Reading: Components of MCB – Electrical Engineering Questions
Inst Tools > Blog > Electrical MCQ > Components of MCB – Electrical Engineering Questions
Explore in-depth questions on the components of MCB to check your knowledge in electrical engineering and circuit breakers.
Last updated: August 31, 2024 8:08 pm
Electrical MCQ
9 Min Read
Components of MCBWhat component in an MCB is responsible for detecting overloads?Which component of an MCB helps in extinguishing the arc formed during tripping?What is the primary function of the magnetic coil in an MCB?What role does the tripping mechanism play in an MCB?Which part of an MCB provides insulation between the internal components and the external environment?What component in an MCB is responsible for rapidly disconnecting the circuit in the event of a short circuit?How does the bimetallic strip in an MCB detect an overload condition?Which component ensures the MCB can be safely reset after tripping?What is the primary material used for the casing of an MCB?Which component in an MCB is used to manually turn the circuit breaker on and off?What part of an MCB moves to make or break the connection?Which MCB component serves as the main point for power entry?Which component in an MCB ensures secure mounting in a electrical panel?What is the function of the plunger in an MCB?Which component of an MCB holds the arc chutes in place?What is the role of the outgoing terminal in an MCB?What ensures the proper alignment and function of the bi-metallic strip in an MCB?Which MCB component provides visual feedback on the status of the breaker?Which part of an MCB is responsible for holding the internal components together and providing insulation?What component in an MCB can be used to release the breaker manually (in some models)?What is the primary function of the internal wiring in an MCB?Which part of an MCB ensures that contacts remain properly aligned and connected?What component in an MCB resets the breaker to its original position after tripping?Which part of an MCB provides a secure foundation for all the internal components?What component in an MCB can be used to adjust the tripping characteristics?What is the function of auxiliary contacts in an MCB?How does the spring mechanism contribute to the functioning of an MCB?What is the primary purpose of the insulating material in an MCB?What function does the solenoid serve in an MCB?What role does the latch play in the operation of an MCB?Which component in an MCB moves to physically separate the contacts when tripping?
Components of MCB
This electrical engineering video focuses on the detailed explanations for the MCB components related questions.
Components of MCB - Electrical Engineering Devices
Question 1
A. Tripping mechanism
B. Magnetic coil
C. Arc chute
D. Bimetallic strip
Show the Answer
Bimetallic strip
Question 2
A. Magnetic coil
B. Arc chute
C. Operating lever
D. Arc strip
Show the Answer
Arc chute
Question 3
A. Detecting short circuits
B. Operating the manual switch
C. Extinguishing arcs
D. Detecting overloads
Show the Answer
Question 4
A. Interrupting the circuit
B. Connecting to the load
C. Detecting short circuits
D. Manual operation
Show the Answer
Question 5
A. Casing
B. Magnetic coil
C. Tripping mechanism
D. Arc chute
Show the Answer
Casing
Question 6
A. Magnetic coil
B. Tripping mechanism
C. Bimetallic strip
D. Arc chute
Show the Answer
Magnetic coil
Question 7
A. By generating a magnetic field
B. By manual operation
C. By bending due to heat
D. By cooling the arc
Show the Answer
Question 8
A. Operating lever
B. Magnetic coil
C. Arc chute
D. Bimetallic strip
Show the Answer
Operating lever
Question 9
A. Metal
B. Rubber
C. Plastic
D. Glass
Show the Answer
Plastic
Question 10
A. Solenoid
B. Latch
C. Plunger
D. Knob/Handle
Show the Answer
Knob/Handle
Question 11
A. Incoming Terminal
B. Fixed Contact
C. Dynamic Contact
D. Arc Chutes
Show the Answer
Dynamic Contact
Question 12
A. Outgoing Terminal
B. Incoming Terminal
C. Bi-metallic Strip Carrier
D. Din Rail Holder
Show the Answer
Incoming Terminal
Question 13
A. Mounting Base
B. Safety Barriers
C. Arc Chutes Holder
D. Din Rail Holder
Show the Answer
Din Rail Holder
Question 14
A. Extinguishing arcs
B. Insulating the contacts
C. Detecting overloads
D. Operating the tripping mechanism
Show the Answer
Question 15
A. Bi-metallic Chutes Holder
B. Solenoid
D. Plunger
Show the Answer
Arc Chutes Holder
Question 16
A. Extinguishing the arc
B. Detecting short circuits
C. Connecting to the power source
D. Connecting to the load
Show the Answer
Question 17
A. Arc Chutes Holder
B. Plunger
C. Din Rail Holder
D. Calibration Screw
Show the Answer
Calibration Screw
Question 18
A. Plunger
B. Indicator Window
C. Solenoid
D. Incoming Terminal
Show the Answer
Indicator Window
Question 19
A. Housing/Casing
B. Plunger
D. Safety Barriers
Show the Answer
Housing/Casing
Question 20
A. Plunger
B. Release Lever
C. Incoming Terminal
D. Arc Chutes Holder
Show the Answer
Release Lever
Question 21
B. Providing electrical connections
D. Holding components
Show the Answer
Question 22
A. Fixed Contact
B. Arc Chutes Holder
C. Indicator Window
D. Spring Mechanism
Show the Answer
Fixed Contact
Question 23
A. Solenoid
C. Plunger
D. Spring Mechanism
Show the Answer
Spring Mechanism
Question 24
A. Mounting Base
B. Indicator Window
C. Solenoid
Show the Answer
Mounting Base
Question 25
B. Arc Chutes
C. Solenoid
Show the Answer
Calibration Screw
Question 26
A. Offering additional signaling or control functions
B. Detecting overloads
C. Providing electrical insulation
D. Extinguishing arcs
Show the Answer
Question 27
C. Operating the tripping mechanism
D. Resetting the breaker
Show the Answer
Question 28
A. Providing electrical insulation
B. Extinguishing arcs
Show the Answer
Question 29
A. Detecting overloads
B. Creating a magnetic field for tripping
C. Manually resetting the breaker
D. Holding the contacts in place
Show the Answer
Question 30
A. Resetting the breaker
B. Holding the breaker in the “on” position
D. Cooling the contacts
Show the Answer
Question 31
A. Fixed Contact
B. Plunger
C. Dynamic Contact
D. Operating Mechanism
Show the Answer
Plunger
  • Star Delta Starter Circuit Diagram
  • What is Vacuum Circuit Breaker?
  • DOL Starter Principle & Applications
  • Read an Electrical Single Line Diagram
  • Residual Current Circuit Breaker (RCCB)
Permanent Magnet DC Motor (PMDC) Questions
200+ Transformer MCQ – Multiple Choice Questions
Electrical Machines MCQ Series 4
DC Generators Objective Questions and Answers
Power Systems MCQ Series 17
Electric Circuits Objective Questions – Set 11
Synchronous Machines Flux and MMF Phasors Questions
Synchronous Machine Stability Questions
illumination Multiple Choice Questions and Answers (MCQ)
Electrician Tools MCQ Questions
Electromagnetic Field Multiple Choice Questions
Alternators Multiple Choice Questions
100+ Quiz on Electrical Circuits and Control
DC Machines Efficiency and Testing Quiz
Electrical Machine Multiple Choice Questions
Electrical Machines MCQ Series 20
Alternator Voltage Regulation Quiz
Reluctance Motor Quiz
Motor Losses and Efficiency Quiz
DC Generators Characteristics Quiz
Power Systems MCQ Series 10
Switchgear & Protection Objective Questions and Answers
Center Tap Full-Wave Rectifier
Full-Wave Rectifier Circuit
Coriolis Mass Flow meter as a Multi Variable Transmitter - 2
Coriolis Flowmeter Advantages and Limitations
Pressure Gauge Accessories
Batch Mixing with PLC Ladder Logic Program
PLC Latched Circuit Example
PLC Latching Function
Transistor as Switch Working Animation
How a Transistor Switch Works
Top 100 Microcontrollers Project Ideas
4-20mA Image
4-20mA Graphical Calculations
