Reading: Common Valve Abbreviations in US Engineering Drawings
Inst Tools > Blog > Control Valves > Common Valve Abbreviations in US Engineering Drawings
Familiarize yourself with frequently used valve abbreviations in US engineering drawings for engineers and technicians in process industries.
Last updated: September 20, 2024 11:29 am
Control Valves Instrumentation MCQ
11 Min Read
Common Valve AbbreviationsWhat does “BB” stand for in valve terminology?In valve terminology, what does “BC” represent?What does “BV” stand for in valve terminology?The abbreviation “BWE” in valve terminology refers to what?What does “CV” stand for in valve terminology?In valve terminology, what does “CWP” mean?What does “DD” stand for in valve terminology?In valve terminology, what does “DI” stand for?What does “DWV” stand for in piping and valve terminology?In valve terminology, what does “FE” stand for?What does “FF” stand for in valve terminology?In valve terminology, what does “FLG” represent?What does “FP” stand for in valve terminology?The abbreviation “FTTG” in valve terminology refers to what?What does “FW” stand for in valve terminology?In valve terminology, what does “HF” mean?What does “HW” stand for in valve terminology?What does “IBBM” stand for in valve terminology?In valve terminology, what does “IPS” represent?What does “ISRS” stand for in valve terminology?The abbreviation “GV” in valve terminology refers to what?What does “MJ” stand for in valve terminology?In valve terminology, what does “NPS” mean?What does “NPT” stand for in valve terminology?The abbreviation “NRS” in valve terminology refers to what?What does “OWG” stand for in valve terminology?In valve terminology, what does “PRV” mean?What does “RF” stand for in valve terminology?The abbreviation “RJ” in valve terminology refers to what?What does “RP” stand for in valve terminology?In valve terminology, what does “RS” stand for?What does “RWD” stand for in valve terminology?What does “SB” stand for in valve terminology?In valve terminology, what does “SE” represent?What does “SOV” stand for in valve terminology?The abbreviation “SW” in valve terminology refers to what?What does “SWE” stand for in valve terminology?What does “TB” mean in valve terminology?What does “TE” stand for in valve terminology?The abbreviation “TC” in valve terminology refers to what?What does “SWP” stand for in valve terminology?In valve terminology, what does “UB” mean?What does “UC” stand for in valve terminology?The abbreviation “WOG” in valve terminology refers to what?What does “WWP” stand for in valve terminology?
This video provides explanations for these common valve questions and answers.
Common Valve Abbreviations in US Drawings: Quiz Yourself
Question 1
A. Blind Bonnet
B. Ball Bearing
C. Bolted Base
D. Bolted Bonnet
Show the Answer
Bolted Bonnet
Question 2
A. Bearing Cap
B. Bolted Cap
C. Base Cover
D. Ball Cap
Show the Answer
Bolted Cap
Question 3
A. Bearing Valve
B. Base Valve
C. Ball Valve
D. Butterfly Valve
Show the Answer
Ball Valve
Question 4
A. Base Weld End
B. Bolted Wedge End
C. Butt Weld End
D. Ball Weld End
Show the Answer
Butt Weld End
Question 5
A. Circular Valve
B. Control Valve
C. Check Valve
D. Choke Valve
Show the Answer
Check Valve
Question 6
A. Compressed Water Pressure
B. Constant Working Pressure
C. Current Working Pressure
D. Cold Working Pressure
Show the Answer
Question 7
A. Dual Disk
B. Double Disc
C. Direct Drive
D. Double Diameter
Show the Answer
Double Disc
Question 8
A. Ductile Iron
B. Differential Indicator
C. Double Insulation
D. Direct Injection
Show the Answer
Ductile Iron
Question 9
A. Dual Water Vent
B. Drain, Waste, Vent
C. Drain Water Valve
D. Direct Water Valve
Show the Answer
Drain, Waste, Vent
Question 10
A. Flexible End
B. Fast End
C. Flange End
D. Full End
Show the Answer
Flange End
Question 11
A. Flat Flange
B. Flange Face
C. Flat Face
D. Full Face
Show the Answer
Flat Face
Question 12
A. Flange Guide
B. Flange
C. Full Gasket
D. Flexible Gasket
Show the Answer
Flange
Question 13
A. Flat Plate
B. Flange Port
C. Flexible Pipe
D. Full Port
Show the Answer
Full Port
Question 14
A. Flange Tension Gasket
B. Fitting
C. Flexible Tension Guide
D. Fastening Tool
Show the Answer
Fitting
Question 15
A. Flange Width
B. Full Width
C. Flexible Wedge
D. Fixed Wedge
Show the Answer
Flexible Wedge
Question 16
A. Heat Fuse
B. Heavy Force
C. High Flow
D. Hard Faced
Show the Answer
Hard Faced
Question 17
A. Heavy Weight
B. Handwheel
C. Heat Weld
D. High Width
Show the Answer
Handwheel
Question 18
A. Iron Base Brass Mount
B. Iron Body Bronze Mounted
C. Iron Bound Bronze Metal
D. Internal Brass Bearing Mount
Show the Answer
Question 19
A. Iron Pressure Seal
B. Iron Pipe Size
C. Internal Pressure System
D. Industrial Pipe Standard
Show the Answer
Iron Pipe Size
Question 20
A. Internal Stem Rotary Seal
B. Inside Screw Rising Stem
C. Iron Screw Rotating Seat
D. Internal Seat Rising Screw
Show the Answer
Question 21
A. Gas Valve
B. General Valve
C. Gate Valve
D. Globe Valve
Show the Answer
Gate Valve
Question 22
A. Metal Jacket
B. Multi-Joint
C. Mechanical Joint
D. Metric Joint
Show the Answer
Mechanical Joint
Question 23
A. Normal Pressure Seal
B. Nominal Pressure Standard
C. Nominal Pipe Size
D. National Pipe Standard
Show the Answer
Nominal Pipe Size
Question 24
A. Nominal Pressure Tolerance
B. National Pipe Taper Thread
C. National Pipe Thread
D. Non-Pressure Thread
Show the Answer
Question 25
A. Non-Return Spring
B. Normal Rising Stem
C. Non-Rising Stem
D. Nominal Rotating Seal
Show the Answer
Non-Rising Stem
Question 26
A. Over Water Gauge
B. Open Water Gasket
C. Oil, Water, Gas Pressure
D. Oil and Water Gate
Show the Answer
Question 27
A. Pressure Relief Vent
B. Positive Return Valve
C. Pressure Retention Valve
D. Pressure Reducing Valve
Show the Answer
Question 28
A. Raised Flange
B. Round Flange
C. Raised Face
D. Recessed Face
Show the Answer
Raised Face
Question 29
A. Rotating Jacket
B. Raised Joint
C. Ring Type Joint
D. Round Joint
Show the Answer
Ring Type Joint
Question 30
A. Rotating Plug
B. Raised Plate
C. Reduced Port
D. Ring Port
Show the Answer
Reduced Port
Question 31
A. Ring Seal
B. Rotating Stem
C. Rising Stem
D. Rotating Screw
Show the Answer
Rising Stem
Question 32
A. Raised Wedge Design
B. Resilient Wedge Disc
C. Resilient Washer Device
D. Rotating Wheel Disc
Show the Answer
Question 33
A. Steel Bonded
B. Soldered Base
C. Solid Brass
D. Silver Brazed
Show the Answer
Silver Brazed
Question 34
A. Steam End
B. Steel Enclosure
C. Screw End
D. Solder End
Show the Answer
Solder End
Question 35
A. Steam Operated Valve
B. Shut Off Valve
C. Safety Overflow Valve
D. Sealed Outlet Valve
Show the Answer
Shut Off Valve
Question 36
A. Solid Wedge Disc
B. Soldered Wedge
C. Screw Weld
D. Sealed Wedge
Show the Answer
Solid Wedge Disc
Question 37
A. Solder Welded End
B. Sealed Water Entry
C. Steel Water End
D. Socket Weld End
Show the Answer
Socket Weld End
Question 38
A. Threaded Bonnet
B. Threaded Base
C. Tight Bonnet
D. Tapered Bore
Show the Answer
Threaded Bonnet
Question 39
A. Tight End
B. Threaded End
C. Threaded Entry
D. Tapered End
Show the Answer
Threaded End
Question 40
A. Tapered Coupling
B. Tight Connection
C. Threaded Collar
D. Threaded Cap
Show the Answer
Threaded Cap
Question 41
A. Solid Water Pressure
B. Standard Water Pressure
C. Steam Working Pressure
D. Sealed Water Pipe
Show the Answer
Question 42
A. Union Bonnet
B. Union Base
C. Under Bonnet
D. Upper Base
Show the Answer
Union Bonnet
Question 43
A. Upper Chamber
B. Unidirectional Coupling
C. Union Cap
D. Under Cut
Show the Answer
Union Cap
Question 44
A. Wide Operating Gate
B. Water, Oil, Gas Pressure
C. Welded Outlet Gasket
D. Water Orifice Gauge
Show the Answer
Question 45
A. Water Working Pressure
B. Wide Water Passage
C. Water Welded Port
D. Welded Water Pipe
Show the Answer
  • Solenoid Valves Terminology
  • Pressure Relief Valve Terminology
  • Proportional Valve and Servo Valves
  • Control Valve Stem Packing Replacement
  • Control Valve Installation & Maintenance
250+ Electronic Measurements and Instrumentation MCQ Questions
Working of Rupture Disk
Basics of Actuators
SIS Final Control Elements
Electro Mechanical Systems Objective Questions
High Frequency Amplifiers Objective Questions
What is Swing Check Valve ?
Gyroscope Objective Questions
Frequency Measurement Objective Questions
Ultrasonic Sensors Objective Questions
Special Control Valves
ESDV : How it Works ?
Bridge Circuits Objective Questions
Electrical Actuators
Top 100 Power Plant Engineering Objective Questions & Answers
Nano Instrumentation Objective Questions
Pressure Safety Valve Leak Test Procedure
Pressure Safety Valve Leak Test Procedure (PSV Testing)
Non-variable reducing valves
What is Reducing Valve ?
Solenoid Valve Troubleshooting
Solenoid Valve Troubleshooting Tips
Split-Range, Auto-Selector Ratio, And Cascade Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
Tie rods double acting cylinder
What is a Pneumatic Cylinder?
pilot operated relief valves
Pilot-operated Relief Valve Principle
PLC datasheet
How to Read the PLC Datasheet? – Important Notes About PLC
Purpose of Isolation valve
What are Isolation valves? – Purpose, Types, Configurations
resistor-color-coding-example
IEC labelling for Resistors Color Code
Types of Heat Exchangers
Mechanical Temperature Indicators (MTI) Problem
Electronic Devices & Circuits Quiz – Set 9
Hydrogen Sulfide Accident
The Aghorn Hydrogen Sulfide Accident – H2S Gas
Digital Control Valve (DCV) Calibration Procedure
