to minimize the effect of the gas before it reaches LEL for ignition. We should properly place chemical or gas storage tanks in confined areas.
Basically, it should not be first of all within the reach of all employees. The staff must be properly trained by concerned persons on the effects of the gas, how it can catch fire, and how it should not be allowed to cross the limit of LEL. After this, it is recommended that only this trained staff be allowed to handle the gas and chemicals.
When working with gas like blowing, transferring, storing, mixing, or pumping, the staff must be well versed with the safety hazards and should strictly follow the training given to them to ensure that LEL is not crossed.
Also, as soon as it is found that LEL has been crossed, it must be ensured that the gas is given a safe discharge path outside the reach of personnel and the factory so that it does not get in contact with anyone. Also, due to this, the LEL gets reduced properly.
The storage containers must have a proper ventilation system for the gases to be removed properly. If there are any leakages, broken seals, or other issues, then the ventilation will not work properly. The most basic thing that I mostly forget while taking care is cleaning.
When cleaning or washing storage tanks, it must be ensured that the water does not touch any delicate or critical parts. There are many safety washing techniques to be followed so that any untoward leakage does not happen and LEL is not crossed.
  • What is the Upper Explosive Limit?
  • Why is LEL important in Gas Detection?
  • Troubleshooting PLC Automation Systems
  • LEL vs Percent By Volume vs Parts Per Million
  • Hydrocarbon Gas Detector Calibration Procedure
Argonite Fire Suppression System Working Principle
What is Lower Explosive Limit & Upper Explosive Limit ?
Gas Detection Excel Converters
Gas Detectors Interview Questions & Answers
What is a Fusible Plug? – Working, Advantages, Disadvantages
Fire and Gas System Loop Checks Procedure
Factors for Setting Alarm Levels on Toxic Gas Detectors
Types of Fire Detectors
Industrial Flame Detectors
What is Fire Alarm System?
Gas Detectors Installation Techniques
Beam Detectors Working Principle Animation
Fixed Temperature Heat Detector Working Principle
Fire Extinguishers Mock Test
Fire Pump
What is a Fire Pump? – Definition, Principle, Types, Comparison
Fire Alarm System Questions
Interview Questions on Fire Alarm System
Hydrogen Sulfide Gas Detector Calibration Procedure
Fire Detectors Working Principle
Basics of Fire Detection and Alarm System
Infrared Gas Detectors Principle
Infrared Gas Detectors Working Principle
Fire and Gas System Interview Questions & Answers
Quartzoid Bulb Detector Working Principle
Fire Water Sprinklers Working Principle
Fire-Triangle-in-Gas-Detection-System
Basics of Fire Detection System
electromechanical-level-measurement-working-principle
ElectroMechanical Level Measurement Working Principle
What is Chemical Vapor Deposition
What is Chemical Vapor Deposition? – The Ultimate Guide
Flare KOD
Flare Knockout Drums Working Animation
Example Ladder Logic Diagram
What is Relay Logic ?
Ultrasonic Sludge Blanket Level Meter Animation
Electrical Motors Interview Question And Answers
Piezo Electric Transducers Objective Questions
control-valves-classification
Types of Control Valves
