Reading: Choke Valve Hydro Testing Procedure
Inst Tools > Blog > Control Valves > Choke Valve Hydro Testing Procedure
In this article, we will learn about the procedure for hydro testing of a choke valve with a Haskel pump in the oil and gas industries.
Last updated: October 17, 2023 1:56 pm
Control Valves
Tools & TacklesFittings RequiredInstruments RequiredManpower RequiredChoke Valve Hydro-test SetupAssembly SetupChoke Valve Inlet Side AssemblyChoke Valve Outlet Side AssemblyHaskel Pump Setup DrawingChoke Valve Hydro Testing Procedure
The choke valves are used to control the flow of fluids coming from the wells in oil & gas industries.
Here we use a high-pressure “Haskel Pump” for hydro testing the choke valve. This pump operates with the help of instrument air. The Haskel pump needs an instrument air as input and generates high-pressure hydraulic output. The pump output pressure depends on the value of input instrument air. The Haskel pumps are commonly used in wellhead control panels (WHCP) in the oil and gas industries.
Tools & Tackles
  1. Ring spanner – 55 : 2no’s (stud bolts at reducer assembly)
2. Ring spanner – 46 : 2no’s (stud bolts at reducer & blind assembly)
3. Ring spanner – 1” (for choke valve actuator disassembly)
4. Brass hammer – 1no.
5. Big adjustable – 1no.
6. Chain block -1 Tonne or above.
Fittings Required
1.     ¾” F to 3/8” F and ¾”M to ¾”M auto clave fitting for connecting high-pressure hose to connect choke valve inlet side (or) ¾” NPT(M) to 3/8” NPT(F) high-pressure fittings
  1. High pressure (20,000 PSI) Haskel pump
2. High pressure (15,000 PSI) gauge with 3/8” F fitting.
3. ½”AFR with a hose for Haskel pump input supply
4. ¾” hose for inlet water supply
5. 3/8” high-pressure hose for connecting choke valve with inlet supply.
Manpower Required
1. Master flow vendor.
2. Instrument engineer for coordinating and doing job with vendor support.
3. Instrument technicians (2 No’s) for assisting the job
4. Roustabouts (4 Nos) for assembling & disassembling stud bolts, lifting valve & providing chain block.
The below images shows the hydro test setup for the choke valve with the Haskel pump.
Assembly Setup
Choke Valve Hydro Test Setup
Choke Valve
choke valve calibration
Haskel Pump Tubing
The below-mentioned steps describe the detailed procedure for hydro testing of Choke Valve in an offline safe area in the offshore platform (oil and gas).
Take the proper work permit and inform about the activities to the control room.
1. Prepare the area for hydro testing.
2. Barricade the area and notify hydro test is in progress.
3. Connect the 15000lb. Class spool assembly with threaded entry blind flange in the inlet and blind flange in the outlet.
4. Connect Haskel pump set up in the inlet of the choke valve.
5. Connect a 15000 PSI pressure gauge at the outlet of the choke valve.
6. Keep choke valve in the fully open position by rotating manual override stem.
7. Allow water into the valve body and start pressurizing slowly by throttling Haskel pump discharge pressure.
8. Isolate Haskel pump after reaching 15000psi pressure in the choke valve body and observe the performance for 15 mins.
9. Depressurise the valve body and remove all connections.
Author: Pardha Dharmaraju
  • How to Install a Control Valve?
  • How to Select Directional Valves
  • Solenoid Valve Manual Reset
  • 5 Port 2 Position Valve Working Principle
  • Flow Control Valves Interview Questions
Control Valves Pre-Commissioning Checklist
Basics of Butterfly Valves
What is a 4-way Solenoid Valve?
How to Protect Pumps from Cavitation? – Reasons, Solutions
Level Control Valve with Horizontal Float
Applications of Needle Valves
Control Valve in Nutshell – Valve Design and Selection Factors
Different Types of Control Valve Actuators
Calculate Control Valve Stem Position
Locked Open (LO) and Locked Closed (LC) Valves
Valve Actuator Bench Set
Classification of Control Valves
Control Valve Cavitation and Flashing
List of Valve Standards
Gate Valve Parts
What is Gate Valve ?
Pneumatic Training Course - Download PDF
Pneumatic Training Course – Download PDF
Types of Control Valves Noise
Direct operated (direct acting) solenoid valves
Solenoid Valves Types & Functions
Triple-offset Butterfly Valves
Butterfly Valves – Concentric, Double-offset, and Triple-offset
Valve Leakage Tests
Types of Valve Leakage Tests
Electropneumatic Valve Positioner Working Principle
Electro Pneumatic Valve Positioner Schematic & Principle
Two SOV Connections
Two Solenoid Valves Working Principle
toroidal conductivity probe principle
Electrodeless Conductivity Probes Principle
Fieldbus Flow Transmitter Calibration
100 Instrumentation Projects for Final Year Engineering Students
Infrared Gas Detectors Principle
Infrared Gas Detectors Working Principle
memory types in siemens plc
#13 PLC Best Practices – Disable Unused Communication Ports
diode-limiter-principle
Diode Limiters/Clippers Operation
Encoder Principle
Encoder Working Principle
Network Switch
