Reading: What is Complementary Split Range Control (CSRC)?
Inst Tools > Blog > Control Valves > What is Complementary Split Range Control (CSRC)?
Complementary split range control (CSRC) is a method where multiple control elements work together to regulate a single process variable.
Last updated: September 18, 2024 4:55 am
Control Valves PLC Tutorials
In industrial applications, there are times when a single control valve will not be able to control a process parameter like temperature or flow. In such applications, precision and high resolution of the process parameter is a must.
Complementary Split Range ControlCSRC ProcessAdvantages of CSRC control
But here, a single control valve will not be able to maintain such a requirement. So, there arises a need to use multiple control methods for a single process variable. In instrumentation, this method is called complementary split range control. In this post, we will see the concept of CSRC.
The complementary split range control (CSRC) is a process where multiple control elements are employed and work in tandem to control a single process variable. The main thing to note here is that the control elements work in opposite directions with each other.
Suppose there are two valves in a system, designed to control a single flow meter. In this case, if one valve is fully open, then the other will remain fully closed. In a case where the valve is analog, if one valve is 25% open, then the other valve will be 75% open.
In this complementary manner, the valves will coordinate with each other and control the final process. What is the main advantage of this? If one valve is allowed to pass one type of media and the other valve the other media, then when one valve is closing, the other valve will open simultaneously. It means that a proportional flow of media will flow to the final process.
Due to this, a proper mixture of media will always be maintained in the process. If there was a single valve, then it would have taken time for the media to settle its parameter; because the valve would either open or close only. CSRC thus controls a process parameter accurately and with fine resolution.
CSRC Process
Consider a tank where a liquid is filled. The temperature of the liquid must be maintained accurately by the flow of hot and cold water. For both these types, two types of analog valves are used where one will pass hot water and the other valve will pass cold water. When one valve will open, the other valve will close, and vice-versa.
A PID controller will control both outputs inversely. At a desired cold setpoint, when one valve will start to open to pass cold water, the other valve will start to close to pass less hot water. Both the valves will be locked at a desired percentage to then pass an accurate amount of water mixture in the tank.
Similarly, at a desired hot setpoint, when one valve will start to open to pass hot water, the other valve will start to close to pass less cold water. As the setpoint is changed by the user, both the valves will work simultaneously and inversely to control the exact water temperature by maintaining proper water mixture flow.
  1. As we saw, different types of media can be controlled in an inverse manner, which ensures a desired percentage of media presence, thus controlling the process parameter accurately.
  2. As the control elements work in a balanced way and avoid any full opening or closing at their best, the safety levels are high in this control. Due to this, the process can run smoothly without any safety hazards.
  3. With the multiple control elements, you can diversify your product by bringing in variations. And because these variations are under safe operation, business output too increases.
  4. Because the control elements are operating in inverse conditions, sudden jerks, mechanical imbalances, and process imbalances are reduced to a great extent.
  5. You can use CSRC control for redundancy too. This means if there are two valves, only one valve will operate at a time. The other valve will switch over in case of failure of the first valve.
In this way, we saw the concept of complementary split range control.
  • What is a Split Range Control Loop?
  • Types of SCADA System Architecture
  • SCADA and PLC Configuration Systems
  • Control Valve Sequence Methods
  • Split Range Control using Ladder Logic
PLC Valve Control Ladder Logic Programming
Value Assignments in SCL Language – Single, Multiple, Combined
Solenoid Valve Problems and Solutions
How to Configure an Alarm in InTouch SCADA?
Heating and Mixing of Products using PLC Example Tutorial
How to use Master Control Reset (MCR) Instruction in PLC
Control Algorithms in PLC Programming
How to Solve On-Off Valve Problems?
Exclusive Control Valve Sequence
Pneumatic Training Course – Download PDF
Pressure Relief Valve Principle
PLC offline data of a project are compared
Compare Two Offline PLC Projects
valve trim characteristics
Control Valve Trim Characteristics
Volume Booster Working Principle
Control Valve Volume Booster Working Principle
What is a Servo Valve?
What is a Servo Valve? – Principle and Advantages
Needle Valve Body Design
What is Needle Valve ?
Pump and Mixer Operations Example PLC Timer-Based Control
Pump and Mixer Operations Example: PLC Timer-Based Control
Switched Mode Power Supply (SMPS)
Car Wash Program using Functional Block Diagram (PLC)
Filters in Compressors
Electronic Devices & Circuits Quiz – Set 2
Circuit diagram of Liquid level measurment using Adruino C
Level Measurement and Control using Arduino C
How to Design a Motor Faceplate in Graphics - SCADA Tutorials
Resistor-Color-Code-Chart
Resistor Color Code Animation
Siemens PLC Force LED
Forcing and Modifying PLC Logic
Electrostatic Precipitator
Principle of Operation of an Electrostatic Precipitator
Beta ratio ( β )
Important Factors in Flow Measurement
