Reading: What is a Disc Valve ?
Inst Tools > Blog > Control Valves > What is a Disc Valve ?
Last updated: March 21, 2019 4:24 pm
Control Valves
1 Min Read
Disc valves (often referred to as eccentric disk valves, or as high-performance butterfly valves) are a variation on the butterfly design intended to improve seat shut-off.
The disc’s center is offset from the shaft center-line, causing it to approach the seat with a “cam” action that results in high seating pressure. Thus, tight shut-off of flow is possible even when using metal seats and disks.
Disc Valves
The following photograph shows the body of a Fisher E-plug control valve, with the disk in a partially-open position:
Disc Check Valves are recommended after traps discharging into closed systems to guarantee Non return or no reverse flow. These check valves can be mounted between pipe flanges in any direction.
DCVs feature a compact and rugged stainless steel design and are suitable for any process liquid & gas, apart from steam.
Disc Check Valves are designed to be sandwiched between flanges i.e. wafer type. They are suitable for use on a wide range of fluids for applications in process lines, hot water systems, steam and condensate systems etc.
Also See : Butterfly Valve Animation
Spring and Diaphragm Pneumatic Actuators
When to choose Full Bore Valve or Reduced Bore Valve ?
What is Lift Check Valve ?
How Gate Valves Work ?
What is Directional Control Valve (DCV)?
Valve Technician Interview Questions
Common Terms Used in Control Valves
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Control Valve Preventive Maintenance
Short Notes on Different Valve Types
What is a Pilot Valve? When do we use a Pilot Valve?
Types of Failures in Control Valves
cavitation-control valve trim
What is Control Valve Cavitation ?
self-operated pressure regulating valve
Working Principle of Self Operated Valves
Deluge Valve Operation using Solenoid Valve Animation
Pneumatic Actuators Types Animation
Types of Pneumatic Actuators Animation
Single Port Globe Valve
How Sliding Stem Valves Work ?
SMART Control Valve Positioner
Electronic Valve positioners
PISTON CHECK VALVE THEORY
Valve Materials Comparison Notes
Programmable Logic Controller Practice Tests
Induced EMF
Magnetic Circuits
Battery Interview QuBattery Interview Question and Answersestion and Answers
Battery Terminology
PLC Program for Trash Compactor
Relay Permissive and interlock circuits
Draw a ladder logic to switch ON-OFF a bulb using a toggle switch
Draw a Ladder Logic to switch ON-OFF a Bulb using a Toggle Switch ?
Selecting A Pneumatic Manifold
How to Select a Pneumatic Manifold
Control System Basic Wiring Practice Animation
PLC Connection between Instrument, Junction Box, Marshalling & System Cabinet
