Reading: Check Block Consistency Tools in Simatic Manager
Inst Tools > Blog > PLC Tutorials > Check Block Consistency Tools in Simatic Manager
Last updated: March 4, 2021 11:54 am
2 Min Read
This article is about the use of the check block consistency tool using Simatic manager.
The check block consistency tools are used to check the interface conflicts within a data block, function block, and user-defined blocks.
Let’s learn how to check and use the check block consistency tool with some programming block.
Step 1:
Open Simatic manager. Open an existing project or create a new one.
Here I will show you blocks of the plant programming and will check faulty block using block consistency tools.
Step 2:
In the block section, do right click and select check block consistency tools as shown in the below window.
Checking Block Consistency
Step 3:
Click on tools that will open up a new window.
Simatic Manager Block Consistency Tools
Step 4:
Now, click on the icon as shown in the below window. Which will only show the conflict block with a red sign or yellow sign.
Siemens Block Tools
The red sign indicates blocks that are not compiled and the yellow exclamation mark shows the conflict in the block.
Step 5:
To know what symbol indicates, simply choose any block and press “F1” to know the symbol and its meaning.
Step 7 Block Consistency Tools
Step 6:
To solve the problem, click on the “Compile All’ icon as shown in the below window.
Compile Siemens Project
Now, close the tools and open it again and conflicts are solved.
Author: Suhel Patel
  • RSLogix 500 PID Instruction
  • Allen Bradley Powerflex VFD
  • InTouch SCADA Security
  • PID in Siemens TIA Portal
  • Ladder Logic & Statement List
How to Convert Current to Voltage using Resistor ?
#11 PLC Best Practices – Instrument for Plausibility Checks
Omron PLC Timer Example Explained
What is Sequential Function Chart (SFC?)
Down Counter PLC Program
PLC Ladder Logic Example based on Set Coil and Reset Coil
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
Importance of Grounding Electronic Equipment
What is Contextual HMI? – HMI Screens on a Mobile or Tablet
What is a Dry Contact? – Basics of PLC Wiring
3 Phase Motor Control using PLC Ladder Logic
PLC Program for Star Delta Motor Starter
Motor Clock Wise Operation using PLC
CW and CCW Operation of Motor from Same Push button
Global Data Blocks in PLC
What is a Data Block? Global Data Blocks in PLC
Scaling in PLC
PLC Ladder Logic for Sensor Scaling with Offset
SR Flip Flop Logic
How to implement SR Flip Flop using PLC Ladder Logic
Siemens Profibus Interface DP
How to Create New Project Using Simatic Manager
How to Delay a Sensor Signal in PLC?
Different PLC available in the Simatic S7 generation
Overview of SIEMENS PLC – S7-1500, S7-1200, S7-400, S7-300
TIA Portal MOVE Instruction
MOVE Instruction in PLC – What You Need to Know?
Power Electronics Applications Quiz
Memory Devices Objective Questions – Part 2
Safety PLC Programming steps
Safety Door Interlock PLC Program
Electronic Force Balance Pressure Transmitter
Thermal Differential Level Measurement
What is Thermal Differential Level Measurement?
Current-to-Percentage-Conversion
Formula for Current 4-20ma to Percentage Conversion
Measurement of Phase Angle Objective Questions
Capacitor Filter Operation
