Reading: Difference Between Core and Shell Transformers
Inst Tools > Blog > Electrical Basics > Difference Between Core and Shell Transformers
In this post, we will learn the difference between core and shell transformers used in electrical engineering industries.
Last updated: September 28, 2022 3:42 pm
Electrical Basics
What is a Core Type Transformer?What is a Shell Type Transformer?Difference between Core and Shell Transformers
A transformer is an electrical device which is used to change voltage range; either increasing it to a certain level or decreasing it to a certain level. It is one of the most basic components used in an electrical network.
Voltage conversion is necessary because you cannot always apply the same input voltage to any device. Every instrument has it’s own set of power requirement and it varies from instrument to instrument.
Now, based on construction, two types of transformers are generally used – core and shell. In this post, we will see the difference between core type and shell type transformers.
A core type transformer is the one in which the primary and secondary windings encircle the core of the transformer. Refer to the below image.
As you know, a transformer has two types of windings – primary and secondary. Voltage is transferred from primary to secondary windings through magnetic flux.
The windings in this figure are mounted on the core of the transformer. Core is the metallic layer which conducts magnetic field and can also be termed as the main body of the transformer.
So, in this type of transformer, the windings are surrounding the core. That is why, they are called as core type transformer. The part where the winding is done is also known as the limb. Both the windings are mounted on separate limbs of the core. As you can see, there is only single flux path in the circuit.
Also, it is to be noted that two types of windings are present on each of the primary and secondary ones – low voltage (LV) and high voltage (HV). In the below image, green one is LV winding and red one is HV winding.
Transformer LV winding and HV winding
LV winding is placed near the core and HV winding is overlapped on the LV winding. As you can see, there is not a single core; but multiple layers of core. They are called as laminations.
A shell type transformer is the one in which the core of the transformer encircles the windings. Refer to the below image.
In this type of transformer, the core is surrounding the primary and secondary windings. That is why, they are called as shell type transformer.
Both the windings are wound on a central limb of the core. As you can see, there is two flux paths in the circuit. The central limb carries the whole magnetic flux; and the other two side limbs carry half of the flux.
HV and LV winding mounting is same as discussed earlier in core type transformers. The red winding in the second image below is primary and the green winding is secondary winding.
Shell Transformer
The following are the key differences between core and shell transformers.
  • The main general difference is that in core transformer, the windings surround the core; whereas in shell transformer, the core surrounds the winding.
  • Core type is more compact and smaller in size as compared to a shell type.
  • Winding protection is more safer in shell type than in core type, due to it’s construction.
  • The cross section area of core type is rectangular, but that in shell type is square shape.
  • Core type has two limbs as compared to shell type which has three limbs.
  • Core type has only one magnetic flux path as compared to shell type which has two paths.
  • Core type has more losses as compared to shell type, so output is better in shell type.
  • Due to separate limbs for the windings, core type is easy to repair and troubleshoot as compared to shell type.
  • The mechanical strength of core type is less as compared to shell type.
  • Core type is used for high voltage applications like autotransformers and power transformers. Shell type is used for low voltage applications like transformers in an electronic circuit.
  • Cooling is better in core type, because the windings are directly exposed to atmosphere, as compared to shell type ones.
In this way, we understand the difference between core type and shell type transformers.
What is the LBB Protection Relay? (Local Breaker Backup)
VFD Pros and Cons – Variable Frequency Drives
Advantages of Valve Regulated Lead Acid (VRLA) Batteries
Siemens Standard Drives Application Handbook (PDF)
Residual Current Circuit Breaker (RCCB)
What is a Megger? Principle, Advantages, Disadvantages, Applications
What is an Electrical Conduit? – Types – How to Choose?
What is a Damper? Types of Dampers in HVAC
Difference Between Isolator and Circuit Breaker
What is an Oil Separator in HVAC?
Basics of Electrical Transformer
Dahlander Motors – Principle, Advantages, Disadvantages
Electrical Cabinet Air Conditioner – Enclosure Cooling, Maintenance
Motors Inrush Currents
Motor Inrush Current Measurements
Circuit Breaker Making Capacity
automatic changeover switch explained
Automatic Transfer Switch – Electrical Circuit, Operation, Video
Electrical Equipment Selection in Hazardous Area
Lightning Arrester Basics and Terminology
Difference between Soft Starter and VFD
Difference Between AIS and GIS Panels
Hydraulic Motor Forward and Reverse Control with Simulation
Quiz on Sensor Transducer
Submersible Pump
What is a Submersible Pump? Principle Advantages Disadvantages
Digital Electronics Objective Questions – Set 1
Parameters of SRT_DINT instruction
Tia Portal – OB20 Time Delay Interrupt Organization Block
What is a Power Transformer
What is a Power Transformer? – Components and Types
Calibration Standards
Practical Calibration Standards
Measurement of Voltage Objective Questions
