Reading: Electrical Switches Principle & Types
Inst Tools > Blog > Common > Electrical Switches Principle & Types
Electrical Switches have mechanical contacts or relays. Types of electrical switches are SPST, SPDT, DPST, DPDT and other custom designs.
Last updated: November 2, 2023 4:18 pm
Common Electrical Basics PLC Tutorials
Electrical Switches have mechanical contacts or relays. These types of switches can control a wider range of current and voltage options. They are not affected by dirt, mist, magnetic fields or temperature ranges from near absolute zero to 1000°.
Solid-state switchConfigurationPole/ThrowSingle Pole, Single Throw (SPST)Single Pole, Double Throw (SPDT)Double Pole, Single Throw (DPST)Double Pole, Double Throw (DPDT)
Electro-mechanical switches can adapt to misalignment in installation/application to ensure there is no leakage current and making it available in many circuitry, actuator, and housing styles.
Disadvantages include their price, limited contact life cycle, large size and slow response.
Solid-state switch
Solid-state switches are electric devices that do not have moving parts to wear out.
They are able to switch faster without sparking between contacts or problems with contact corrosion. Their disadvantages include a high cost to build in very high current ratings.
Also Read: Electrical Switches Animation
Configuration
When selecting a level switch, the user needs to determine if the electric circuit requires a normally open or normally closed switch.
Normally open (NO)
switches do not allow current to pass through in the free position. They need to “make” a contact to be activated.
Normally closed (NC)
switches allow current to pass through in the free position and need to “break” contact (open) to be activated.
Pole/Throw
Most switches have one or two poles and one or two throws, but some manufacturers will produce custom level switches for special applications. The number of poles describes the number of separate circuits which can pass through the switch at the same time.
The number of throws describes the number of circuits each pole can control. This is noted by the configuration of the circuit (NO/NC). Breaks are interruptions to the circuit caused by the separated contacts the switch introduces into each circuits it opens or interrupts in the circuit.
Single pole, single throw (SPST) switches make or break the connection of a single conductor in a single branch circuit.
They usually have two terminals and are referred to as single-pole switches
Single pole, double throw (SPDT) switches make or break the connection of a single conductor with either one of the two other single conductors. They usually have three terminals and are commonly used in pairs.
SPDT switches are sometimes called three-way switches.
Double pole, single throw (DPST) switches make or break the connection of two circuit conductors in a single-branch circuit. They typically have six terminals and are available in both momentary and maintained contact versions.
Double pole, double throw (DPDT) switches make or break the connection of two conductors to two separate circuits. They typically have six terminals and are available in both momentary and maintained contact versions.
Other types – Other, special throw types with more than two poles. Examples include switches that are designed to split loads into separate circuits (e.g., headlamp switch).
Also Read : Switches Terminology
  • Switch Types and Common Terminology
  • Basics of Temperature Switch
  • Relay Principle & its Types
  • Creating Custom Calibration Resistances
  • Switch Contact Normal State and Make/Break Sequence
What is Live Zero in 4-20 mA Current Loop?
PLC based Drink Dispenser System
PLC Digital Signals Wiring Techniques
Do’s and Don’ts in PLC
#11 PLC Best Practices – Instrument for Plausibility Checks
Robotic Process Automation (RPA) in AI – Market Growth & Business Benefits
ON and OFF a Group of Outputs by One Push button PLC Logic
Allen Bradley SLC 500 PLC Programming
How to Use Encode and Decode Instructions in PLC ?
PLC Program using START and STOP Buttons
Why do Teenagers want to be Entrepreneurs?
Two Hand Control Logic using PLC
Single-acting Pneumatic Cylinder Operation with Limit Switch
Magnetic Tape Recorder Principle
What is Magnetic Tape Recorder ?
Production Planning Software
PLC Programming for Automated Curtain Control
Automatic Curtain Control – PLC Programming Solution
PLC Programming Limit Switch
Basic Components of HVAC System
Wiring-Connection-from-PLC-to-Solenoid-Valves
How to Connect a Solenoid Valve with PLC?
Use Cryptographic checks for PLC
#5 PLC Best Practices – Cryptographic and Checksum Integrity Checks
PLC Program for Positive edge pulse output for one scan cycle
PLC Program for Positive Edge Pulse Output for One Scan Cycle
Tilt Level Switch Theory
Tilt Level Switch Working Principle
Percentage-to-Process-Variable-Conversion
Formula for Percentage to Process Variable Conversion
Convert-Process-Variable-to-Percentage
Convert Process Variable to Percentage
Difference between BDV and PSV
P&ID
Over Pressure Protection Devices
Control Loops
DC Machine
DC Machines Construction
