Reading: DP Master System Configuration in PLC
Inst Tools > Blog > PLC Tutorials > DP Master System Configuration in PLC
Last updated: March 4, 2021 2:41 pm
3 Min Read
Write the PLC program for the DP master system configuration in PLC.
DP Master SystemConfiguration:
DP Master System
DP Master System
In this example, we will configure the DP master system using Simatic manager. For example purpose, we will configure PLC and create a DP master system for the DP communication.
When you configure the DP master system in the software, the software will configure the DP master line automatically. DP slave can be added from the hardware catalog on the DP master line.
DP slave modules or devices can be added as per requirement on the DP master bus. DP master system is used for Profibus communication between the slave device and the master system.
For example purpose, here we have taken S7-300 PLC as a master system and IM module as a slave device.
Configuration:
First Configure CPU 315-2 PN/DP from the hardware catalog for DP master system. Once the hardware is created, the DP master system line will be created automatically.
By clicking on the DP master bus, the property of the DP master system can be modified as per the requirement as shown in figure 2.
DP master bus
Now right click on DP master and add a new object. From hardware, the catalog selects the DP slave system (for example take IM 153-1) as shown in figure 3.
Profibus DP Master
Double click on the IM module to open DP slave property setting as per the requirement as shown in figure 4.
DP Slave address in Simatic Software
If more IM module in the system, we can add as per the above procedure. As shown in figure 5, you can see one more IM module on the DP master bus.
The slot numbering system will be the same as per the S7-300 system. Hence actual I/O modules will start from slot 4 as shown in figure 6.
Siemens Slot numbering system
Note:- This is the simple DP master system configuration, we can use this concept in other examples also.
Author: Bhavesh
Maintenance of PLC’s
Engineering Logic Diagram
STEP 7 PLC programming
PLC Modbus Communication
Comparison Instruction in PLC
Actuator Sensor Interface (ASi) Protocol in PLC
Conveyor Sorting System with Color Detection PLC Logic
Design a PLC program for Operational Sequence of Packaging Process
Can a PLC Function Without an HMI or SCADA?
Turbine-Compressor System Architecture
How to Install GSD File in Step 7 PLC using Simatic Manager?
Wet Contacts and Dry Contacts in PLC Systems
Structured Text PLC Programming for Two-Tanks Level Application
Analog Measurement using Ladder Logic
Difference between Compact PLC and Modular PLC
Types of Digital Outputs in PLC
How to Connect PLC with SCADA System via OPC UA?
Tia Portal – Different Instances of Calling a Function Block
DDE Protocol
What is the DDE Protocol?
Conditional Jump instruction
Jump Instruction in Siemens Tia Portal
Types of Allen Bradley PLC
Structured Text in PLC: Parking Information Systems
Free WinCC SCADA Training Course
Free SCADA Training Course
LIFO Instruction in Allen Bradley PLC Programming
LIFO Instruction in PLC
Online PLC Ladder Logic
Mis-conceptions of PLC Ladder Logic
Scan cycle of a Siemens PLC
OB1 – Main Cyclic Organization Block in TIA Portal
Why Grounding
Basics of Grounding
Dip Tube Type Level System
Questions on Dip Tube Type Level System
Diagnosing the Electric Motor Circuit
Diagnosing Electric Motor Circuit
What is an RTD
Components of RTD
Remote User Authentication
Security of Industrial Automation Systems
Modern Industrial Joystick Controls
Installing and Using Modern Industrial Joystick Controls
Top PLC Manufacturers
PLC Brands Software Information
Transformer Operation Under No-Load
