Reading: Differential Pressure Transmitter with 5 Way Manifold Valve
Inst Tools > Blog > Practical Questions > Differential Pressure Transmitter with 5 Way Manifold Valve
Last updated: November 13, 2020 7:33 pm
Practical Questions Pressure Measurement
2 Min Read
Some differential pressure transmitters are equipped with 5 way valve manifolds. These valve networks allow for blocking, equalizing, and bleeding of the transmitter’s two pressure ports, the valves being arranged in this pattern:
Differential Pressure Transmitter5 Way Manifold Valve
Shown using standard P&ID symbols – instrumentation equivalent of an electrical schematic diagram – the transmitter and manifold arrangement looks like this:
5 Way Manifold Valve Schematic Diagram
Identify the normal, operating valve positions (open/closed) for a five-valve manifold. Describe the proper sequence of manifold valve operation to successfully prepare the transmitter for removal from the process.
Why do you think we have such things as 5-valve manifolds? What can be done with this manifold that cannot be done with a three-valve manifold?
Answer:
Normal valve positions:
  • Both block valves open.
  • Both equalizing valves closed.
  • Vent valve closed.
Removing differential pressure transmitter from service:
  • Close one block valve.
  • Open both equalizing valves (which one first does not matter).
  • Close the other block valve.
  • Open the vent valve.
  • Tag all valves, notifying of transmitter’s planned return time/date.
  • Disconnect the transmitter from the manifold.
Restoring the transmitter back to service is as simple as reversing all the steps taken to remove it from service (i.e. go through the list backwards, doing the reverse of each instruction).
Difference between 5-valve manifold and 3-valve manifold?
One feature that 5-valve manifolds provide over 3-valve manifolds is the ability to route a vent tube to a remote (safer) location, for use with particularly hazardous process fluids.
5-valve manifolds allow for in-place transmitter calibration, provided one of the ∆P transmitter’s sides has an atmospheric vent. By connecting the calibrating pressure source to the vent line, one can route the calibrating pressure to either side of the transmitter (only), while keeping the other side vented.
  • Instrument Hook Up Diagram
  • Instrumentation and Control MCQ
  • Pressure Gauge Datasheet
  • Temperature Controller Problem
  • Pressure Measurement MCQ
Credits: Tony R. Kuphaldt
Heat Exchanger Differential Pressure Transmitter
Liquid Level Measurement using Pressure Transmitter Questions
How to Connect Proximity Switch (Source Type) to Make LED ON ?
Pressure Gauge Cocks
Smart DP Transmitter Flow Meter Calculations
  • Ajay Kumar says:
    June 14, 2020 at 8:00 pm
    Dear sir,
    How to calibrate or zeroing of DPT with 5-way manifold.
Problem on Weigh feeder
Pneumatic Level Transmitter Calibration Table
Hydrostatic Pressure Measurement Questions
Determine the Status of Lamps and Relays in the Circuit ?
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Which Instrument is at Fault in this System?
Identify Solenoid Valves Energized or de-energized?
Process Switches Normal Status
Pressure instruments example circuit
Motion-Balance and Force-Balance Instruments
statuses of all lamps and relay coils in the circuit
Analyze the Relay Circuit and Find the Status ?
Pressure Gauges with Diaphragm Sensor Principle
Which instrument is faulty
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Which Tube has most Hydrostatic Pressure
Which Tube has most Hydrostatic Pressure?
Why are Impulse Lines often Installed in a Sloping Manner (Angle)
Why are Impulse Lines often Installed in a Sloping Manner?
Pressure gauges with capsule elements
Pressure Gauges with Capsule Sensor Principle
Calculate Power in Parallel RC Circuit
Synchronous Motors Quiz
belt conveyors principle
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
What is Gear Box Backlash
What is Gear Box Backlash ?
Voltmeter Calibration
Calibration Procedure of Voltmeter and Ammeter
Contact less Tachometer
Types of Tachometers – Mechanical and Electrical Tachometers
Use of line reactors
Fiber Optic Cable - Method of Joining and Fusion Splicing
Fiber Optic Cable – Method of Joining and Fusion Splicing
