Reading: Center Tapped Full Wave Rectifier Operation
Inst Tools > Blog > Electronic Devices & Circuits > Center Tapped Full Wave Rectifier Operation
Last updated: October 4, 2016 12:56 pm
Electronic Devices & Circuits Electronics Animation
1 Min Read
A center-tapped rectifier is a type of full-wave rectifier that uses two diodes connected to the secondary of a center-tapped transformer, as shown in Below Figure. The input voltage is coupled through the transformer to the center-tapped secondary. Half of the total secondary voltage appears between the center tap and each end of the secondary winding as shown.
For a positive half-cycle of the input voltage, the polarities of the secondary voltages are as shown in Figure (a). This condition forward-biases diode D1 and reverse-biases diode D2. The current path is through D1 and the load resistor RL, as indicated.
For a negative half-cycle of the input voltage, the voltage polarities on the secondary are as shown in Figure (b). This condition reverse-biases D1 and forward-biases D2. The current path is through D2 and RL, as indicated. Because the output current during both the positive and negative portions of the input cycle is in the same direction through the load, the output voltage developed across the load resistor is a full-wave rectified dc voltage, as shown.
center-tapped-full-wave-rectifier-animation
(a) During positive half-cycles, D1 is forward-biased and D2 is reverse-biased.
Center Tapped Full Wave Rectifier Working Animation
(b) During negative half-cycles, D2 is forward-biased and D1 is reverse-biased.
Electron Gun of Cathode Ray Tube
Basic Electronics Questions & Answers
Transistor Emitter Bias
Ideal Diode Characteristics
Transistor Voltage Divider Bias
Capacitor Filter Working Principle
Dependent Voltage Source
Forward Bias & Reverse Bias Diode Working Animation
Zener Diode Limiter
Capacitively Coupled Multistage Transistor Amplifier
Light Emitting Diode Operation
Phototransistor Working Principle
Basic DC Power Supply Circuit
Short Notes on Rectifiers & Filters
Comparison of MOSFET and BJT
capacitor-filter-ripples
Ripple Voltage in Rectifiers
LC Tuned circuit Working Animation
Transistor Collector Characteristic Curves
Power Supply Circuit Working Animation
Transistor as Amplifier
parallel-resistors-circuit-example
Series and Parallel Resistors
kirchhoffs-voltage-law
What is Kirchhoff’s Voltage Law
How Does an Infrared Thermometer Work
How Does an Infrared Thermometer Work?
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
D.C Tachogenerator Principle
Design a flip-flop using other flip-flops Questions
Corona-Ring-on-Surge-Arresters
Analyzer Sample Conditioning
Sodium Analyzer Problems and Troubleshooting Steps
Code Simulation of Safety Circuit
Feedback Monitoring in Safety PLC
