Reading: Difference between Signal Cables and Control Cables
Inst Tools > Blog > Electrical Basics > Difference between Signal Cables and Control Cables
Signal cables are used for data or signal transmission while control cables are used to control devices to the machinery they control.
Last updated: July 24, 2023 10:35 am
Electrical Basics PLC Tutorials
In industrial automation systems, both signal cables and control cables carry information between the control system and field devices but have different purposes and characteristics.
Signal CablesControl CablesDifference between Signal Cables and Control Cables
Signal Cables
Signal cables are used to carry low-level electronic signals between devices or within a device. These can include data signals, such as Ethernet or Fieldbus communication, or they can be low-voltage analog or digital signals, like 4-20mA current loops, or 0-10V signals. The main function of these cables is to relay information, not to deliver power or actuate machinery.
Signal cables typically have several characteristics designed to maintain the integrity of the signals they carry, including:
  • Shielding: To protect against electromagnetic interference (EMI) which could degrade the signal.
  • Twisted pairs: To reduce the influence of external interference and to minimize cross-talk between signals in different pairs in the same cable.
  • Lower current carrying capacity: These cables are designed for signal transmission rather than power delivery.
Control Cables
Control cables are used in industrial automation to connect control devices like PLC (Programmable Logic Controllers) to the components they control, such as motors, valves, actuators, etc. These cables can carry higher currents and voltages, as they are often used to deliver the power that actuates a device or machine.
Control cables usually have these features:
  • Higher current carrying capacity: These cables are designed to carry the current needed to control machinery or devices.
  • Can be shielded or unshielded: Depending on the environment and the specific requirements of the application, control cables may also be shielded to protect against EMI.
  • Might have multiple conductors: Control cables often have multiple conductors to allow for multiple control or power connections to be made with a single cable.
The main difference between signal and control cables lies in their purpose: signal cables are used for data or signal transmission while control cables are used to connect control devices to the machinery they control, typically delivering the power to actuate those machines.
In the below table, we discussed the comparison between signal and control cables.
DetailsSignal CablesControl Cables
PurposeTransmit low-level electronic signals or data.Connect control devices to machines they control.
Type of ConnectionConnect devices for data or signal transmission.Connect devices for control or power delivery.
Current Carrying CapacityLower, since they are for signal transmission.Higher, since they are used to power or control devices.
ShieldingTypically shielded to protect against EMI.Can be either shielded or unshielded.
Conductor ConfigurationOften uses twisted pairs to reduce interference.May have multiple conductors for multiple connections.
  • Single Core and Multi-Core Cables
  • Difference Between HV and LV Cables
  • Types of Cables in Industrial Automation
  • Instrumentation Cables Testing Steps
  • Flame Resistant and Retardant Cables
  • Materials in Instrumentation Cables
Top Free PLC Software
PLC based Metro Automation Project
Contacts and Coils in PLC Ladder Logic
What is the OPC Server?
How to Use the Shift and Rotate Instructions in PLC?
Remote Factory Acceptance Test
  • Joseph Kevin Raju says:
    December 4, 2023 at 1:01 pm
    Hi,
    I believe there is a mistake in the terminologies used and the explanations provided. Control i.e. Process Control Cables are used to communicate signals – be they analog or digital or Modbus or F.O. from DCS or PLC or even an LCP to or from instruments, analyzers, Indicators, Recorders etc.
    Electrical cables (usually LV) on the other hand deliver power from the source, which can be an MCC or PDB to motors, pumps, valves etc. Instruments are usually loop-powered, eliminating the need for a separate power supply transferred through a separate set of cables.
    I believe an article on Digital vs Analog control cables will be useful, as this platform is mainly focused on the Instrumentation side of things.
    Thanks.
How to Create Templates in FactoryTalk View Studio?
Transformer Testing – Routine Tests of Transformers
PLC Programming Example with Pushbutton and Motor
Use of Isolators and Barriers in Electrical Panel
Single-acting Pneumatic Cylinder Operation with Limit Switch
How-to do Security of SCADA Systems?
PLC Pump Control
PLC Pump Control: 10 seconds ON & 20 seconds OFF
Advantages of Three Phase System Compared to Single Phase System
What is Electrical Panel Door Earth Bonding? Explained
Learn PLC Programming
Basics of Ladder Diagram in PLC Programming
Electrical Power Grid Automation
Siemens Tia Portal Function Block
Function Blocks in PLC (FBs) – What You Need To Know?
Convert Raw Counts to Engineering Units
Raw Counts to Engineering Units : Conversion Formula
PLC Programmer Tools
Difference between Soft Starter and VFD
PLC-based mail box automation
PLC Program for Mailbox with Letter Counting & Light Indicators
Three-Phase Wye Wiring System
4-Wire, Three-Phase Wye Wiring System
neutral-grounding-practice-in-power-system
Neutral Grounding Practice in Power System
PID Controller Bumpless Transfer
What is PID Controller Bumpless Transfer ?
Absorption Instrumentation Questions & Answers
3 Phase Bridge Inverter MCQ
Hydrostatic Level Measurement
