Reading: Determine Resistance value of Resistors
Inst Tools > Blog > Practical Questions > Determine Resistance value of Resistors
Last updated: January 20, 2020 11:30 am
Practical Questions
2 Min Read
Determine the nominal resistance values of these resistors, given their band colors, and also express the allowable tolerance in ohms (i.e. what the minimum and maximum acceptable resistance values are for each resistor given its advertised tolerance).
Determine Resistance value of ResistorsSolution:
For example, a 25 kΩ resistor with a 10% tolerance rating would have an allowable tolerance of +/- 2.5 kΩ.
1. Red, Org, Blu, Gld =
2. Brn, Blk, Grn, Sil =
3. Blu, Blk, Brn, Gld =
4. Yel, Vio, Red, Sil =
5. Grn, Brn, Yel =
6. Wht, Blu, Blk, Sil =
7. Gry, Grn, Org, Gld =
8. Org, Org, Gld =
9. Vio, Red, Sil, Gld =
10. Brn, Red, Blk, Sil =
Solution:
  • Red, Org, Blu, Gld = 23 MΩ, +/- 1.15 MΩ
  • Brn, Blk, Grn, Sil = 1 MΩ, +/- 100 kΩ
  • Blu, Blk, Brn, Gld = 600 Ω, +/- 30 Ω
  • Yel, Vio, Red, Sil = 4.7 kΩ, +/- 470 Ω
  • Grn, Brn, Yel = 510 kΩ, +/- 102 kΩ
  • Wht, Blu, Blk, Sil = 96 Ω, +/- 9.6 Ω
  • Gry, Grn, Org, Gld = 85 kΩ, +/- 4.25 kΩ
  • Org, Org, Gld = 3.3 Ω, +/- 0.66 Ω
  • Vio, Red, Sil, Gld = 0.72 Ω, +/- 0.036 Ω
  • Brn, Red, Blk, Sil = 12 Ω, +/- 1.2 Ω
Credits: Tony R. Kuphaldt
  • Resistor Colour Codes
  • Identify Instruments in P&ID
  • Smart HART Transmitter
  • Alarm Annunciator Circuit
  • Electric Motor Circuit
Programmable Logic Controller (PLC) Questions and Answers – 9
Identify Solenoid Valves Energized or de-energized?
Why Pressure Vessel Connected to Tubing System?
Calculate the 0%, 50%, and 100% Calibration Points
Air Pressure Regulator Questions
Calculate the Thermocouple Output millivolts
  • Undefined says:
    January 15, 2020 at 1:23 pm
    trick
    BB Roy great britain very good wife
Determine the functions of Pressure Switches ?
Air Pressure Inside the Tank
Questions on Pneumatic Control Loop
DP transmitter Elevated 10 Feet above the Vessel
Stripper Overhead Temperature Control System
Baffle Nozzle Question
Identify the Purpose of Flow Ratio Controller
Allen-Bradley MicroLogix 1000 PLC
Questions on Allen-Bradley MicroLogix 1000 PLC
pressure switch control two lamps wiring
Draw Wiring of a Pressure Switch to control two lamps
Thermocouple Questions
Thermocouple Terminal block Questions
A Question on Density Gauge
three-phase motor control circuits
How Overload Heaters used to Automatically Shut the Motor OFF ?
Hydrostatic level transmitter Formula
Hydrostatic Level Transmitter Questions
liquid flow control system
Practical Process Control System Questions & Answers – 7
Allen-Bradley MicroLogix 1000 controller
PLC Switch Actuation Status
Why Three-phase Voltage is 440 Volts
Why Three-phase Voltage is 440 Volts?
Process Control & Instrumentation Objective Questions – Set 1
Functional Block Diagram in PLC for Oil and Water Process
Ultrasonic Flow meters Working Animation
Ultrasonic Flow Meters Animation
Tuning a Liquid Level Process Control Loop - 1
Rotating Magnetic Field Multiple Choice Questions
What is HIPPS System in Oil and Gas
What is HIPPS System in Oil and Gas?
P&ID Guidelines for Storage Tanks
