Reading: Difference Between NEMA and IEC Motors?
Inst Tools > Blog > Electrical Basics > Difference Between NEMA and IEC Motors?
In this article, we will learn the difference between NEMA and IEC electrical motors used in industrial applications.
Last updated: October 17, 2023 1:56 pm
Electrical Basics
Difference Between NEMA and IEC MotorsEase of functionMechanical DifferencesAssembly of ProductsElectrical DifferencesConclusion
Every product that is used in the market has to follow a certain standard that has been set for that range of products to function. If you want to sell your product in the market, it must have the stamp authority of the standard which is set for that type of product.
Without the standard rating, it would be impossible for the product to run in the market. In this post, we will see the product of electrical motors.
Motors run in two electrical standards –
  1. NEMA and
  2. IEC.
NEMA stands for National Electrical Manufacturers Association.
IEC stands for International Electrotechnical Commission.
Basically, NEMA is majorly used in North American markets and businesses relating to North America. But, IEC is used in most parts of the world. Both have set a certain slot of standards for an electrical motor to run in the market.
Without their ratings, no one will purchase a motor. That’s because that motor has not been approved by any standard and no one knows how it will function.
Let us see some differences in these two standards:
Ease of function
NEMA motors are very easy to select as they are just categorized on the basis of voltage and horsepower.
But, IEC motors go into deep detail for your selection. Many parameters like motor load, duty cycle, full load current, etc. are categorized so that the user who deeply knows a motor can select it accordingly.
Mechanical parameters too play an important role in differentiating both these motors.
Traditionally, NEMA motors are stronger in this department as compared to IEC motors. They have a wide range of enclosures as compared to IEC motors.
Also, they differ in frame size, shaft height, and usage of grease in it. The shaft seal usage is more in IEC motors as compared to NEMA motors.
NEMA products are easy to assemble as compared to IEC motors. Mostly, NEMA motors are fully assembled and sold. Only certain products like starters (contactors) allow for some components like thermal units to be swapped.
But, IEC products mostly come in separate components like contactors, auxiliary blocks, overload relay, etc.
But, NEMA motors have an open design; so safety covers are mostly required as compared to IEC motors where they are relatively safer in design and don’t require any cover.
Both these motors have their corresponding design standards in inrush current allowance, torque design, and slippage.
The main difference between them is the hysteresis they allow for voltage and frequency.
NEMA motors allow a tolerance of +-10 % at rated frequency and voltage; while IEC motors allow a tolerance of +-5 % at rated frequency and voltage.
The duty cycle operation of IEC motors is much more flexible than NEMA motors. You can operate the IEC motor in a more flexible way with varying periods and load/speed changes than a NEMA motor.
Conclusion
These are some of the general differences mentioned between these two motors. Overall, if you want to choose a simple, easy-to-select product; then NEMA is your choice.
But, if you want to go deeper in motor selection criteria with much perfection and according to your customized needs, then IEC is your choice.
  • What is Electrical Busbar?
  • Working of Air Compressor
  • What is Electrical Slip Ring?
  • High-Speed Counters in PLC
  • Safety Barrier in PLC System
Why V/f Ratio is kept Constant in VFD?
Difference Between Overcurrent and Overload
What is a Ground Rod?
Electrical Feeder Automation in Smart Grid
How to Check the Continuity of Protective Conductors?
What is a Capacitor Bank?
What is an Inductor? – Types of Inductors
Difference between Power Cables and Signal Cables
How to Operate a Group of Induction Motors using PLC Logic?
Download Electrical Enclosure Book
How does an Electric Motor Operate? – AC Motor Fundamentals
What is Electrical Slip Ring? Principle, Types, Advantages, Applications
Automatic Motor Forward and Reverse Control using Timer
What are Ground Fault and Earth Fault?
Motor Protection Relay
Motor Protection Circuits
Arc Protective Clothing
What is Arc Protective Clothing? – Importance, Features, Materials
Motor Star Delta Connections
simple latching motor control circuit
Motor Control Circuit Wiring
Three phase induction motor nameplate
How to Size a Cable for Industrial AC Motors?
Difference Between AIS and GIS Panels
Types of Filters used in Air Compressors
How Do Air Compressor Filters Clean and Protect the System?
Electrical Voltage and current Signals
Sample Raw DataSheet for Pressure Calibration
Open Channel Flow Measurement Animation
Open Channel Flow Measurement Principle
Electrical Ground Loop
How to Solve Electrical Ground Loop Problems?
Insulation Resistance Test
What is an Insulation Resistance Test? – Types, Applications
Barrier & Sensor Connection with NAMUR
Why we use NAMUR Output Sensor?
Single-Phase Half Wave AC-DC Converter MCQ
Saybolt Viscometer
Saybolt Viscometer
Basics of Emergency Shutdown System
Emergency Shutdown System Philosophy
