Reading: How to Communicate with Excel from RsLinx?
Inst Tools > Blog > PLC Tutorials > How to Communicate with Excel from RsLinx?
I am using RsLogix 500 here to communicate with Rslinx to write the data from PLC to excel. You can also use RsLogix 5000.
Last updated: March 4, 2021 11:21 am
3 Min Read
There are times in which we want to acquire all our PLC’s data into a spreadsheet to get a clear view or something.
Now let’s see How we can communicate with Microsoft Excel from RsLinx to write the data to excel?
I am using RsLogix 500 here to communicate with Rslinx. You can also use RsLogix 5000 also.
Now I will create a sample program in Rslogix 500 to communicate with Excel.
TON Timer in Rslogix 500
I have created a Reset timer for 20 seconds. Basically, the timer runs for 20 seconds and resets itself and runs again endlessly.
The communication protocol we are gonna use here is the Dynamic Data Exchange or DDE protocol.
Training: Allen Bradley PLC
Now let’s got to Rslinx, First of all, create a communication driver Emu-500 for running the program in an emulator.
Now go to DDE/OPC then click on the topic configuration.
A dialog box opens up as shown below.
RSlogix 500 to communicate with Excel
The driver we created will be shown on the right side of the box Click on the Plc icon that is shown. The Model of the processor changes automatically to the program that we created on Rslogix 500.
After clicking on the PLC icon click new to create a topic. So when we now create a topic it will be associated with the processor we clicked that is Micrologic 1200 here.
ControlLogix PLC to Excel Read Values
We have created a topic Excel and press yes to update it.
Now we will go and download the program in Rslogix 500 and change the processor to run mode.
Now create a workbook in Excel and now we have to activate the DDE command through Excel.
DDE command in Excel
Just Click randomly on any cell and write the formula, The syntax is as follows,
= Application Name|Topic Name!’TagName,L1,C1.
So for the application, I created here the function for activating DDE protocol Goes like this,
=RSLINX|Excel!’T4:0.ACC,L1,C1’
After Pressing enter since the program is in run mode the value of the accumulator in timer will instantly be updated here. The value changes as the timer run.
Export Live Analog values from PLC to Excel
The above is our final Output. We can use this for many creative projects, Like where we have to visualize the data in real-time like that.
Author: Abishek D
  • InTouch SCADA to Excel
  • FIFO Instruction in PLC
  • Advantages of RTO Timer
  • Scaling for Analog Input
  • Configuration of Alarms
PLC Fault Diagnosis – PLC Training Documents
Basic Pumping System Application Used in Industrial Automation
PLC Programming for Weight-Based Packaging
OB1 – Main Cyclic Organization Block in TIA Portal
Difference Between Wifi and Industrial Wireless
Example PLC Program to Control a Pump based on Level Sensors
Safety PLC Coding Practices – Programming Recommendations
What is an RTU? – Remote Terminal Unit
PLC Controlled Conveyor and Weighing with Labeling Automation
Sequential PLC Programming for the Pneumatic Valves
Allen Bradley SLC 500 PLC Programming
PLC control 4 machines with 1 button
CX-Programmer Tutorial: 1 Button To Activate 4 Different Machines
Marking Machine
PLC SCL Program for Marking Machine
Top 100 PLC Objective Questions and Answers
Remote Factory Acceptance Test
Network Switch
Yokogawa DCS
Yokogawa DCS and SIS System Architecture
PLC FBD Example for Tank Liquid Heating Control by Steam Flow
Encode and Decode Instructions
How to Use Encode and Decode Instructions in PLC ?
Search tank in Intouch Scada
Tank Filling and Emptying using Intouch Scada Script
Programmable Logic Controller (PLC) PLC Maintenance Check Points
Programmable Logic Controller Maintenance Check Points
How to Create Faceplate in FactoryTalk View Studio
How to Create Faceplate in FactoryTalk View Studio?
Top 300 Arduino Projects for Engineering Students
DCS Quiz
DCS Quiz
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
pneumatic piston actuator
Working Principle of Pneumatic Actuators
Instrumentation Transmitter
Instrumentation Common Measurement Issues
