Reading: Electrical & Electronics Measurements Objective Questions – Set 1
Inst Tools > Blog > Electronics MCQ > Electrical & Electronics Measurements Objective Questions – Set 1
We prepared the top 30 Electrical & Electronics Measurements Objective Questions for your exam preparation to crack the competition tests.
Last updated: November 3, 2020 10:29 am
Electronics MCQ
3 Comments
3 Min Read
Test your knowledge with the 30 objective questions and answers on the Electrical & Electronics Measurements.
1. Piezoelectric effect is carried out in
A) crystal filter.
B) constant k prototype.
C) m derived.
D) composite filter.
2. Swamping resistance is used to compensate
A) none of the answers
B) error due to temperature true variations.
C) compensate error due to strong magnetic field.
D) both error due to temperature true variations and compensate error due to strong magnetic field.
3. The high torque to weight ratio in an analog indicating instrument indicates
A) low friction loss.
B) high friction loss.
C) none of the answers
D) nothing related to friction loss.
4. Which of the following is a variable displacement transducer?
A) synchros
B) potentiometer
D) tachometer
5. A galvanometer with a full scale current of 10 mA has a resistance of 1000 Ω.
The multiplying power (the ratio of measured current to galvanometer current) of 100 Ω shunt with this galvanometer is
A) 100.
B) 11.
C) 110.
D) 10.
6. _______ is used to measure the flow of air around aeroplane.
A) Wheatstones.
B) Schering.
C) Hays.
D) Desautys.
7. When checked with an ohm meter an open resistor reads
A) infinite.
B) low but not zero.
C) high but within tolerance.
D) zero.
8. Resistance of a VARISTOR varies with
A) Candela
B) Steradian
C) Radian
D) Degree
9. Potentiometer method of DC voltage measurement is more accurate than direct measurement using a voltmeter because
A) It loads the circuit moderately.
B) It does not load the circuit at all.
C) It uses centre zero galvanometer instead of voltmeter.
D) It loads the circuit to maximum extent.
10. Relative permittivity can be measured by _______ bridge
A) Both Voltage and Temperature
B) Voltage
C) Current
D) Temperature
All 30 questions and answers are available in the Quiz.
Instrumentation Quiz
Take All Tests
      • Electrical & Electronics Measurements Set 1
      • Electrical & Electronics Measurements Set 2
      • Electrical & Electronics Measurements Set 3
      • Electrical & Electronics Measurements Set 4
      • Electrical & Electronics Measurements Set 5
      • Electrical & Electronics Measurements Set 6
Top 250 Electronic Circuits Objective Questions and Answers
Electronic Devices & Circuits Quiz – Set 5
Electronic Devices & Circuits Quiz – Set 12
Circuit Control Devices Multiple Choice Questions & Answers
Electronic Devices & Circuits Quiz – Set 2
3 Comments
  • Kajal says:
    November 28, 2018 at 7:20 pm
    How to see answer
  • Svn says:
    April 5, 2020 at 10:54 pm
    How to check ans
    • S Bharadwaj Reddy says:
      April 6, 2020 at 10:12 am
      Answer the Questions (click on the expected answer option), it will show you the answers.
Top 300 Solid State Devices Objective Questions and Answers
Electronic Devices & Circuits Quiz – Set 15
Top 300 Electricity and Magnetism Questions & Answers
Types of Relays – Questions and Answers
Electronic Devices & Circuits Quiz – Set 10
Electrical & Electronics Measurements Objective Questions – Set 4
Basic Electronics Questions and Answers
Electronic Devices & Circuits Quiz – Set 16
Circuit Protection Devices Questions
Circuit Protection Devices Objective Questions and Answers
Electrical Switch Questions and Answers
Top 50 Electrical Switch Questions and Answers
Electronic Devices & Circuits Quiz – Set 7
Top 300 Electrical Circuits Objective Questions and Answers
Electronic Devices & Circuits Quiz – Set 6
Electrical & Electronics Measurements Objective Questions – Set 2
Vacuum Tubes Multiple Choice Questions and Answers
Electronic Devices & Circuits Quiz – Set 4
SCADA Multiple Choice Questions
Practical Control Systems Questions & Answers - 2
Practical Process Control System Questions & Answers – 2
Instrumentation Engineer Interview Questions
Interview Questions on PID Controllers
Digital Control Systems
Z-transform Analysis of Sampled-Data Control Systems
CNC Programming - Definition, Types, and Tips
CNC Programming – Definition, Types, and Tips
Types of Scan Time in a PLC
#16 PLC Best Practices – Create Trend for Cycle Time on HMI
Three Phase Converter Test Questions
Digital to Analog Converters Objective Questions
